Welcome to the North American Subaru Impreza Owners Club Thursday February 25, 2021
Old 01-08-2021, 02:37 PM   #1
m5gorrf
Member#: 468210
2006 WRX Wagon
Default 340Lph in stock setup?
Hi, Thanks for reading!
I will soon be upgrading my turbo from the TD04,
Any issues with upgrading my fuel pump to a 340Lph before / just run stock injectors with the TD04? About time to do the fuel filter & the turbo swap is a few months off.
Thanks
m5gorrf is offline   Reply With Quote
Old 01-08-2021, 02:44 PM   #2
JSR84
Member#: 469585
2009 STi
I think you're asking if you can install the new fuel pump before doing injectors and the new turbo... If so, the answer is... that won't be a problem.
JSR84 is offline   Reply With Quote
Old 01-08-2021, 02:46 PM   #3
m5gorrf
Member#: 468210
2006 WRX Wagon
Yes correct thanks for making sure.
Old 01-08-2021, 02:49 PM   #4
neg_matnik
Member#: 132389
Thanks
No, it's perfectly fine. And, yeah, it's a good idea to get a new fuel strainer ("sock") with a new fuel filter with your new pump.
I'd also get a new/fresh rubber gasket (between the fuel pump assembly and the fuel tank).
neg_matnik is offline   Reply With Quote
Old 01-09-2021, 03:26 PM   #5
m5gorrf
Member#: 468210
2006 WRX Wagon
Thanks for all the input you all have been GREAT!!!!!
Any thing to consider with putting in an E85 pump now even if I might not go E85 in the future? Beyond cost..
Old 01-09-2021, 04:13 PM   #6
JSR84
Member#: 469585
2009 STi
Nope, the E85 pump just ensures that all the components are E85 friendly and wont react.
Old 01-12-2021, 02:04 PM   #7
m5gorrf
Member#: 468210
2006 WRX Wagon
Thanks, truly appreciated.
