Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Old 03-02-2020, 06:35 PM   #26
97OBLimited
Member#: 224432
1997 Outback Limited
2012 DGM Impreza Hatch
I'll play, here's my box at work:
Damn, image quality took a hit, did the hosting quality get reduced?
97OBLimited is offline   Reply With Quote
Old 03-02-2020, 06:53 PM   #27
chapstien
Member#: 68284
1999 GMC Sonoma
hhhuate
Hosting quality improved in that you can load a funking page of images now. You may find a thread about it somewhere.
chapstien is offline   Reply With Quote
Old 03-02-2020, 11:19 PM   #28
GrundleJuice
Member#: 165749
A toolbox with plants on it? Is that what Snap-On boxes are good for?
Old 03-03-2020, 07:55 AM   #29
Salvation27
Member#: 292403
2012 Legacy
Graphite
Originally Posted by Sloth View Post
WhAt iS tHiS tHinG????
Salvation27 is online now   Reply With Quote
Old 03-03-2020, 08:05 AM   #30
GrundleJuice
Member#: 165749
Can't you read? It's a fish stretcher and carpet descaler.
Old 03-03-2020, 08:22 AM   #31
Salvation27
Member#: 292403
2012 Legacy
Graphite
I remember the thread about it
Old 03-03-2020, 09:03 AM   #32
97OBLimited
Member#: 224432
Try putting two pineapples on a Harbor Freight box and see what happens!
For real though, did reddit ever come to a conclusion? I searched but couldn't find it on r/whatisthisthing.
Old 03-03-2020, 09:19 AM   #33
SVX WRX
Member#: 26358
2018 RS 400
Originally Posted by Strider View Post
I only buy the finest overpriced chrome plated **** from some roaming dude in a truck who lets me finance on a weekly basis because I'm an idiot who makes poor financial decisions while also thinking I need to impress the other fellas at the quick lube shop with an $8k toolbox I don't need.
I think that about covers it.
is that like buying expensive designer boots to wear in an office?
SVX WRX is offline   Reply With Quote
Old 03-03-2020, 11:14 AM   #34
kos
Member#: 118334
2006 Red GDA-F
2005 Aspen White GDA-E
Been fairly keen on the new Milwaukee Packout line of storage. Would be nice to take that as a toolbox for track days and what not, with some Kaizen foam inserts to hold everything in place.
kos is offline   Reply With Quote
Old 03-03-2020, 11:43 AM   #35
Dentt42
Member#: 180570
I'm looking for a good roller toolbox now. How are the current offerings from Craftsman? I've been looking at some available through Lowe's that are 'Murican made.
Dentt42 is offline   Reply With Quote
Old 03-03-2020, 12:42 PM   #36
GrundleJuice
Member#: 165749
Over smooth concrete and a generally clean area? Probably ok. Everyday use on rough concrete, casters and bottom might not last too long.
Old 03-03-2020, 12:44 PM   #37
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
in all seriousness...
I need a 22mm thin walled socket that is actually thinner than a normal one. I ask because it seems the vast majority of sockets marked thin wall on amazon and elsewhere are not actually thinner than normal...
need for wheel duty, my existing 1/2" drive impact socket technically fit in the hole but I just completely ****ed the finish on my wheels putting them on.
Any thoughts?
Akirasoft is offline   Reply With Quote
Old 03-03-2020, 12:57 PM   #38
torquemada
Member#: 128484
2006 EDM WRX STI
Any thoughts?
change to something like this?
Old 03-03-2020, 01:19 PM   #39
GrundleJuice
Member#: 165749
Snap-On non impact sockets are thinner walled than typical Craftsman/big box store stuff. Would be a $25 test to find it if it clears, though. Or you could turn down a cheaper one. In either case I wouldn't break free or tq with an impact wrench, though.
Old 03-03-2020, 01:33 PM   #40
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Any thoughts?
I had good luck with this brand, might need to get the version without the protector though. https://www.amazon.com/Grey-Pneumati.../dp/B007QV26XK
On the Forgestar F14 wheels I have I had to go to a smaller diameter nut with its own driver. What torquemada posted would work also.
Old 03-04-2020, 08:45 AM   #41
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
yeah, I actually found the GP ones online, with the protector they are about the same OD as my existing socket (GP with protector is 31.5MM, my Craftsman is 32mm). Not sure if that .5mm will make a difference. Might be just fine since the protector will help prevent it from marring the surface further and 32mm does fit in the hole... just barely.
Old 03-04-2020, 09:27 AM   #42
bcblues
Member#: 17256
18 Outback
on the road....
It will probably work. I had a set of wheels that had tight pockets for the lug nuts. A normal socket would not work with regular lug nuts. I bought a set of smaller headed forged lug nuts and a steel regular deep socket would barely fit (I mean tight - you could tap it onto the lug nut but really not turn it without bunging up the wheel finish). I bought a "slim protected" socket and it worked well, even though there was only a mm or so difference in diameter.
bcblues is offline   Reply With Quote
Old 03-04-2020, 09:56 AM   #43
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
indeed. I basically already royally screwed up the surface anyways but it might be nice to avoid it in the future, especially since I'll be swapping wheels at least a dozen times a year.
Old 03-04-2020, 10:08 AM   #44
tommaso05
Member#: 277826
2009 TSX 6 speed
^Similar to those are the Titan Tools sockets. The nylon/plastic part slides off and leaves a super thin socket. I had to buy one for the winter wheels on my Hyundai Kona as nothing else would fit.
Can get on Amazon, but I needed it in a hurry and AutoZone carries them for about the same price. I couldn't find a thinner socket.
tommaso05 is offline   Reply With Quote
Old 03-04-2020, 10:57 AM   #45
Dentt42
Member#: 180570
I had a set of McGard spline drives on my WRX, and the tool they came with was about at thin as you could get, coupled with the nuts themselves being quite small in diameter. Plus, they're two-piece so the seat doesn't have to twist and dig into the wheels as you torque em.
https://www.oakos.com/MCG84247.htm?g...QaAqwNEALw_wcB
^^Chosen just for the pic.
Old 03-04-2020, 11:39 AM   #46
aod
Member#: 7121
TIL socket condoms.
aod is offline   Reply With Quote
Old 03-04-2020, 12:33 PM   #47
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
yeah sadly there don't appear to be many itty-bitty lugs like that for my car. I've got big-honkin lugs that get torqued to 140 ft-lbs!
*EDIT I'm an idiot*
sorry, didn't see that you said "shared just for the pic". It does look like they offer something that might work for me and in black which would look less terrible... Wonder if they hold up to highish-torque applications ok?
Old 03-04-2020, 12:53 PM   #48
aod
Member#: 7121
Mike,
You can torque deez.
Old 03-04-2020, 01:24 PM   #49
Dentt42
Member#: 180570
*EDIT I'm an idiot*
140 ft-lbs is up there for sure, but the two piece design may help by reducing stress on the splined adapter as you turn them. It's made of aluminum and lightweight, but seemed well made.
What thread pitch do you need?
Old 03-04-2020, 01:28 PM   #50
mitch808
Member#: 10228
2002 Subaru WRX
You could always have a socket machined down too.
I'm learning I have to grind down wrenches and such to make them thin to fit in newer cars with really tight features.
mitch808 is online now   Reply With Quote
