Welcome to the North American Subaru Impreza Owners Club Monday January 18, 2021
Old 05-20-2009, 10:26 PM   #1
joec wrx
Member#: 112359
14 Challenger RT
Default How to drain out A/C Freon?
How do I drain out the freon? I filled up my a/c with a can of R-134 from Kragen and I think I may have put too much. The kit I bought did not come with a pressure gauge, so I had to wing it. It squeals really loud when the a/c is on.
Thanks in advance!
joec wrx is offline   Reply With Quote
Old 05-20-2009, 10:30 PM   #2
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
You really can't do this yourself safely. The refrigerant is under pressure and if it contacts your skin or gets in your eyes, it can cause instant frostbite or blindness.
A shop will have the proper equipment to safely discharge the system, recharge it to the right amount, and check it for leaks.
AC work is not something you can "wing" or DIY unless you have the proper qualifications and tools.
Old 05-20-2009, 11:39 PM   #3
joec wrx
Member#: 112359
14 Challenger RT
I was hoping to save myself money by doing it myself. The loud squeal is leading me to believe:
1. Overfilled the freon
2. AC Belt loose
3. AC compressor bad
#2 is ruled out as I tightened the belt and the sound is still there. I guess there is no way around this.. my wallet is gonna hate me for it but it's off to the shop.
Old 05-21-2009, 12:46 PM   #4
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
I still can't figure out why a shop/tech has to be a/c certified to buy refrigerant, but a individual does not. our government at work I guess.
crampfan is offline   Reply With Quote
Old 05-21-2009, 01:19 PM   #5
rick-l
Member#: 33868
2003 wrx
srp
You don't have to be certified to buy R-134 just EPA 609 certified for R-12.
You can be certifed for the Exam cost of $19.95. You can pass the test if you remember you are not supposed to vent refrigerant to the atmosphere.
rick-l is offline   Reply With Quote
Need advice on how to drain my hog imprezton Off-Topic 53 09-12-2018 03:25 AM
when doing oil change how long do you leave the oil to drain out? malibuda Service & Maintenance 38 11-07-2005 01:35 PM
How to drain engine coolant properly DTECH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-30-2003 07:13 AM
How to drain '02-'03 radiator armand1 Service & Maintenance 9 02-28-2003 10:23 PM
Battery drained, how to find out what's wrong? Dealer Xing Tri-State Area Forum 3 12-23-2002 11:38 PM
