Welcome to the North American Subaru Impreza Owners Club Tuesday March 2, 2021
Old 11-17-2020, 02:20 PM   #1
tomsti03
Member#: 511743
Default Impreza Sti 2003 lost power hlgh rpm
Hi. I have European sti 2003 ej207 stage 2 340hp, as it turns out that one day it stopped blowing at high revs.
The car makes a small sound and the turbo pressure drops suddenly, going from 22psi to about 14 or less from an estimated 5200 rpm.
It is as if the engine does not suck or evacuate gases. I have changed the speed connector, coils, spark plugs, new gasoline pump, filter, checked the timing, I installed a fixed turbo wastegate, cleaned all the connections ...
It emits as a small blow and the turbo pressure drops suddenly, when before it reached 22 psi at cutoff. Turbo looks good
What do you think it may be?
tomsti03 is offline   Reply With Quote
Old 11-18-2020, 08:30 PM   #2
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
my first guess would be the Tune...the ECU controls the Boost controller and WILL cut if it reaches a certain level..
What are you using for Engine Management??
and What Turbo??? VF30-?? VF-22??
The other thing would be to check the wastegate actuator??? to see if its holding..
My guess is...its not holding the boost level you have designated for your Tune...
Someone else can chime in.. but those are my initial Thoughts..Good luck
Bill
Scooby South is online now   Reply With Quote
Old 11-18-2020, 09:18 PM   #3
Blackfin
Member#: 361325
2010 STi
Dark Gray Metallic
Does the car still have a catalytic converter(s)? If so it may be damaged and causing a blockage.
Blackfin is offline   Reply With Quote
Old 11-18-2020, 10:22 PM   #4
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Good call.. That definitely is a possibility..
Bill
Old 01-09-2021, 09:55 AM   #5
tomsti03
Member#: 511743
Default Log inside
https://drive.google.com/file/d/1Y7v...ew?usp=sharing
Here's the log of the car. The car losses turbo pressure after 5000 rpm. The maf signal also drops and when this happens i hear a small hit sound.
I checked the syncronitation timing belt, changed the coil packs and spark plugs and no intake leaks.
The car was working fine and this happened suddenly, it has a fbo performance stage 2. Full exhaust 3", bov, walbro 340 classic stage 2.
Old 01-09-2021, 12:36 PM   #6
kopele
Member#: 363007
2008 STI
Not sure what the sound might be, but I would check the boost controller, wastegate, and vacuum lines. Looks like it might be dropping to spring pressure, which most often is around 14psi.
kopele is online now   Reply With Quote
Old 01-09-2021, 05:28 PM   #7
Gucciflipflops
Member#: 521349
2005 Impreza WRX
Possibly an exhaust issue. I think Steve Tuned on youtube had an issue similar to this and it ended up being something random in the exhaust system. If you have cats your cats could be going bad.
Gucciflipflops is offline   Reply With Quote
Old 01-10-2021, 02:52 PM   #8
tomsti03
Member#: 511743
Already discard all that, lock wastegate mechanically to see that it does the pressure and does exactly the same.
Regarding the exhaust system, I do not have catalysts. I have a complete line 3 "plus kakumei collectors.
