#51 |
Member#: 59427
Vehicle:2005 Legacy GT ltd Black as night |
![]() So I've read the instructions and looked at the pics. Looks like there is going to be a total of 3 connections running from the neg battery, however in the last pic it shows the blue wire running past the last point of connection. Is that going somewhere not mentioned? Just want to make sure I am understanding correctly. Thanks
#52 |
Member#: 3803
Vehicle:07 Mustang GT Ford Crappy Paint White |
![]() This really should be the grounding Fix, as this just cleans up grounds on questionable cars.
As for whether it actually does anything, I can't find the old article about the legacy B4 grounding issues. Subaru (and other OEMS) ground 'just good enough', and when the B4 came out (don't know which generation) several people had grounding problems. The end result is that Subaru enlarged the grounds to fix performance issues. If people are getting more power from this, it is generally because they weren't making the power they were supposed to originally. Rather, the torque curve had dips from poor grounding that the fix corrected. Seems kinda common on Subaru's. I really need to re-do mine, as I half-assed it when I did this 3 years ago. Tom |
#53 |
Member#: 74811
Vehicle:'99 Impreza 2.5RS Silver |
![]() just to make sure i fully understand this process.
all you have to do is run a cable from the battery and split it into three cables and connect them as follows: one to the altanator then to the left head and then to the right head...? is that seriously all there it to it or am i missing something?... cuz that sounds so simple that i think i could even do it ![]() also woundering if it really matters what bolt you attatch it to... as long as it is on the head its ok right? |
#54 | |
Member#: 23676
NESIC
Vehicle:. |
![]() Quote:
#55 | |
Member#: 23676
NESIC
Vehicle:. |
![]() Quote:
![]() The chassis is grounded 6 inches from the battery. |
#56 | |
Member#: 59427
![]() Quote:
#57 | |
Member#: 50578
Vehicle:2014 Fiesta ST -=meh=- |
![]() Quote:
I know it doesn't NEED to be grounded to the body over there, but now I have an extra legnth of wire & a ring at the end of it with no home. ![]() |
#58 | |
Member#: 60671
Vehicle:1972 Datsun 240z LS3 w/ Jenvey ITB |
![]() Quote:
maybe the transmission for ****s and giggles. to the reverse light switch works more efficiently? the exhaust? so the o2 sensor works better? or maybe the abs block |
#59 |
Member#: 57898
![]() just finished mine...took about a half hour drunk.
#60 |
Member#: 49895
NESIC
Vehicle: 09 Forester 06 Legacy 2.5i Wagon |
![]() I added the alternator and both head grounds a few days ago per Davenow's instructions. It seems to work great. The car really runs smoother now - well worth the minimal time and expense. Thanks Davenow!
#61 |
Member#: 61731
South East
Vehicle:1999 RSTi |
![]() nice write up. thanks for the info and keep us updated of any more points of grounding.
#62 | |
Member#: 23676
NESIC
Vehicle:. |
![]() Quote:
Have you grounded the tbody yet? I would go for it way before the sturt tower. |
#63 | |
Member#: 23676
NESIC
Vehicle:. |
![]() Quote:
![]() /runs off to drink beers ![]() |
#64 |
Member#: 69032
Vehicle:2005 Legacy GT Obsidian Black |
![]() Dave, Id buy a kit for 30 bucks shipped with a decent set of instructions..Just to let you know.
#65 | |
Member#: 57898
![]() Quote:
#66 |
Member#: 993
![]() I am still stunned that any of you would think that this would not make a difference. OEM's have been doing just good enough on cars for YEARS. GM had a TSB on doing just this for a long time if a customer reported rough idle and no other problems were found....and this was in the 89 and on Quad4 engines.
The grounding mod used to be my first order of business when I was still installing car stereo's for a living. Without it you could count of the headlights flashing and maybe the car stalling....after it usually no problems. |
#67 | |
Member#: 23676
NESIC
Vehicle:. |
![]() Quote:
#68 |
Member#: 9090
Vehicle:09 Forester Gump 02WRX->04STi->09Gump |
![]() will this fit on an STi?
~v6 |
#69 | |
Member#: 59993
International
Vehicle:Ass, grass or cash no one rides for free!! |
![]() Quote:
#70 | |
Member#: 51240
Vehicle:08 Lexus IS350 Black |
![]() Quote:
#71 |
Member#: 74359
Vehicle:2005 2.5 rs |
![]() just thought i would chirp in here with my grounding mod experience.
initially, i learned the mod from scoobymods.com. the first attempt i ran 2 separate 10 gauge wires from the (-) terminal to each strut tower. i got no results by doing this. after a month of assuming subaru took care of the grouding problem from earlier models on my MY05 rs, i began to read this thread and decided to try to run 2 more grounding wires to the engine head. by running 2 separate 10 gauge wires to each side of the engine head, i got results. from what i can tell after just having done this over my lunch break (in less than 30 mins), this mode enhanced the car's performance. my ECU did not reset b/c i still have all my radio presets. so that is not the cause of my delight. the car is a step quicker out of the gates now. the first thing i noticed was that when slightly revving the engine in neutral, the tactometer would drop down lower than its usual idling rpm. it actually almost stalled while i let it idle for a few minutes. while driving around for 20 minutes, i became a true believer. no more half second hesitation when flooring it. the engine just seemed to react much sooner. i have 2 more ring terminals and a short length of wire left to run to the alternator to finish the job. i checked the stock grounding point, and it is fine b/c it has a bare contact point and plent of grease on it. thanx to dave and to nasioc for helping my car run better. this mod is very worthwhile when done correctly. even for a MY05. |
#72 |
Member#: 25478
SCIC
Vehicle:2003 WRX Sport Wagon PSM |
![]() NWwagon - Clean wiring job....I like the grommets!!
#73 |
Member#: 60671
![]() OK, WHERE on the heads do you ground?
the valve cover things, or up by the spark plugs, there are threaded holes.... what is that exactly? i wish i had a pic, but i cannot explain in any other way... |
#74 | |
Member#: 23676
NESIC
Vehicle:. |
![]() Quote:
If there are threaded holes on the head itself, even better. |
#75 |
Member#: 59427
![]() Just a quick update.
I did this to my car last weekend but didn't get to test it out until this morning. It worked like a charm. There was no more surge at 5k rpm. Just a nice smooth pull all the way through. Thanks again Davenow for the help! |
DIY: Intercooler Screen Mod - The right way! | efaroh | Interior & Exterior Modification | 61 | 09-05-2018 03:32 PM |
Fog Lights on with Highs Mod for 2000 RS, the right way | IowaRS | Electrical & Lighting | 12 | 12-03-2010 02:23 AM |
Head light mods, the right way. | Iggy76 | Electrical & Lighting | 12 | 01-11-2006 08:16 PM |
just got the car, modding the right way? | sheizen | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 06-16-2005 01:05 AM |
The right way to do fuel lines w-pics!!! | O4STInger | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 20 | 03-11-2005 12:39 PM |
