Welcome to the North American Subaru Impreza Owners Club Thursday February 25, 2021
Old 01-18-2021, 02:41 PM   #1
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
Default Spun bearings survey?
Hey, I've heard lots of different reasons people spun bearings and lots of theories on how to prevent it- but I'm hoping people who've spun a bearing wouldn't mind doing a survey for me- if we get enough responses it would be pretty cool to see what common threads are there!
https://www.surveymonkey.com/r/JR2Z3DW
GeoNV is offline   Reply With Quote
Old 01-18-2021, 03:37 PM   #2
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Looks like a great idea, I would also add if it was a stock block or built, was it forged internals? Maybe also add the company who put the block together?
BlackFighter is offline   Reply With Quote
Old 01-18-2021, 04:34 PM   #3
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
I added some tick boxes at the last question to try to capture that- with a free survey I'm limited to 10 q's! people could put it in the comments i think. Thanks for the feedback.
Old 01-18-2021, 04:57 PM   #4
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
Old 01-18-2021, 10:26 PM   #5
Jay11STI
Member#: 492422
2011 STI
Good idea but nothing is concreate. I do have a couple of suggestions. You might want to add 5w-40 oil since that is very popular. Also maybe change the engine mod section. Stage 1, 2, and 3 and reduce alot of those other options. The power levels for example can go.
There are SO many reasons why an engine can fail and so many possibilities as to why and how a spun bearing occures.
Jay11STI is offline   Reply With Quote
Old 01-19-2021, 12:37 PM   #6
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
made some changes- I wanted to leave the power levels in there so if people know them they can put them in. I did add stages though, thanks for the suggestions.
Old 01-21-2021, 01:37 PM   #7
Fairchild72
Member#: 521505
2005 Forester
As I am unsure of what the stock oil pump is I believe its 11? Ultimately the cause of my issue was determined to be a failed weld at the oil pick up!
Fairchild72 is offline   Reply With Quote
Old 01-21-2021, 03:53 PM   #8
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
ouch. that sounds pretty common out there. I think they were 10mm, then 11mm for the Sti from 08 on and even 12 mm for some JDM engines.
Old 01-22-2021, 04:27 PM   #9
saaiello21
Member#: 501997
2011 WRX
gray
Spun a bearing on my 11 WRX drag racing on a very hot day and about 2700 miles in on my oil change rotella 5w40. I blame the oil and maybe some detonation.
saaiello21 is offline   Reply With Quote
Old 01-22-2021, 05:08 PM   #10
GK1707
Member#: 373868
'04 STi
This is great data collection. So far I gathered that majority of bearing failure from those who answered have occurred in those that run 5w30 and a stock oil pickup
GK1707 is online now   Reply With Quote
Old 01-22-2021, 06:49 PM   #11
Jedi03
Member#: 491095
2009 STi Blue
based on my own reading over the years i think the stock pickup is a big culprit...to date im doing 5w30 with killer b oil system...so far so good! built motor will be adding larger oil pump as my clearances seem to be on the loose side when i build
Jedi03 is offline   Reply With Quote
Old 01-23-2021, 02:54 PM   #12
Rallyquest
Member#: 521853
2008 STi
White - Gold wheels
I recently purchased a mildly modded '08 STi, pretty much mint runs great, no weird internal noises. Ordered a Moroso pickup tube after reading many cooked engine posts on lots of sites, and a very high percentage of them include a cracked or failed oil tube. For the cost it looks like a must-do. I'm not even going to drive mine any further until it arrives and installed. I'm guessing the brazing process re-tempers the metal tube, and that combined with unsupported free end of the pickup tube vibrating does the damage over time as seen by where many are cracked.
Surely not the only reason the engines fail, but looks quite common.
Rallyquest is offline   Reply With Quote
Old 01-25-2021, 08:31 PM   #13
Ryanearly
Member#: 514627
That was a pretty good survey. Is there a way to view the results?
Ryanearly is offline   Reply With Quote
Old 01-25-2021, 11:21 PM   #14
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
Comment #4 should take you to the results Thanks for taking it!
Old 02-01-2021, 09:46 PM   #15
idntvpe
Member#: 521263
Originally Posted by GeoNV View Post
Great information. Its hard to believe only 1 had an AOS. 6 had DIY tunes. I would get the best tune I can get or wait until I can afford it before buying any other mods.
Good to see they were all above 60k though. Seems cumulative damage could be a factor.
Thanks for the post.
idntvpe is offline   Reply With Quote
Old 02-02-2021, 02:24 PM   #16
GeoNV
Member#: 518830
2009 WRX
dark grey metallic
It is interesting isn't it? I wonder how that will look as more results come in.
