Welcome to the North American Subaru Impreza Owners Club Sunday March 7, 2021
Old 01-18-2021, 04:30 PM   #1
ben_7
Member#: 464522
2020 Subaru WRX STi
Default Getting some knock readings on newly modified 2020 STi, what is the best way to avoid
Hi everyone,
I just did the first line of modifications to my 2020 STI which include:
- COBB Accessport
- COBB SF Intake + Airbox
- COBB three port EBCS
- IAG Street Series AOS
- nameless midpipe to complete my nameless cat back exhaust system (I only had the nameless axleback before)
- killer b oil pickup and baffle kit
My STi is pro-tuned for 91 octane gas and the boost has been raised from 16.2 psi which I believe came stock for the 2019+ STi’s to around 19 psi and it briefly overboosts to 20.6 psi, which is what my boost gauge currently shows.
My tuning shop tells me that the mustang dyno they use show underrated numbers, so my car dynoed at 275whp and 301 wtq.
A bit of a story as to why I’m concerned about heat soak prevention...
So my tuner asks me to data log for him after driving around a couple of days and after I did this, he noticed some knock on the higher end during some pulls which he made some adjustments for, and sent me a revised map to data log against.
On this map, during pulls I noticed my feedback knock values hit -2.8 sometimes and my fine knock learn hit anywhere between -3 and -5 on certain pulls but whenever I got into boost, it was steadily around -1.4 until I got off the throttle where it would then return to zero or if I was on low boost, it would stay on zero as well.
The dynamic advance multiplier value has always been at 1 thank God.
When I told this to my tuner, he said my intake temps were through the roof, sometimes hitting 140F and he told me to stop getting into boost whenever my intake temps were above 100F.
Since I’m new at a modifying STi’s, I thought I just had to watch out for the coolant temps being at approximately 180F before getting on boost, however I will now watch my intake temps more closely.
So he told me to reset my ECU via the Accessport to get rid of the fine knock trims and start over by data logging again and hitting boost with intake temps under 100F.
The issue there is that I noticed my intake temps build up quite fast which means I should not be getting into boost, so here are my questions:
1. Should I buy a COBB turbo heat shield and/or turbo jacket?
2. Should I invest in a process west tmic? (I’m not interested in going fmic as I’m not upgrading my turbo or going for high horsepower levels. I only plan to put a downpipe, up pipe, koyo rad, and fuel system upgrade minus flex fuel hopefully by the summer of this year for my next set of power modifications)
Even though E85 burns cooler, it will increase the power, thereby making my engine work harder and risk trouble without my engine being properly built to handle above 350whp and similar wtq levels.
With the second set of mods I listed, I hope to get around 310whp and 330-340wtq on a 91 dyno tune and that’s more than enough power for me on an STi.
I do plan to take my car to the track a few times a year when possible so I’d like to do that safely which is why I wanted my tune to be set more for reliability than power.
Thanks and please let me know your suggestions.
ben_7 is offline   Reply With Quote
Old 01-26-2021, 03:45 AM   #2
kharmicresonance
Member#: 461898
2004 Forester XT MT
01G
Well, I may be confused here, But you took a 2020 STi to a tuner, with those mods, paid $$$ for them to raise the boost and lower your HP/TQ? ( the 2020s were spec'ed at 310whp but a few have been dyno'ed straight off the showroom floor at 280whp on mustang dynos ) The Stage1 OTS Cobb Map itself is supposed to be good for something like 290whp/330tq.
And then they told you to just not drive in boost when the intake is over 100F? They did not even offer to look at your airbox to determine why it was not pulling cool air in from outside?
Remember, that heatsoak is usually only present after you have sat at a stop for a few minutes. And that the stock intercooler can overcome heatsoak in less than a minute ( although it will only ever get temps down to within 10-30 degrees of ambient depending on atmospheric conditions) If your tuner is leading to you believe that you are running into heatsoak *at speed* then you should question them on how they think that is happening. Because there are thousands of other 2020 STis running around without that problem putting out more power *stock*.
Save your car, and your money, and find a better tuner.
kharmicresonance is offline   Reply With Quote
Old 01-26-2021, 06:54 AM   #3
12wrx1
Member#: 386873
What he said.....
12wrx1 is offline   Reply With Quote
Old 01-26-2021, 08:12 AM   #4
horsePOOGAS
Member#: 450712
04 STi
When you're data logging, is it in stop and go traffic or rural road/highway cruising? If you're logging in stop and go traffic and then doing WOT pulls (say entering on a highway or whatever) I could understand why your intake temps are high at the time of the pull.
Whenever I've done data logging and WOT pulls for my tuner I have a specific route I always take. Long straights, few stop signs, and plenty of room to do a WOT pull after I've been driving for a bit. All that is to make sure my intercooler and coolant temps are at the lowest possible for the pulls.
But along with what Kharmicresonance said - Your tuner should be asking you the right questions to figure out why.
horsePOOGAS is offline   Reply With Quote
Old 01-27-2021, 11:45 AM   #5
subaru_gc8
Member#: 29292
2004 WRX wagon
if your dam is staying high, don't worry about it, you are just being paranoid.
subaru_gc8 is online now   Reply With Quote
Old 01-27-2021, 11:54 AM   #6
JP Chestnut
Member#: 504432
I'd get a new tuner. "Don't get on boost when your intake temps are about 100" isn't a solution. You paid money and killed your warranty -- I'd be hoping for a little more than what you're getting.
JP Chestnut is offline   Reply With Quote
Old 01-29-2021, 08:18 AM   #7
hotdog
Member#: 197520
2020 WRX STI
Magnetite Gray Metallic
As others have said: You've done insanely little to your car, and your tuner sounds like a goober. Go find better. You've voided your warranty and he's having you do a labor of driving around and logging? **** that. Find someone better.
hotdog is offline   Reply With Quote
Old 01-29-2021, 08:56 AM   #8
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
1. Should I buy a COBB turbo heat shield and/or turbo jacket? Heat protection is never a bad idea. The best/cheapest avenue for this is https://forums.nasioc.com/forums/sho....php?t=2298336. Will this solve your issue? No. But it should help.
2. Should I invest in a process west tmic? (I'm not interested in going fmic as I'm not upgrading my turbo or going for high horsepower levels. I only plan to put a downpipe, up pipe, koyo rad, and fuel system upgrade minus flex fuel hopefully by the summer of this year for my next set of power modifications). No. No intercooler on earth will help with intake temperatures as those are read PREintercooler.
I'd also recommend you watch some Cobb videos and website documentation on what the AccessPORT reads and when/when not to be concerned. I think you are pissing yourself for no good reason. I keep my AccessPORT in the drawer below my computer. It stays in the off position save for an update twice a year for fun. It monitors the room's temperature just fine.
Your intake temp is a concern. Causes:
1. Your intake may not be installed correctly.
2. You are idling the car and/or are in heavy traffic for awhile before you do your pulls.
3. Your temp sensor is fubar.
Prior to doing a log pull you should be cruising around like a Christian and allowing your car to come up to temp nicely and you should see that your normal cruising intake temp is 10ish degrees above air temp at speed. So its 90 outside, your intake temp...at a nice 40mph...should be like 100. Each car is a bit different of course, so go with YOUR normal.
Old 01-29-2021, 12:39 PM   #9
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
That's like basically saying "don't hit boost in the summer"! Were the temps that high while just sitting there idling, or while driving around?
Old 02-28-2021, 05:57 AM   #10
ben_7
Member#: 464522
2020 Subaru WRX STi
The intake temps go up only when I’m idling at a traffic light for example.
When I’m driving around, the intake temps go down.
Old 02-28-2021, 05:59 AM   #11
ben_7
Member#: 464522
2020 Subaru WRX STi
A quick update. My tuner gave me a revised map where he did some trimming on throttle tip-in and that seemed to solve the knock issues I had earlier.
While this map is slightly less aggressive on the throttle than my previous map, the car still pulls hard and I rarely see any knock values.
I think I saw my fine knock learn gauge register a -2.8 at some point during my drive (during a pull) but it was so quick that I hardly noticed it.
The knock values remain at a constant zero with any amounts of throttle 99.9% of the time so this map seems fairly stable.
Where I do notice the less aggressive throttle is the tip-in (which is what my tuner did to reduce the knock values) so I notice that I have to push the throttle all the way down to keep it at around 19 pounds of boost.
Thanks for the replies everyone!
Old 02-28-2021, 08:41 AM   #12
K3rm1tth3fr0g
Member#: 508105
2002 WRX Wagon VF39
Midnight Black Pearl
Glad your tuner got you all figured out.
One more factor that I don't see talked about very often on NASIOC when it comes to fine knock and feedback knock is fuel quality.
If you had gas your car tuned in the winter time, or you are just running winterized fuel, that may play a factor in your ECU pulling timing. I had issues on the winter blend in my area but it cleared up as the gas got better as the weather got warmer.
Also Lucas octane booster and Torco both do good jobs artificially raising your octane to add a safety net for your fuel.
K3rm1tth3fr0g is online now   Reply With Quote
