Welcome to the North American Subaru Impreza Owners Club Tuesday March 2, 2021
Old 04-18-2020, 11:09 PM   #1576
kscoob
Member#: 513600
Post p2096, p0137 on Stock 2008 Impreza Sedan
2008 Subaru Impreza 2.5i Sedan stock, 113k miles
Codes: p2096, p0137
My exhaust was leaking at multiple points. After I got this fixed, the codes came back after a few days. When cleared, the CEL will illuminate after a few mins driving on the highway.
I believe that the Upstream AF sensor has a rich bias. About 5 minutes after the car warms up, it produces a consistent negative current (-0.05-0 mA). Its voltage is 2.1-2.2 V. In that time the LTFT drops from 0 to -4%.
The downstream O2 sensor provides reasonable values at first, in the 1.2-0.4 V range. However this gradually drops to 0.01-0.02 V.
The MAF sensor appears to be responsive, increasing with engine RPM.
2 g/s at idle, 10 g/s at 3000RPM.
I dont hear any vac leak whistles while the engine is being revved with the hood up.
Any ideas?
kscoob is offline   Reply With Quote
Old 06-17-2020, 12:16 PM   #1577
GoranNoSuponsaa
Member#: 515535
2007 Impreza Wagon
2007 Impreza 2.5i Wagon, stock, 136k miles
Code: P0171 System Too Lean (Bank 1)
Taking a look at this in a bit. Either dirty MAF or serious vacuum leak. Built a DIY smoke tester out of a soldering iron and a pickle jar. Will update when I clear the code.
GoranNoSuponsaa is offline   Reply With Quote
Old 06-18-2020, 04:17 AM   #1578
Jerpster
Member#: 515697
08 WRX
Here's one for you. I'm posting in this not because of a code. But the lack there of.
I'm the third owner of my 08 wrx. It has 155k miles. I bought it at 100k. Timing belt was done by PO at 90K. Paperwork to prove it was done. It was after my idler pulley exploded that I realized only belt and tensioner pulley were replaced. So I'm here about the lack of P0340 0345 codes. I have the timing belt cover off and found the issue.
Might I be the luckiest man in the world and just need to replace broken cog pulley check timing and replace timing belt water pump and compression test?
Thoughts?
Jerpster is offline   Reply With Quote
Old 07-08-2020, 11:37 AM   #1579
aswresm
Member#: 482455
Default 2012 Subaru Impreza with CEL p02419
Any idea what to look for when trying to fix that CEL. T
Thanks in advance.
aswresm is offline   Reply With Quote
The Subaru 360 Thread SIL01 Member's Car Gallery 29 09-19-2006 10:21 PM
Subaru impreza CEL thread dominiond Service & Maintenance 3 04-25-2004 02:00 AM
The Subaru Upscale Thread SUBE555 News & Rumors 46 10-18-2003 10:16 AM
