Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Old 12-06-2020, 12:46 PM   #1
Powsurfer96
Member#: 493872
Default Can I run USDM ej205 heads on a Jdm short block?
My 170k engine is getting a little tired, so Iím starting to plan out what direction I want to go with replacing it. I donít really want to deal with all the headaches of settling up or deleting AVCS. So I was wondering about using a jdm shortblock with my USDM heads. Has anyone done this?
Powsurfer96 is offline   Reply With Quote
Old 12-06-2020, 12:54 PM   #2
Bansheeboy11
Member#: 182415
1999 RS
Yes..
Bansheeboy11 is offline   Reply With Quote
Old 12-06-2020, 11:46 PM   #3
Bluestreak03
Member#: 125887
2001 EJ207 V7 RSTi,
Mica Blue
Can you tell me what all setup headaches you speak of? And you can run your JDM block with your USDM ecu just as easy... Whichever way you choose to go is your choice
Bluestreak03 is offline   Reply With Quote
Old 12-07-2020, 12:00 AM   #4
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
setting up AVCS is really not hard and so much worth it...imo I wouldn't ever go back to a non-avcs engine they just are so slow...all you have to do is run 4 extra wires from the engine to ecu...i mean if you can build an engine I'm sure you can get AVCS setup and running...
murrdogg24 is online now   Reply With Quote
Old 12-07-2020, 10:38 AM   #5
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Itís not hard to wire AVCS but not as easy as you say.
D-Rodman is online now   Reply With Quote
Old 12-07-2020, 11:14 AM   #6
Bluestreak03
Member#: 125887
2001 EJ207 V7 RSTi,
Mica Blue
+1 have to have good attention to detail
Old 12-07-2020, 12:12 PM   #7
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Thank you. I'm getting tired of correcting this.
To the OP. Yes add 4 wires but also re-pin wires at the ECU and on an engine harness plug by the battery. This is why companies like iA Tuning and iWire make AVCS wiring kits which do make it easier. And as has been mentioned, once you have AVCS, you'll never want an engine without it again.
snow_bound26 is offline   Reply With Quote
Old 12-07-2020, 11:15 PM   #8
Powsurfer96
Member#: 493872
Actually I would love to have the AVCS, but I really want to be able to get tuned using an accessport. The JDM ecu is what I meant by headaches
Old 12-07-2020, 11:29 PM   #9
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Get it open source tuned. It's not a headache. It's just a different platform. And it will save you money since you don't have to buy an AP. And if you already have one you can sell it and make some money back. I don't miss having my AP. AVCS is worth more than having the AP
Old 12-08-2020, 01:29 AM   #10
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Agreed.
Old 12-09-2020, 03:02 PM   #11
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
Don't you need the JDM ecu to run AVCS? If so I would have problems with emissions where I live. I could always swap over the the USDM ecu to pass I guess...
monkeyposeur is offline   Reply With Quote
Old 12-09-2020, 03:33 PM   #12
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Not sure what you're really asking here. Yes you need the JDM ECU for AVCS and yes you take 15 min and swap the ECU for emissions.
Old 12-09-2020, 04:41 PM   #13
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
OK, I was confused by you saying it's not a headache and when you mentioned it could be open sourced tuned I was wondering if I missed in my research if using a USDM ecu to run AVCS was a possibility.
Yes, swapping out the ECU isn't that big of a deal. Maybe a little bit of a pain for some, and adding to that pain is the fact that I have to swap out my high flow catted DP every year for the stock DP makes it a little bit more of a pain.
Old 12-11-2020, 03:55 PM   #14
saaiello21
Member#: 501997
2011 WRX
gray
You just need to find a shop that will over look the visual inspection. I have been running catless for years and my shop will pass it as long as no engine light on.
saaiello21 is offline   Reply With Quote
Old 12-14-2020, 03:01 PM   #15
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
I too wanted to know about using my usdm ej205 heads, that i have, on a jdm ej20 block that has no heads, and only responses were "thats stupid, do avcs". I wish ppl would just help instead of try to persuade other to do things different...
Im 99% sure you can bolt usdm ej20 heads on a jdm ej20 block, and should be able to run it and tune it with the usdm ecu.
No clue what that will do to compression ratio or piston to valve clearance other than "thats stupid, AVCS ftw!!!!"
4eat05 is offline   Reply With Quote
Old 12-14-2020, 03:31 PM   #16
snow_bound26
Member#: 395793
2005 92x Aero
Beige
It sounds like the OP has a JDM long block. In this case it's easier to install the entire long block regardless of using AVCS. Tearing everything apart would result in taking it to a machine shop and having everything clearanced and tolerances checked before mating it all back together. It's an added expense.
If you have a JDM short block and no JDM heads then that's a different story. There's no reason why you can't use the USDM heads and make it work. Any reputable machine shop can check tolerances, and make sure you're getting proper piston to valve clearance and quench height.
The problem is there's a lot of bad information out there that makes people scared to use the JDM engines and hook up the AVCS when they aren't familiar with the process. So if you have a full JDM long block, why spend the extra time and money to use the USDM heads and not have the extra performance of the JDM heads? It's a step backward. If you don't have the heads then it really doesn't make a difference. Do whatever fits your budget best as no matter what heads you use, they will still need to mated to the SB properly.
Old 12-14-2020, 05:54 PM   #17
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
For me, its because i have good usdm ej205 heads and couldve grabbed a good ej207 short block for cheap, but never got any advice other than "avcs!" Lol
All im saying is, cant we help him with info about his question, usdm heads on jdm block, instead of telling him to use jdm heads, which doesnt answer his question?
Old 12-14-2020, 08:14 PM   #18
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Why are you getting on everyone's case? I get that you weren't happy with the responses you had from your questions in a different thread, but in this one, the OP even stated he would like to use AVCS and just thought it was going to be more complicated than he thought. But if he has a JDM engine then why spend the extra money to use inferior heads? If all he has is a short block than he can say so and we can change our responses accordingly.
Without reading your thread I can't say why people weren't giving you info for your specific question. But even so, in this thread people said yes you can and asked what headaches he was referring to. He even stated his only reason for not wanting to use the JDM heads was to retain using his AP. Information was given to show him the pros and cons. Soooooo let's keep this thread on topic rather than getting on everyone's case and if the OP isn't getting the info that helps him he can say so.
Old 01-06-2021, 10:31 AM   #19
Foo_Blyat
Member#: 93750
I have a jdm ej205 with avcs for sale. Compression video included. Can separate the block from the heads if you choose to go that route. Pm me if interested
Foo_Blyat is offline   Reply With Quote
