Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Old 01-05-2021, 12:55 AM   #1
Ryanvilas102
Member#: 491712
Default After market fuel rails.
Hello just a quick question for anyone out there reading this but I’m planning on doing a tgv delete to my bugeye here soon and I figured while I was at it I’d upgrade my fuel rails...But I’m not sure if I have to upgrade my fuel lines as well or can I keep them stock?
Ryanvilas102 is offline   Reply With Quote
Old 01-05-2021, 03:23 AM   #2
MortonCharbo
Member#: 487057
2002 WRX Wagon
You can keep em stock as long as they provide your injectors with enough fuel. Basically, if you were using them before without issues, they should be just fine.
What turbo/injectors/pump are you running currently?
MortonCharbo is offline   Reply With Quote
Old 01-05-2021, 09:02 AM   #3
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Keep the OEM rails unless they are becoming corroded. I'd replace the pieces of rubber hosing though since they are now quite old. The OEM rails are plenty capable. One thing to consider is having your injectors cleaned while you have everything apart. It's cheap insurance to make sure your getting proper fuel to each cyl.
snow_bound26 is offline   Reply With Quote
Old 01-05-2021, 09:36 AM   #4
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Midnight Black Pearl
My tuner told me switching to IAG rails can help eliminate lean spots while tuning. I'd say upgrade rails when doing TGVs
K3rm1tth3fr0g is online now   Reply With Quote
Old 01-05-2021, 10:25 AM   #5
JarHarms
Member#: 138994
2006 WRX, 6MT, 5x114
TMIC, FP blue, ELH
Aftermarket fuel rails are not worth the effort and cost for 95% of the persons still using factory sized injectors and marginally increased power levels. You will have to deal with fuel line plumbing, address incorporating the FPR, etc. It is very unlikely your setup will need the larger volume of aftermarket fuel rails to address fuel delivery or harmonic issues.
You do not provide specifics on your 2.0L setup or plans. But after going through your prior posts I would stick to factory rails. Doing so will get your car up and running sooner. Very good idea to replace all of the short rubber hoses and clamps while accessible. Also a great suggestion to have the (aged by now) injectors sent out for ultrasonic cleaning and flow checking while you are working on the other tasks. When injectors return you just install them and finish top end assembly.
v - Yes they do clean up the engine area a bit as long as the fuel plumbing is done well. Trust me, I completely get your reason for considering doing those at the same time.
JarHarms is offline   Reply With Quote
Old 01-06-2021, 12:14 AM   #6
Ryanvilas102
Member#: 491712
Thanks for the feedback on this.. I was just looking into the possibility of doing the rails when I do the tgv delete mainly because it seems to clean up the motor a lot more. And honestly I’m not trying to do anything crazy with my 2.0 I’m just trying to get it to run right at the moment... and yes I’ve already had my sti blue injectors sent out cleaned for some insurance.
Old 01-06-2021, 12:19 AM   #7
Ryanvilas102
Member#: 491712
Hey thanks for feedback.. they weren’t causing me any issues before I mainly was just going to do it sense I’d have the stock ones off for my tgv’s and aftermarket rails really seem to clean up the motor. But I’ll probably just stick with stock rails for now.
I’m running a vf48 turbo, 565 injectors (sti blues) and 255 walbro fuel pump
Old 01-06-2021, 12:44 PM   #8
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Honestly you don't really need to do a full TGV delete. Just remove the butterfly plates in the TGVs and you have most of a full delete for $0 cost.
If you want, you can do some blending inside the TGVs.
Samurai Jack is offline   Reply With Quote
Old 01-06-2021, 12:54 PM   #9
Waddlz
Member#: 395275
2012 STi
I ran stock fuel lines with Id1300s, hardwired walbro 450 making 461 whp 461wtq on a rotated EFR 7163 with E85 with 0 fueling related issues for 3 years.
I'm swapping to aftermarket fuel rails because I think the OEM rail being small caused me to burn up a walbro 450, and the IAG TGV deletes kept kinking the fuel rails causing boost leaks.
Waddlz is offline   Reply With Quote
Old 01-07-2021, 12:05 AM   #10
MortonCharbo
Member#: 487057
2002 WRX Wagon
Keep your stock setup then.
I highly recommend taking JarHarm's advice on replacing all the little rubber hoses in there as well.
Old 01-12-2021, 12:17 AM   #11
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Stock fuel rails are fine. Aluminum is nice because they heat up slower. Steel heats up faster but also cools slower.
spoolinsti05 is offline   Reply With Quote
