#1 |
Member#: 74041
Vehicle:2006 2012 Weee-strom 14 Hyundai Borenata |
![]() Simply put, are all 5mt from 2003 to 2011 the same? Wiki says it is called the Revised 5MT and I have an 06 2.5i with a dying center differential, and it seems more cost effective to just buy a used trans and swap it in.
Can I swap any of these years in and it wouldn't mess anything up? I read somewhere the 5mt from 06 - 07 have different ratios, but would it matter than much if I swapped in say an 09 trans? This is for a weekend rallycross car, not a primary driver. Thanks. FYI I did run through the pertinent faq and they were educational but just want to confirm whether or not the supposed different ratios matter with the rear differential.
#2 |
Member#: 220971
South East
Vehicle:2004 Impreza |
![]() The Final Drive Ratios, and Transfer Ratios make ALL the difference between nuking the diff and trans or not. I've literally seen rear diffs catch fire from wrong transmissions swapped in.
The Gear set ratios make no difference. Also- Variations in if the trans has Vehicle Speed Sensor, (VSS) nor not. '08-and later went to ABS, no sensor in the trans. Variations in Front axles Female (roll pin style Usually '04 and earlier) or Male (clip in) axle interface. Here's the chart with the Trans codes https://rallispec.com/downloads/Tran...art_Public.pdf Bottom of the list you should have a TY754VC7AA , 3.900 FINAL, with a 1.000, Transfer = Only other on the list similar would be 05-07 LEGACY, {forester and outback WILL NOT WORK UNLESS swapped with the matching Rear Diff assembly.} Last edited by Blktrax; 03-08-2020 at 12:43 PM. |
#3 | |
Member#: 74041
![]() Quote:
I appreciate this greatly! |
#4 | |
Member#: 239822
South East
Vehicle:2010 WRX pandiculation |
![]() There's some good info here:
https://www.rallispec.com/gea_syn_rst1140_t.html Quote:
#5 |
Member#: 521600
![]() Hello,
New and need some help! Where do I find the correct Outback transmission code list and final drive (FD) ratio? How to confirm my current outback LL Bean 3.0 H required FD ? Rear end differential has a code stamp..? Car Vin. 4S4BP86C984328117 Trans Code: TG5D7CVDBA-UW ...has the Si-Drive 3 position knob on the console. Getting a turbine speed fault in the transmission code I found a JDM trans on E-Bay TG5C7CVDBA all gears are matching a code chart I found off of NASIOC ....EXCEPT the FD ratio Need answers ASAP, thx for the support!! Joe |
#6 |
👏 Big Ron 👏
Moderator Member#: 18062
![]() https://forums.nasioc.com/forums/sho....php?t=2931575 has some rear diff codes
Search on cars101.com for your year/model as that usually has ratios. |
#7 |
Member#: 445600
Vehicle:2002 Outback Sport Green |
#8 |
Member#: 521600
![]() THANKS!!
I did a manual check as well ....10 full turns of the rear tire in neutral resulted in ~31 turns of the driveshaft so a low 3.1 ish reading .....close to the 3.273 ratio. How to decode the original transmission code TG5D7CVDBA I can find a JDM TGC7CVDBA is this a equivalent swap? Only difference is D Vs. C..? Looks like the 5 transmission gear ratios are correct 1/3.54, 2/2.264, 3/1.471, 4/1.0, 5/0.834 and FR of 3.273 Note factory trans has harsh shifts and is getting a turbine sensor fault but I believe only replacement is a Vbody at $900.00+ so a JDM swap is low miles and hope it is a proper match. Does the Si-Drive bring in any other issues to check on with the JDM trans..? Again THANKS!!! Joe |
