#26 |
Member#: 425415
BAIC
Vehicle:66 Bug with ej20g |
![]() Right now I am usung a stock 5 speed clutch. It seems to hold up okay. I also have a stock sti clutch I can use. And my buddy sold me a stage 3 setup, but not sure if I want to use it. I may just use the disc from it, or a stock disc with bigger pressure plate if I start slipping.
Absolutelyeti - what motor are you putting in your type 3?
#27 |
Member#: 425415
BAIC
![]() ![]() Here's the new motor: 2.5 block with darton sleeves Je fsr pistons, 9:1 compression Manley h tuff rods King race bearings Arp case bolts Arp 625+ head studs 12mm oil pump Stock 08 sti heads Stock 205 cams Brian Crower pulleys (still need to index them) Killer b pan, pickup, and windage tray Ej253 big manifold AMR 490 turbo (for now) ID 1300cc injectors Microsquirt 3 ecu Last edited by Mauricemonge; 01-03-2021 at 03:33 PM. |
#28 |
Member#: 425415
BAIC
![]() Dropping the engine 1.5” and making a firewall
