Welcome to the North American Subaru Impreza Owners Club Wednesday March 3, 2021
Old 01-18-2021, 03:34 AM   #1
WRX_mattb
Member#: 349275
2012 STi
Default Questions on finishing up my build
So my STi has been built for a little over a year now and has been awesome! Currently sitting at 450whp with id1050’s and aem 340lph pump. Here is a list of my current build before I get into my questions so everyone knows and isn’t wondering.
2012 STi
-outfront v4 closed deck
-Manley platinum forged pistons
-Manley I beam turbo tuff rods
-new sti crank
-acl main and rod bearings
-arp 1/2 inch head studs
-kelford 272 cams
-super tech valvetrain
-killerb pick up
-killerb pan and baffle
-iag tgv deletes
-iag v2 fuel rails
-turboxs rotated turbo kit with Garrett gtx3582
-invidia q300 catback
-act xtreme clutch kit
-iag aos
-turboxs fmic
Pretty sure that’s about it. I’m sure I’m missing some small things. The car was built by Andrewtech. I have been talking with them for plans for make 600+ whp and have started compiling parts. I have been in touch with Andrewtech about my plans and they are saying 650-700whp on e85.
But a couple questions came to mind this weekend that I can’t get out of my head and figured I’d ask here to get peoples input. I do plan on calling ata this week to get confirmation. But like seeing others opinions as well.
So as of now this is what we have came up with to finish up my build and get the power I want.
-killerb holy header
-id1700
-radium dual pump hanger with dual 450 pumps
-Cobb flex fuel sensor
-Id f750 fuel filter
-Cobb 4 bar map sensor
-aeromotive a1000 FPR
Now what I’ve been thinking about the last day or so is adding a dampening crank pulley like the ATI or fuidampr. Is this needed for a 650(ish)whp build?
Also I am still running stock engine mounts. I’m looking at the torque solutions mounts thinking that I better upgrade those while I’m there as well. I’m not opposed to running solid mounts if needed. What would you guys suggest? Something the like torque solutions polyurethane mounts, or solid, and why?
Thanks for the input!
WRX_mattb is offline   Reply With Quote
Old 01-18-2021, 09:18 AM   #2
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Building a closed deck myself by TiC for 500whp and was told to use a brand new oem pully or aftermarket like fuidampr. Not sure about solid or not for eng mounts myself yet but deff anything over stock.
How did the turboxs rotated kit fit?
BlackFighter is online now   Reply With Quote
Old 01-18-2021, 09:50 AM   #3
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Built engine or stock, something like Fluidampr or an ATI crank pulley are good options. Been using Fluidampr for several years now and I noticed a difference in how smooth the engine felt. Had a GS lightweight pulley before that and won't go back to any of the lightweight pulleys again.
snow_bound26 is offline   Reply With Quote
Old 01-18-2021, 10:12 AM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
As others have said, a dampener is a great idea on a build like this.
Our header will broaden the power curve and add ultimate power as well. It will wake things up for sure.
Double check the fueling for the ID1700s, we ran 2000s at that power level. With good supporting mods you should definitely be +650whp on E.
As an option to the dual pump hanger, check out Visconti's fuel pump setups. I've used them a couple of times now and I don't think I'll go with a dual pump setup again, just because this setup is pretty easy and seems to be rock steady reliable.
I like the urethane motor mounts. More tolerable on long drives IMO. Other parts look good too!
KillerBMotorsport is offline   Reply With Quote
Old 01-18-2021, 11:30 AM   #5
BlackFighter
Member#: 193940
2004 WRX STI Black
Are you using this in a stock fuel tank or a cell?
Old 01-18-2021, 01:33 PM   #6
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
If you are looking into engine mounts I highly recommend the Perrin mounts, the use a bolt rather than a stud so you can drop the engine onto the cradle and just slide it back into the trans. I pull my engine alone and not messing with the trans hight helps a LOT with making it quick and simple.
Scuby04STi is offline   Reply With Quote
Old 01-18-2021, 03:17 PM   #7
WRX_mattb
Member#: 349275
2012 STi
No issues with the turboxs kit!
Old 01-18-2021, 03:47 PM   #8
BlackFighter
Member#: 193940
2004 WRX STI Black
Is this the kit?
https://www.furiouscustoms.com/turbo...ubaru-wrx-sti/
Is yours a 2 pcs uppipe?
Old 01-18-2021, 03:52 PM   #9
WRX_mattb
Member#: 349275
2012 STi
That says 02-07. But looks similar. My external wastegate is plumbed back into the downpipe just like that.
Old 01-18-2021, 04:06 PM   #10
WRX_mattb
Member#: 349275
2012 STi
Is this the kit?
My uppipe is one piece.
Old 01-18-2021, 04:08 PM   #11
WRX_mattb
Member#: 349275
2012 STi
Me and my shop/tuner were discussing the Visconti basket with the 525 hellcat pump. They are more comfortable with radium dual hanger and dual walbro 450’s. They install them all the time and will give me head room with my pumps for more power on the future if I want it.
Old 01-18-2021, 09:32 PM   #12
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Originally Posted by WRX_mattb View Post
Me and my shop/tuner were discussing the Visconti basket with the 525 hellcat pump. They are more comfortable with radium dual hanger and dual walbro 450's. They install them all the time and will give me head room with my pumps for more power on the future if I want it.
I currently have 45,000 miles on my AEM in-tank pump and dual Radium 450 Walbros with surge tank. Rock solid reliability
GroupN mounts are great, work well for me from 500-800whp
user1029 is offline   Reply With Quote
Old 01-19-2021, 04:15 PM   #13
WRX_mattb
Member#: 349275
2012 STi
Here is another question for you guys. Ive been wanting the killer b holy header since it came out and has been a part of my build plan forever. However, Ive read a few threads and things on the internet about ETSs v2 manifold actually making more power. What is everyones thoughts on the new ets vs killer b?
In my head Im leaning hard killer b. The holy header has been proven time and time again. Not to mention killer b uses 321 stainless compared to ets using 304.
Thoughts?
Old 01-19-2021, 05:40 PM   #14
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Thoughts?
From what user posted in proven power the peak looks like a wash and the ETS picked up slightly quicker. I wasn't there so have no clue how similar the pulls where.
I have helped test a few products and when it involves a dyno the amount of effort to have the same temp, humidity, header temp, ect was a LOT of work and I don't see many people show that they go to those lengths in customer reviews. Just something to keep in mind.
Old 01-19-2021, 09:10 PM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Stock VA basket. never had an issue and surprisingly quiet.
If course I'm biased, but you won't be disappointed
If you have questions, let me know, I'm the guy who designed them.
Old 01-19-2021, 10:40 PM   #16
user1029
Member#: 57064
2008 STi IAG built
Thoughts?
https://forums.nasioc.com/forums/sho....php?t=2930411
Old 01-20-2021, 12:59 AM   #17
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Originally Posted by user1029 View Post
No If its unclear how the data was collected.
If asked what one to give me as a gift KB all day, its got more track time and that shows structural integrity.
I don't run either header (neither is going to add enough to what I have to make a significant change), I just know most people don't realize your car makes different whp nearly every pull (some more then others). With the same tune and PARTS my car has shown to make passes between 118-123 mph (92 tune) mostly on weather. It has never made the same pull twice in a row on a dyno with no change without keeping everything the same (I mean actually the same. Not one pull then another right after). I live in Oregon so I do see a 55* to 100* swing on ambient temps when at the track throughout the year. But the point is that without a LOT of data a comparison is useless.
Old 01-20-2021, 02:09 AM   #18
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
don't get that garbage regulator go with Fore, if you going to daily on pump gas the injectors are too big, also get radium dual brushless pump kit much more efficient pumps and wont heat up your fuel, and for the cam make sure you delete your AVCS because if AVCS freaks out a bit "and it will" you going to bend your valves, so right there deleting AVCS you will loose about 60-80 trq down low.
Bariga is offline   Reply With Quote
Old 01-20-2021, 11:36 AM   #19
pigboat_2
Member#: 247823
2006 Fxt
RBP
Hm, not sure about "garbage", but I would go with a fuelab regulator and FIC 1650's...
pigboat_2 is offline   Reply With Quote
Old 01-20-2021, 08:08 PM   #20
BlackFighter
Member#: 193940
2004 WRX STI Black
"don't get that garbage regulator*"
Why would you think that aeromotive is garbage? Any issues you had with them? Aeromotive have been used on Subarus for years with no major issues as of what I know.
Old 01-20-2021, 08:57 PM   #21
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Midnight Black Pearl
I was wondering the same thing
K3rm1tth3fr0g is online now   Reply With Quote
Old 01-21-2021, 12:22 AM   #22
user1029
Member#: 57064
2008 STi IAG built
I’ve been running an aeromotive FPR for 140,000 miles. I’ve been daily driving the car with 2000cc injectors for 140,000 miles without any problems. Disable dual AVCS? I love the low end torque it’s given me for 165,000 miles
Old 01-21-2021, 04:43 PM   #23
pigboat_2
Member#: 247823
2006 Fxt
RBP
Agreed, no real reason to over complicate things. Aeromotive fpr and ID2k's here. No complaints. Running a Walbro 535 AND AVCS?? I must be doing everything wrong, but at least my valves are straight for now.
Old 01-22-2021, 01:20 AM   #24
WRX_mattb
Member#: 349275
2012 STi
I havent heard anything bad about the aeromotive FPR. Its what my tuner recommends. And at the end of the day he is the one tuning and knows what works. So Im comfortable with it.
Old 01-22-2021, 01:23 AM   #25
WRX_mattb
Member#: 349275
2012 STi
I have decided to stick with the your holy header. Love killerb stuff. Already running your pick up, baffle, and pan combo on my built motor.
