Welcome to the North American Subaru Impreza Owners Club Sunday October 21, 2018
Old 03-03-2005, 08:41 PM   #1
impreza_wrx_2003
Member#: 55468
04 STI
Default what kind of hp numbers on my sti setup
What kind of numbers do you think I will get out of my setup? It will be dynoed on a dynodynamics dyno if that helps anyone out.
2004 STI
UTEC
APS S/R 55 turbo
perrin modded injectors
walbro pump
perrin fmic
perrin big maf intake
Turboxs tbe
GT spec genII header and up-pipe
Perrin inlet tube
it will be tuned on 91 for one tune and a race tune on 105.
thanks
Tristan
impreza_wrx_2003 is offline   Reply With Quote
Old 03-03-2005, 08:55 PM   #2
adamrmr
Member#: 4338
STi T3/To4e 433WTQ
tuned by Clark
380 +whp on the 105 and say 340+whp on the safe pump gas map,
Not to many people have/made good #;s with the sr turbos
adamrmr is offline   Reply With Quote
Old 03-03-2005, 08:56 PM   #3
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
What is the point in guessing? Depends on the tune, the weather, the gas. Check DynoComp's site, they have many graphs.
-Mike
MJU1983 is offline   Reply With Quote
Old 03-03-2005, 09:23 PM   #4
Mattr762
Member#: 31624
02 WRX White
uppipe, turbo-back, MBC
I vote 330whp.
Mattr762 is offline   Reply With Quote
Old 03-03-2005, 09:26 PM   #5
subaru mike
Member#: 30749
2002 wrx
^^^ what he said^^^
subaru mike is offline   Reply With Quote
Old 03-03-2005, 11:26 PM   #6
04STiLover
Member#: 58221
2004 STi
Silver/18x8 BBS RE's
330whp on a dynodynamics dyno sounds reasonable with a good tune. Good luck and share the results when you get it tuned!
04STiLover is offline   Reply With Quote
Old 03-04-2005, 09:12 AM   #7
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Post back here when it is Proven.
And my guess is 320 and 380.
wcbjr is offline   Reply With Quote
Old 03-04-2005, 01:00 PM   #8
wgknestrick
Member#: 32576
04 STI
http://forums.nasioc.com/forums/showthread.php?t=690507
Since I have almost every mod you do and a very similar turbo, you wouldn't be far off from this.
wgknestrick is offline   Reply With Quote
Old 03-04-2005, 09:33 PM   #9
impreza_wrx_2003
Member#: 55468
04 STI
Thanks everyone Im heading down to St. Louis on the 8th to get it tuned by Axis Power Racing hopefully I can get some good numbers.
Tristan
Old 03-04-2005, 11:04 PM   #10
Jayhawker
Member#: 56964
2004 STi
With my SR55 I am at 341.4 at 18 lbs of boost on crappy AZ 91 octane. I have ECUTek instead of the UTEC. This was done at DynoComp here in Phoenix on a dyno dynamics dyno. Very safe and conservative tune. No knock what so ever and I am very happy. That's all that really matters.
Jayhawker is offline   Reply With Quote
Old 03-04-2005, 11:49 PM   #11
impreza_wrx_2003
Member#: 55468
04 STI
Jayhawker what kind of times are you running in the quarter? Are you pleased with the 55? How does it pull at 18lbs? thanks
Tristan
Old 03-05-2005, 12:20 AM   #12
ESEMES
Member#: 67128
2001 996TT
seal
Booked.
ESEMES is offline   Reply With Quote
Old 03-05-2005, 12:55 AM   #13
MARKGSTI
Member#: 70197
335-340 pump......390-395 race with a strong race tune
Good luck
MARKGSTI is offline   Reply With Quote
Old 03-05-2005, 12:55 AM   #14
MARKGSTI
Member#: 70197
Nice setup BTW
Old 03-05-2005, 08:15 AM   #15
sexbomb69
Member#: 71003
04 JDM 2.0 sti wrb
12.7 @107 vf35
a pal of mine went 394 crank hp on s/r 40 @ 1.6 bar (23/24 psi) with same if not a tad better spool than his standard turbo. built ver 7 block ver 6 chassis on 97 oct gas. got misfire but will be rectified as they tune a bit more. other mods inc. uprated pump fmic knn filter 3.5" tbe
i want a bit more so i might go s/r55. tuners where im from get better results with this turbo rather than 20g. s/r 55 similar to s/z / green
sexbomb69 is offline   Reply With Quote
Old 03-05-2005, 09:28 AM   #16
Jayhawker
Member#: 56964
2004 STi
Tristan
Tristan, I haven't taken the new set up to the track yet. To be totally honest with you, I have only been down the 1/4 once and I totally suck at it. Eveyone including my tuner says to "feather the clutch" and I don't understand how to do it. I am still on a stock clutch but it seems to be holding up ok.
Old 03-05-2005, 11:40 AM   #17
impreza_wrx_2003
Member#: 55468
04 STI
thanks again for the replies
Old 03-05-2005, 01:28 PM   #18
MARKGSTI
Member#: 70197
I can't say its easy, but i can explain how to do it simply....here goes:
Rev the motor to 5000-5500rpm, (note some car need alittle more revs depending on the setup)...
EASE up off the clutch pedal until u feel it engage with ur left foot..(the car will start slighty moving @ this point)...then quickly let off the clutch pedal...
Droppin the clutch will break parts, and will sometimes either do 4 wheel peel out or make the car go sideways.....I have had both happen to me.
Old 03-05-2005, 02:30 PM   #19
impreza_wrx_2003
Member#: 55468
04 STI
When I leave the line the best 60ft times I get are usually when I spin the tires I usually launch it around 5500 as well I never drop the clutch I feather it and get wheel spin off the line, At the local track all last year I got too much traction and the engine bogged down when I left the line so my 60ft times were around 1.9 because I couldnt get any wheel spin off the line. Just take it out to a empty street and practice launching, all it needs is some practice.
Tristan
Old 03-05-2005, 05:02 PM   #20
MJU1983
Member#: 14364
Tristan
Dont expect high numbers, it's not called the heatbreaker for nothing.
It's for tuning, no being a dyno queen. That would require a dynojet!
-Mike
Old 03-05-2005, 05:08 PM   #21
impreza_wrx_2003
Member#: 55468
04 STI
Yeah thats the main reason im heading down there is to get it tuned I could really care less on how much power its making, It knocks now at full throttle on 91 and I dont even have my turbo installed yet so once I install that I will have to drop the boost way down until I get it tuned. If I get 330 I would be happy
Tristan
what kind of HP should I expect? Newbaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-13-2003 12:19 PM
What kind of HP and torque can I expect from this setup? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-01-2002 03:40 PM
What kind of HP with [email protected] PSI on STOCK motor Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-08-2002 11:19 AM
What kind of HP are people making with VF34's? IrvGotti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-02-2002 11:11 PM
What kind of HP/times to expect with these mods? KillerRex Proven Power Bragging 5 07-05-2002 02:20 AM
