Welcome to the North American Subaru Impreza Owners Club Monday March 1, 2021
Old 01-18-2021, 05:09 PM   #1
savagesoob
Member#: 521085
Default making hole and welding bung on ETS TMIC
I am going to a SD tune and need to have a bung welded on my TMIC.
How do they drill the hole without getting the aluminum in the IC? Would hate to leave a piece and it end up in my engine..
Has anyone done this?
savagesoob is offline   Reply With Quote
Old 01-18-2021, 05:34 PM   #2
blurred
Member#: 47143
Remove TMIC
Block fins
Drill hole
blurred is online now   Reply With Quote
Old 01-18-2021, 09:26 PM   #3
undyjr
Member#: 459692
2019 WRX STI
silica black
At one point I was going to install water meth injection on my STI but decided to go flex fuel instead. I had already purchased a Snow Performance injection plate that sandwiches between the throttle body and manifold. It has two 1/8" NPT ports, maybe your IAT sensor would fit if you purchased the plate?
undyjr is offline   Reply With Quote
Old 01-18-2021, 09:57 PM   #4
savagesoob
Member#: 521085
Damn looking at the part and think this would work. Thanks!
Old 01-18-2021, 10:31 PM   #5
undyjr
Member#: 459692
2019 WRX STI
silica black
You'll need this IAT sensor:
https://www.maperformance.com/products/aem-1-8-npt-air-temp-sensor-kit-30-2014?variant=29435987755078&gclid=CjwKCAiAgJWABhAr EiwAmNVTB9FlXRoXWRcrfdRSP4bC7cD1HtpPL07Rsp_6TTrBBj Hvp0jSJoQo9BoCCWYQAvD_BwE
Old 01-18-2021, 11:14 PM   #6
savagesoob
Member#: 521085
Can I get a different IAT as long as it's 1/8 npt. I guess I will have to get this on. I ordered a SD kit from Visconti https://www.viscontituning.com/colle...=1136942940168
But the IAT is 3/8 NPT. Can I just cut the male connector on the SD kit and put the AEM connector on and plug in?
Old 01-19-2021, 09:36 AM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I would want to do some comparative feedback first. Your charge air temps are going to be different from I/C end tank-to-intake runner. Whether that's 10° and inconsequential, or 50° is anybody's guess. Tuners know what works with end tank temps, but I don't believe anyone has gone in this direction. Without proper testing, you're taking on that risk.
KillerBMotorsport is offline   Reply With Quote
Old 01-19-2021, 11:28 AM   #8
savagesoob
Member#: 521085
So no one has ran IAT in the end tanks before for a speed density tune? i thought it was common if not running a FMIC.
My mechanic with 15 yrs exp. working in Subarus told he would weld it on the IC.
I thought the spacer would be a better place since its right on the throttle body. However, with the spacer it will be near impossible to get the coupler on bc the extra 3/4" protrusion. Plus need an extension for the MAP sensor.
Old 01-19-2021, 04:35 PM   #9
lowbee
Member#: 254317
2011 STi
Yep, I have mine IAT bung on the TMIC too but I am not using it at the moment
lowbee is offline   Reply With Quote
Old 01-19-2021, 06:41 PM   #10
savagesoob
Member#: 521085
No problems with reading temp and running well on Speed Density tune?
Old 01-19-2021, 08:14 PM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
My bad. For some reason I was thinking TGVs with secondary injector ports. Sorry!
