Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Old 05-15-2017, 02:45 PM   #6926
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
Originally Posted by DesertWRX11 View Post
Thanks zefy!!! Don't know what I am doing wrong, I've posted photos on here before but can't seem to get it to work when following the instructions from various threads!
the image link always has to end in .jpg. In photobucket, there is a quick link tool you can copy on the side labelled IMG. Just copy and paste that into nasioc and it will display the pic.
Zefy is offline   Reply With Quote
Old 05-22-2017, 04:29 AM   #6927
ab0815
Member#: 464530
2017 Impreza
Ice Silver
Originally Posted by imsoprfct View Post
Dual 6 inch driving lights for me, didn't want to drill the interior to mount the switch, instead used the JDM push button start trim piece to mount the switch.
Any pictures of the switch install? I like the look of these and would be interested in seeing how you did it
ab0815 is offline   Reply With Quote
Old 05-22-2017, 02:49 PM   #6928
imsoprfct
Member#: 213347
I didn't want to drill into the dash, so used the JDM push button start panel piece to install the switch where the push button would go. It allowed for a cleaner installation, and kept the dash intact. I elected to use the simple toggle switch instead of the lighted one that came with the kit, at night the original switch was too bright and became annoying after a couple of minutes.
imsoprfct is offline   Reply With Quote
Old 05-28-2017, 02:56 AM   #6929
ab0815
Member#: 464530
2017 Impreza
Ice Silver
very clean and good looking install
Old 06-06-2017, 03:53 PM   #6930
WrxJake2002
Member#: 410227
2002 Wrx
http://i.imgur.com/OpFDGby.jpg
Rally innovation bar for a Hawkeye that i made fit for my bugeye. Hella 500 black magics are wired to my high beams, and I'm still waiting for my HID kit for my Hella 2000's. I'm selling the black magics if anyone wants them
WrxJake2002 is offline   Reply With Quote
Old 06-12-2017, 01:43 AM   #6931
iRishman514
Member#: 378501
2011 STI Hatch
Plasma Blue Pearl
Default The Ultimate Auxiliary Lighting and Mount Thread
iRishman514 is offline   Reply With Quote
Old 06-12-2017, 10:14 AM   #6932
JordanOfGilead
Member#: 446722
2016 Impreza 2.0i
Dark Gray Metallic
Originally Posted by iRishman514 View Post
That's slick. I'm a big fan of not being able to tell without looking really close during the day.
JordanOfGilead is offline   Reply With Quote
Old 07-20-2017, 08:18 PM   #6933
OldManWinter27
Member#: 471408
2008 Impreza 2.5i
Dark Gray Metallic
Blacked out my LED work lights and light bar.
6 LED work lights behind grille. Two of the work lights are tinted yellow for fog and will be wired to my round fogs. Four of the work lights wired to a button and spliced to that button is a trailer connector for me to plug in my light bar when needed for deer burning brightness.
Had to make custom bar brackets and mounts for behind the grille.
Bluetooth RGB Demon eyes also connected to grille glow. Adding halos soon!
Happy to provide installation tips if anyone needs! Blacked out light bars in last photo are going on my GF's Xterra soon.
http://i.imgur.com/hlS1DyX.jpg
http://i.imgur.com/LnVCCbN.jpg
http://i.imgur.com/KlLMzk1.jpg
http://i.imgur.com/dZGUrTi.jpg
OldManWinter27 is offline   Reply With Quote
Old 11-12-2017, 01:10 PM   #6934
JBONEinWRX
Member#: 223332
Originally Posted by WaveBye View Post
Here is the result of my recent fun, putting Hella Black Magic 500's on my 08 WRX.
The photos don't look like an '08, looks like the wide-body GR.
Should this approximate design work on an '09 wrx?
JBONEinWRX is offline   Reply With Quote
Old 12-06-2017, 08:39 PM   #6935
Paranoid Fabrications
Member#: 140712
2008 WRX STI
some of our late model brackets and Baja Designs lights.
fits
11+ Wrx/STI
13+ XV Crosstrek (18 might need slight sanding of inside of bezel to fit)
12-16 Impreza sport
https://www.paranoidfabrications.com...gn-fog-bracket
and a custom bar we setup for somebody.
Paranoid Fabrications is offline   Reply With Quote
Old 03-28-2018, 11:22 AM   #6936
DesertWRX11
Member#: 341522
2011 WRX
Spark Silver
[/IMG]http://s138.photobucket.com/user/isnowboard4life/media/FullSizeR.jpg.html]
DesertWRX11 is offline   Reply With Quote
Old 08-03-2018, 02:58 AM   #6937
andrew_l_s
Member#: 446616
2018 WRX Limited
Lapis Blue Pearl
Installed PIAA 530 LED driving lights behind my grille with the Perrin horn bracket. You will need screws and nuts to mount the lights as the ones included are too large for the holes on the Perrin bracket. For cars with traditional halogen high beams you could simply tap into either high beam connector and use an inline fuse. My car has the bi-LED setup so I powered the PIAAs off of the high beam fuse in the engine bay fusebox. An add-a-fuse and 2 amp blade fuse is all you'll need. Yes, you read that right 2 amps. These don't even draw 1 amp of current yet are bright enough to be a high beam on their own.
I didn't fail on a bunch of image links, apparently there's a 10 pic limit so I cut out the less important ones. Link to the full album: https://imgur.com/a/jkK1wg8
First, remove the bumper (plenty of how-to's on this)
https://imgur.com/wiBmbBp.jpg
Remove horn and radiator support bolts
https://imgur.com/9zS8GAh.jpg
Relocate the horn, I chose this spot at the bottom of the radiator support
https://imgur.com/h7jmnIr.jpg
Attach the Perrin horn bracket per their instructions
https://imgur.com/f4lZKmA.jpg
Mount the light brackets, make sure they're level
https://imgur.com/HUrr4CZ.jpg
Attach the lights to their brackets
https://imgur.com/8Ltnbcp.jpg
At this point get the lights aimed how you like
https://imgur.com/IMV3wJZ.jpg
Plenty of clearance for the grille and bumper
https://imgur.com/HnGuYXA.jpg
Run the wires along the hood release cable (that weird silver thing in the top right is my work light haha)
https://imgur.com/FZGVTS7.jpg
Tidy up any excess behind the driver's side headlight
https://imgur.com/CDb1lmD.jpg
Ground using the fender bolt, run positive into the fusebox
https://imgur.com/RsooZeD.jpg
Use an add-a-fuse to power the lights off the high beam circuit
https://imgur.com/94Vn6FX.jpg
Done! While off they're barely noticeable
https://imgur.com/qqrL3Uo.jpg
Very bright for the size and minimal current draw
https://imgur.com/rS7dBFe.jpg
I don't have any on the road shots, but these are roughly equivalent to the factory high beam in brightness. Color temperature is a very close match as well. When aimed properly they effectively double the amount of light on the road with high beams on.
andrew_l_s is offline   Reply With Quote
Old 08-04-2018, 11:20 AM   #6938
star fox
Member#: 478419
I'm thinking about trying to squeeze in a light bar above my fmic on my 2016 sti.
Surprisingly I haven't found any threads on this, so I'm wondering if anyone here has any input. I figure you get up to a 4" fmic, so if there isnt any hella horns there should be plenty of room as you could push the bar all the way back almost touching the contact point in front of the radiator.
I know diode dyanimics has their light setup that fits, but I can't find any dimensions on it. I want to put a 20" rigid bar in there and would make a custom mounting bracket to push it as far back as possible. I would go with their midnight series, but the beam is pretty narrow. I'm considering the adapt series for the adjustable lights, but I think it's almost 5" thick and not sure it'll fit.
Anyone have some input here?
Do y'all think it will be obvious the bar is in there? I currently have hella horns painted black that you can't see at all (and will be moving them for the bar...
star fox is offline   Reply With Quote
Old 09-28-2018, 04:49 PM   #6939
OctaneZ
Member#: 42966
Swapped the Stock fogs on a 2016 Forester XT for the Baja Squadron Pro Combos:
Passenger is Stock, Driver side is Baja:
OctaneZ is offline   Reply With Quote
Old 09-28-2018, 04:51 PM   #6940
OctaneZ
Member#: 42966
A Comparison:
Low Beams:
High Beams:
Baja Sqadron Combos + lows:
It's about 15m/40ft to the 05 FXT, and the white house behind it is another 10m/35 feet behind the XFT and the Baja's cast quite the shadow.
Old 10-06-2018, 06:16 PM   #6941
Hagwag02
Member#: 63445
2002 WRX Wagon
Cool
Originally Posted by Hagwag02 View Post
Got mine from Rallylights (Susquehanna Motorsports). Price looks better and I didn't see shields on the other site. They're a slimline rectangular light with rounded ends. The reflector has five roughly equally-sized facets. Mine aren't HID, just the 55W H7 bulbs. Wires are exactly the same as on the 500s and FF1000s.
What did you get mixed up?
For the size, shape, and price these things throw out a surprisingly great amount of light! And the pattern stays focused to a good distance, too!
These FF75s were MEANT for my wagon. Thanks for the suggestion all those months ago.
Well, after a few years some of the lights have gone kaput, some things were removed, etc... I took the opportunity while I was having some mechanical repairs done (oil cooler gasket, valve cover gaskets, clutch) to rewire, reinstall, and replace the lights I mounted over a decade ago. Hard to believe. Touched up the stripes, wash and wax, cleaned the interior. I love the old girl to death. lol.
Hagwag02 is offline   Reply With Quote
Old 09-28-2019, 11:09 PM   #6942
Murray1719
Member#: 506870
Question 08 impreza wagon reccomendations
Just got a gold 08 impreza wagon, black wheel, black rally armor mud flaps, and the stock Subaru cross bars.(having trouble uploading pictures). Any recommendations as to a get a rally bar/light bar set up??
Murray1719 is offline   Reply With Quote
Old 01-06-2021, 03:20 AM   #6943
VeteranNoob
Member#: 512818
Has anyone wired their auxiliary lights to sync with their low or high beams?
I'm a complete noob with electrical stuff. A couple people have given me some options; one was using a relay which I now fully understand, and the other was using an add-a-fuse tapping into the low or high beam fuse. The latter should be cheaper and easier, so I'm trying to figure out if it's worth pursuing; some people have raised concerns that it may either leach power from the headlights and cause problems, or it might even just power the auxiliary lighting constantly instead of only powering when the specific beam is active (because the fuse exists before the switch or something?).
Can anyone weigh in on this?
VeteranNoob is offline   Reply With Quote
Old 01-06-2021, 02:27 PM   #6944
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
I definitely would go with the first option.
satrya is offline   Reply With Quote
Old 01-14-2021, 11:17 PM   #6945
SubieGreg757
Member#: 521531
Default Lighting Upgrades, 2018
Realize this is not really "auxiliary lighting", but the result was well worth the investment. Primary goal was light output while maintaining stock locations and improving overall looks. SubiSpeed v2 Redline Headlights, SubiSpeed Facelift JDM Style DRL Foglight Bezels, and Baja Designs SAE Squadron Fogs.
SubieGreg757 is offline   Reply With Quote
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 614 02-28-2020 06:54 AM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 04:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 01:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 04:37 PM
