#1 |
Member#: 510671
SCIC
Vehicle:2006 WRX Gray |
![]() Yesterday, I was filling the automatic transmission (4EAT) in the Subaru Outback 2001 . I was pouring in a last small bottle of ATF and it seems to have had some water in it. (maybe left in the rain uncapped) About 1/10th of a quart of water was poured into the car transmission . What should I do ? would the water boil off during operation ? I am considering draining the fluid, inspecting for water, removing the part that has water, and pouring it back in.
#2 |
Member#: 504432
![]() That seems like a bad deal. Any way you can siphon out from the top of the transmission? The water will just be sitting there.
#3 |
Member#: 47143
![]() Dbl post
#4 | |
Member#: 47143
![]() Quote:
#5 | |
Member#: 510671
SCIC
![]() Quote:
Here are some other answers I got to this question when posted on a Subaru facebook group (posting here so people can find it when they search on google) "If you didn't run it, drain it and don't worry. If you did run it, drain it and do a 3-cycle flush." "Let it sit as the water will settle in the pan, then drain it out till its atf again and top off and go" "Just drain and refill and change the filter." "ATF is extremely hydrophobic. When mixed with oil and a plastic safe solvent it makes a great additive to a home made Cleaner Lubricant Protectant. " |
