Welcome to the North American Subaru Impreza Owners Club Sunday March 7, 2021
Old 07-25-2020, 11:49 PM   #1
4bang4now
Member#: 489016
2015 STI
Default I broke 3 out of 4 ringlands
The pictures show a couple of them cracked. When I pulled them out of the wash they completely fell apart between rings 1-2 and 3-4. Never smoked or had any feedback knock, or any other issues with logs. It was tuned here locally, and they did all the work. Unfortunately, I have had the car sitting for almost a year since the work was done when the car caught fire (due to blowby and crankcase pressure causing valve cover gaskets to leak oil on exhaust). If you want more info feel free to PM me. I'm pissed as this is all tune related. Compression was good on a all 4 before E85 install (according to them).
Dallas / Fort Worth Area
4bang4now is offline   Reply With Quote
Old 07-26-2020, 12:14 AM   #2
Blackfin
Member#: 361325
2010 STi
Dark Gray Metallic
Did the rings survive? Are you able to measure the ring end-gaps?
Blackfin is offline   Reply With Quote
Old 07-26-2020, 01:00 AM   #3
4bang4now
Member#: 489016
2015 STI
Top ring broke when I pulled it off. I am in the process of haveing a full longblock which will be finished over the next couple days. Originally, I didn't even see the cracks until I started cleaning them up in an effort to see WTF happened. Unfortunately, the rings got tossed in the scrap bin...
Saddest part. This engine only has 43k miles, never missed a beat and didn't smoke, and no white crap on oil cap. Bearings looked good with even wear with no scarring.
I just about gave up on Subie, but threw a pile of money at her, she will get a heart transplant and hopefully live a better life.
Old 07-26-2020, 12:11 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
wow thats crazy, what turbo were you running with that setup
subaru_gc8 is offline   Reply With Quote
Old 07-26-2020, 04:58 PM   #5
djoye
Member#: 50072
2017 STI
Mods? How much power did it put down and on what model dyno?
djoye is offline   Reply With Quote
Old 07-26-2020, 06:22 PM   #6
4bang4now
Member#: 489016
2015 STI
Cobb AF
Nvidia divorced catless DP
Stock turbo, still ZERO shaft play
Billet TGV deletes
Parallel PTFE fuel lines
IAG Rails
1050x inectors
Cobb E85 full kit
AEM 320lpr fuel pump
Fuelab FPR
330whp Mustang Dyno @ iirc 22 psi
Old 07-26-2020, 06:24 PM   #7
4bang4now
Member#: 489016
2015 STI
Stock
The closed deck is my new one, that thing is a whole different animal.
Closed Deck
Pinned mains w/ line hone
New Nitrated Crank
Callies Ultra Enforcer I beam Rods
CP Pistons
Upgraded coated Rings
Clevite bearings
1/2" Head studs rolled thread not tapped for extra strength in the block
12mm oil pump
KillerB Pickup and baffle
Full timing set with gates Racing belt
GSC S2 cams (272s)
Beehive Springs w/ Titanium retainers
GSC 32mm Intake valves
GSC 36mm Exhaust (Super Alloy)
GSC Valve guides
Pocket ported Exhaust +flowbench tested
Funny enough I ran out of funds to upgrade the fuel and turbo for this setup. So I'll have to run the setup I previously had until I get more $$$ to really push this thing. Totally freaking lame.
The current setup is built by the same guy/shop that built the longblock in Kozmics record holding 1/8 mile car
Kozmic Motorsports in Houston will do the break in tune as well as the final.
Old 01-08-2021, 02:14 PM   #8
amsteelle
Member#: 521507
So many people say they have the issue, and if you get it tuned it brings down the chances of ringland failure. And the tune shop that did it said the same. But of course the issue is still possible. So does anyone have anything to say about that as far as getting the tune done and having less of a chance of failure happening ?
amsteelle is offline   Reply With Quote
Old 01-08-2021, 03:02 PM   #9
undyjr
Member#: 459692
2019 WRX STI
silica black
Originally Posted by 4bang4now View Post
Cobb AF
Billet TGV deletes
IAG Rails
1050x inectors
Cobb E85 full kit
Fuelab FPR
330whp on a Mustang Dyno seems a bit over what you should have with a safe tune. With similar mods and the addition of a catted downpipe and Killer Bee EL header my tuner would only "allow" 340whp on a Dynojet at 21#s of boost. I've added a Blouch 20G XTR and an EWG since then. I was offered a safe tune and a "order your short block and oil pump/cooler now" tune. I chose the safe tune and now I'm at 390whp and 22#s. I wish you luck with your build and tune.
undyjr is online now   Reply With Quote
Old 01-12-2021, 07:12 PM   #10
kharmicresonance
Member#: 461898
2004 Forester XT MT
01G
Was the whole setup stock before going to this tuner?
OR were the mods on there and this was the jump to E85?
If the mods were on there first, then you don't really know when the ringlands broke ( although the breaks in your pics do look pretty clean - implying the breaks are not old )
Honestly, either way, if a tuner turned to me said they were pushing 22psi on my *stock turbo and internals* I would have just immediately taken the car to a more reputable shop and told the original tuner to pay for a new engine.
That said, I have seen stock engines with aftermarket up/down pipes reach ~300whp @ 18psi on pump gas with a decent tune. With your list of mods on the stock turbo and internals you should have been hitting 330~350whp at around 18~19psi. So the tuner was getting some pretty big red flags that something was going down with your engine during the whole tune process. Whether they honestly missed that, or just pushed it and expected you not to figure it out, that is for a lawyer to figure out.
kharmicresonance is offline   Reply With Quote
Old 01-12-2021, 11:18 PM   #11
Chi_San
Member#: 53558
2005 Baja Turbo
White/Silver/Black 3tone
That's a hell of a wash...
Chi_San is online now   Reply With Quote
Old 01-13-2021, 05:59 PM   #12
benflynn
Member#: 515308
What tune on earth saves cracked pistons?
benflynn is offline   Reply With Quote
