Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Old 01-12-2021, 05:40 PM   #1
Ej20xHawkeye
Member#: 514415
2006 Ej20x wrx
Default Leaking boost noise been plaguing me please help!!!
Im thinking ive got a boost leak but im not sure where ive replaced all my intercooler piping, and gaskets my silicone tomei inlet is in great shape. ive done countless smoke tests and still nothing and im still getting the full boost im tuned for on my boost gauge but at wot and under heavy boost the car is reading pretty rich on my WB02 although my cruising and idle afrs are great . I feel like the symptoms all started once i began to hear my turbo get way louder. i have the stock tdo4 and stock bpv, stock intake with a K&N drop in (should i replace with oem?) with a hks tbe and ive never heard any turbo blow off but now there is a noticeable and sometime loud hissing woosh on spool and blow off. I really would like to fix whatever is causing the sound because im almost positive that is my culprit. my tuner initially thought it was a issue with my ebcs plug and advised me to replace it, i havent been able to see him since then as he is far and busy but im trying to schedule some more diagnostics. The noise sounds like its coming from the passengers glovebox so something with the ebcs could make sense im stumped tbh, any insight is appreciated.
Ej20xHawkeye is offline   Reply With Quote
Old 01-12-2021, 06:42 PM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Have you check your turbo to DP gasket? Or the up pipe gaskets?
snow_bound26 is online now   Reply With Quote
Old 01-13-2021, 11:18 AM   #3
SubiPCD
Member#: 480087
Default Leak
If was up pipe you would sound like a banshee from hell on wot.
SubiPCD is offline   Reply With Quote
Old 01-13-2021, 11:18 AM   #4
SubiPCD
Member#: 480087
Default Leak
How much boost you making?
Old 01-13-2021, 01:28 PM   #5
Ej20xHawkeye
Member#: 514415
2006 Ej20x wrx
Im tuned for 18psi and i appear to be making all of it on each pull
Old 01-14-2021, 11:46 AM   #6
MortonCharbo
Member#: 487057
2002 WRX Wagon
Start with the cheapest and easiest. Replace the air filter with an OE one and go from there.
Chances are the drop in filter isn't causing any issues, but they have before. You might as well eliminate that variable
MortonCharbo is offline   Reply With Quote
Old 01-14-2021, 04:16 PM   #7
Whooopasss
Member#: 82677
do you have a mechanical boost gauge? Check the vacuum tube to it. it could also be a leaking/sticking BOV. try to check and clean it.
Whooopasss is offline   Reply With Quote
