Welcome to the North American Subaru Impreza Owners Club Sunday February 28, 2021
Old 12-03-2020, 11:27 AM   #1
Morgynn96
Member#: 520567
Default Need some hybrid motor advice!
I have a phase 1 22t block that I plan to put into my 04 WRX sedan, I am curious if I should use the heads off of my stock ej205 or I could use some 251 heads with Delta 1500 cams that's have been port and polished, I've heard the 251 heads will require modification and some wiring to make them work where as the 205 heads should work fine, also what head gasket should I be using for the 251 heads? There's a ton of info on using the 205s but can't seem to find much on the 251/ 22t hybrid, also I'm curious what injectors I should be getting to support 380-400hp? Thank you!
Morgynn96 is offline   Reply With Quote
Old 12-06-2020, 03:33 PM   #2
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Hi,
Not my specialty, but the HG should match the block in most cases - for either of your heads.
Running the EJ22T (graphite?) is the easiest, but I'd look into getting a MLS-type for longevity. The phase II/2 EJ222 ('99-'01) might be an option or may be too thin?
Supposedly Cometic can custom-make them if the coolant/oil passages don't line up.
Double-check your DOHC intake manifold (IM) fits those SoHC heads, too.
You'll need some aftermarket injectors for anything over about 300hp, so look on here for best options. Probably pick up a used set in the Classifieds.
wtdash is offline   Reply With Quote
Old 12-06-2020, 10:09 PM   #3
Morgynn96
Member#: 520567
Thank you I appreciate your help ***128522;
Old 12-06-2020, 11:09 PM   #4
Bansheeboy11
Member#: 182415
1999 RS
You should read around a bit more, if you have an 04 WRX then sohc heads will not work with the ECU in the car, just keep 205 heads on it. Any particular reason you want to use the 22T block? Theres almost no upside over a 205 block to be honest. And your injectors will entirely depend on the turbo you use, these days everyone just runs ID1000s or equivalent.
Bansheeboy11 is offline   Reply With Quote
Old 12-13-2020, 12:55 AM   #5
Morgynn96
Member#: 520567
I'd rather use the 25w heads because they've had work done too them recently, and I'm using the 22t block because I know it's a good strong block and I spun a rod bearing about 2 weeks ago, I got a car for parts and I'm using the block
Old 12-16-2020, 07:46 PM   #6
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
The only reason I like the 22T block is because it's kinda old-school and rare which makes it sort of cool but not a real reason to run one. It's a bit more displacement than the 205 of course. It's nice that it's closed deck and all but my power levels don't need it. Oil squirters are kinda cool but it's debatable if they offer any advantage. Plus they get clogged and fall out if you don't lock tite them. OP if you run a 22T get a set of new squirters or check your's to make sure they open at the correct psi.
If I went back and did it again I'd just go with a 2.5 block. But I found my 22T filled with water under a tarp and went for it lol. I've had about 8 or 9 of them over the years haha. Sold most of them to some nutballs in the UK.
monkeyposeur is offline   Reply With Quote
Old 12-17-2020, 05:31 PM   #7
SoCoNoHa
Member#: 478524
1995 EZ30 Coupe
Green
I like EJ22T's as well. Slap some real heads on and enjoy!
Got some relevant info here just in case.
https://www.rs25.com/threads/if-your...efully.220993/
SoCoNoHa is offline   Reply With Quote
