#1 |
Member#: 407661
![]() TLDR: Accessport shows boost, gauge doesn't. Both show vacuum.
I picked up a 2005 WRX with a very blown head gasket. I pulled the motor and freshened up everything. It runs well, but I think I've had turbo problems the whole time. Since I've gotten it running again, there is never any boost on the gauge, but it shows vacuum and that correlates with the Accessport. The Accessport will show boost up to 22 psi (throwing an overboost code in the ECU and cutting power.) I figured my analog gauge was bad, so I replaced it. The new analog gauge also shows vacuum, but no boost. Aiming my air compressor shows both gauges are capable of showing boost, ie, they're not broken. Putting my finger over the turbo line, I feel vacuum, no matter the rpm I open the throttle to. The line will not blow away from my finger. I checked at 2 different lines, one right on the aluminum intake manifold. What is going on, because I'm completely baffled? Edited to add: the analog gauges go to zero when boost should be (is according to the Accessport) building. The just never go above zero.
#2 |
Member#: 179775
South East
Vehicle:03 WRX/15 FXT 14 BRZ/ 92 SVX |
![]() No codes? Where is the gauge pulling the air from? May have mixed up some vacuum lines during reassembly.
#3 |
Member#: 407661
#4 |
Member#: 82677
![]() check the vacuum line.. maybe it has on of them one-way valve. like these https://www.siliconeintakes.com/imag...Check-Main.jpg
#5 | |
Member#: 428511
Vehicle:2016 STI |
![]() Quote:
If so you are never going to build boost just winging a throttle in neutral, never going to happen. It will basically just dip vacuum to zero and then instantly pull vacuum again because it's impossible to do that in neutral. I'm not sure what your issue is, but that test method is useless. I mean, you must know if you have boost when you drive, so it sounds like you know you have boost, it's just a gauge issue. So check out your connection line. Can you suck air through that line and blow into it also to ensure it is working both ways? |
#6 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
#7 |
Member#: 407661
![]() I think I figured it out. The MAP sensor is aftermarket, and I'm not even sure it's for a WRX. I put a good, used MAP sensor on, and now the computer and gauges are in agreement. Thank you.
