#1 |
Member#: 520383
#2 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
![]() I am assuming the black leads are tied to the same points the other leads are and only one set of leads is needed for the connection. Do the other ends have spade connectors also? If so just match them up and tape up the black leads.
#3 | |
Member#: 520383
![]() Quote:
One of the black leads is like the ground that comes from the bulb, the other black and red are away from it. |
#4 |
Member#: 53443
![]() I am assuming that the black ground lead is also tied to the white lead. Is that correct? If so then you only need to use the leads that fit the wire terminations going to the light.
#5 | |
Member#: 520383
![]() Quote:
Yes that’s correct. So I wouldn’t need to do anything with the other black and red leads? |
#6 |
Member#: 53443
![]() I suggest you just tape up the extra ends well so they can't make contact to anything and stow them away.
#7 |
Member#: 512601
![]() those look like the aftermarket halo foglights red and black are for the halo yes the cap does limit your bulb choice
