#1 |
Member#: 65231
Vehicle:2011 STI Wagon Plasma Blue Pearl |
![]() So, I put a 86431va620 (2019 sti non nav) into my 2018 fxt. I bought a 12 pin harness. I added the door wire. I swapped in a 2019 usb hub in the arm rest. Everything up to this point works. I bought a 2nd 2019 usb hub and modified the change tray behind the shifter under the radio to accommodate. I purchased a second 2019 usb arm rest cable. I tapped the original power wiring in the arm rest and used it to power both usb hubs. There are 3 USB ports on the back of this radio. Both cables have the same tab to only fit the left most port. I filed off these tabs. The ports fit any of the 3 now. Both work with CarPlay when plugged into the leftmost port. Neither work when plugged into the other 2 USB ports. What am I missing? Thanks for the help.
#2 |
Member#: 93830
South East
Vehicle:'06 Silverado |
![]() I noticed those ports do have different plug type channels. Not sure if filing the tab was a good move--I suspect those slots are there for a reason. I couldn't find any information on the purpose of each plug, share a link here if you find good info meanwhile.
