Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Old 12-21-2020, 12:14 AM   #1
ragnaroc
Member#: 388165
2015 WRX
Crystal White Pearl
Default 15 WRX auto headlights always on
I've noticed that my headlights are always on when in auto mode. They aren't the DRL lights and my guages and screens are also dimmed. I haven't been able to figure out whats going on. There's nothing blocking the sensor to make it think that its dark out.
Any help would be appreciated.
ragnaroc is offline   Reply With Quote
Old 12-22-2020, 04:49 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Is the DRL circuit working properly? I assume that you are saying that the headlights are working at full normal brightness and not in the dimmed DRL mode.
Cougar4 is online now   Reply With Quote
Old 12-22-2020, 05:14 PM   #3
Blktrax
Member#: 220971
2004 Impreza
If you swapped stock halogens to aftermarket LED then thatís your problem. LEDs use way less power and do not operate with the same circuit load as stock bulbs. As most people are unaware and constantly blinding people with full power high beams as DRLís
If you still have stock bulbs , then the sensitivity may be set to the maximum setting turning on the headlights in pretty much any condition other than direct sunlight. Look at your owners manual how to adjust the sensitivity setting.
Blktrax is offline   Reply With Quote
Old 12-24-2020, 05:08 AM   #4
ragnaroc
Member#: 388165
2015 WRX
Crystal White Pearl
I already have the sensitivity down to low and from what I've read that just changes how quickly the go from off to on and vice versa. This was going on before the LED bulbs
Old 12-24-2020, 05:09 AM   #5
ragnaroc
Member#: 388165
2015 WRX
Crystal White Pearl
No I mean my low beams/interior lights are acting like its dark out when its still bright enough for me to wear my sunglasses.
Old 12-24-2020, 12:40 PM   #6
Blktrax
Member#: 220971
2004 Impreza
That sounds like the sun sensor on the dash or the dimmer roll switch left the the steering wheel. If you turn it to the full bright setting the dot, then the dash lights should never dim. Have you replaced the radio? If seen wire issues when the illumination wire is hooked up incorrectly cause all kinds of dash light issues.
Old 12-24-2020, 03:14 PM   #7
ragnaroc
Member#: 388165
2015 WRX
Crystal White Pearl
Still has the stock radio. I have the dash dimmer switch to where I like it for night driving, but my old BRZ wouldn't turn on the headlights until it actually got dark.
Old 12-24-2020, 04:19 PM   #8
Blktrax
Member#: 220971
2004 Impreza
Sounds like a failing light sensor on the dash. The black button looking thing right of the center display about the size of a quarter. Have seen dash cleaners get in there and ruin the chip. Part Number: 84088FJ001
https://parts.subaru.com/p/subaru_20...4088FJ001.html
But I've also seen LED headlight and marker bulbs cause crazy things with the Body Control Module, You may want to try swapping back any LED's to normal bulbs and see if the problem continues.
Old 12-24-2020, 05:04 PM   #9
ragnaroc
Member#: 388165
2015 WRX
Crystal White Pearl
That's kinda what I'm thinking and I've been checking out a manual on how to replace it.
This was happening with the standard halogen bulb that was in the car.
