Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Old 01-18-2021, 11:15 PM   #1
bitsmit
Member#: 473523
2004 wrx sti
wrb
Default Fuel line upgrade questions
Hi Guys,
I'm stuck in a limbo and need you need some expert advice/direction. To preface, i have a iag stage 2 tuff block that is currently on running on a stock turbo. I decided to pull the trigger and upgrade the turbo plus supporting mods to make more power.I'm stuck in the fueling department.
Here's the issue, so i bought radium tgv deletes and top feed fuel rails
Here's a link for reference
Tgv housing http://www.radiumauto.com/TGV-Housin...-EJ-P1708.aspx
Top feed rails http://www.radiumauto.com/Fuel-Rails...u-EJ-P631.aspx
But I didn't buy the fuel rail plumbing kit because i dont really need the direct mount regulator and fuel pressure gauge.
Plumbing kit http://www.radiumauto.com/Subaru-EJ-...its-P1767.aspx
So where can i just get the plumbing kit without it? Is there another brand that offers this that would work with my setup?
I did see IAG but they also sell it as a kit. Any help would be appreciated.
bitsmit is offline   Reply With Quote
Old 01-19-2021, 09:29 AM   #2
motorbykemike
Member#: 273868
What turbo and injectors are you planning on running ?
What fuel?
What regulator do you plan on running ?
How will you set the pressure ?
motorbykemike is offline   Reply With Quote
Old 01-19-2021, 03:13 PM   #3
bitsmit
Member#: 473523
2004 wrx sti
wrb
What fuel?
I have a dom 1.5xtr 8cm turbo and fic 1200cc injectors
pump gas(93). Thought about flex fuel but I don't have any E85 gas stations near me unfortunately
I thought the stock setup would suffice in this case
I'm not sure yet
Old 01-20-2021, 07:40 PM   #4
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Originally Posted by bitsmit View Post
Hi Guys,
Make a fittings list baised on the parts you have and the threads they have available. Look at the "kits" if you need a reference most give a parts list (I always just draw it out on paper and get a quick parts list).
Get on summit racing and order them up in the quality/style you like with a chunk of hose that matches the style fittings and have at it.
Or just buy the kit.
I ordered a pile of fittings and because of the style I went with saved a LOT of money.
Scuby04STi is offline   Reply With Quote
