Welcome to the North American Subaru Impreza Owners Club Tuesday March 2, 2021
Old 01-15-2021, 01:49 AM   #1
Baru-barage469
Member#: 518883
Default 2006 ashtray lighting swap
how do i change the ashtray light on my 06 wrx?
Baru-barage469 is offline   Reply With Quote
Old 01-15-2021, 09:16 AM   #2
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
Is it a part of the shifter console? I have one of those in my garage from an 07. I'll see if I can find it. Is it broken or something? If I do find it, you can have it for the cost to ship.
Old 01-15-2021, 10:12 AM   #3
Baru-barage469
Member#: 518883
no its not broken i just want to swap to led
Old 01-15-2021, 12:25 PM   #4
Wayne Suhrbier
Member#: 144044
2006 STI
1. buy a number 74 (double check this) bulb in whatever color you want. Get the widest view angle available.
2. Pull shifter trim and then console trim. Unscrew a few screws that hold the lighter in place.
3. swap bulbs
4. reinstall everything
Wayne Suhrbier is offline   Reply With Quote
Old 01-16-2021, 12:10 AM   #5
thatgarrett
Member#: 497099
2007 Outback Sport
Urban Gray
No screws involved, literally just pull up on the silver trim around the shifter and once you pull up and it snaps free, pull back towards back of car. On the right side of the lighter, you will see two wires going to a small bulb in a socket, twist the bulb socket and remove from housing, then pull the bulb out. I like the 74 tower wide angle one from superbrightLEDS, I did mine in red recently. Same bulb fits in your key ring and instrument cluster lights, if you’re interested
thatgarrett is offline   Reply With Quote
Old 01-20-2021, 12:46 AM   #6
Baru-barage469
Member#: 518883
perfect thanks for the info gonna do my cluster now in blue
