Welcome to the North American Subaru Impreza Owners Club Monday March 1, 2021
Old 01-17-2021, 07:35 PM   #1
m5gorrf
Member#: 468210
2006 WRX Wagon
Default " Refreshed ' heads
Thanks for reading!
Has been sometime since I worked with intake & exhaust valves & seats.
Would it be normal for the valve to valve seat, to ooze WD 40 slowly (just be wet) on the other side, after being 'refreshed'. In the past never expected seat to be solvent / water tight just not sure of present day specs.
Thanks
m5gorrf is offline   Reply With Quote
Old 01-17-2021, 09:24 PM   #2
Jp925
Member#: 510046
Just had a similar thing happen. New heads, bolted to block, did a leak down test to confirm everything was fine, 3 of 4 cylinders perfect, cylinder 3 seemed to have an exhaust valve leak. Pulled the head, poured some water in the exhaust port, and it trickled through the valve. Took it back to the shop and they vacuum tested and had 0 leaks with 100psi of vacuum.
He said when there’s no oil in them sometimes they can appear to be leaking but be fine as soon as you start driving it. I’ll be reassembling this week, hoping he’s right.
Jp925 is offline   Reply With Quote
Old 01-17-2021, 09:25 PM   #3
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
Also could have a little grit stick between the valve face and the seat preventing it from closing. Is this with springs on?
GeoNV is offline   Reply With Quote
Old 01-17-2021, 09:44 PM   #4
m5gorrf
Member#: 468210
2006 WRX Wagon
Yes fully assembled with cam lobes up / off. The 'seepage' is very limited & grit could be the cause. what passes barely wets my finger tip after a few minutes.
Thanks
