Welcome to the North American Subaru Impreza Owners Club Thursday May 24, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 08-17-2005, 02:23 PM   #1
ImportBoost
Vendor
Vendor Sales Rating: (19)
Member#: 80912
Default Momentum EJ5-40T Turbo INSTOCK[FAQ THREAD] + TURBOXS CRAZY DEALS ETC
INSTOCK READY TO SHIP! FAQ AT BOTTOM!
PM FOR PRICE SHIPPED
USE THIS TREAD AS AN " Questions and Answers " THREAD
http://www.importboostwholesale.com/...roducts_id=889
EJ5-40T
The Momentum EJ5-40T turbocharger is the ďbaseĒ model turbo for the ej20/ej25 powered cars manufactured by Subaru. The smallest turbo we currently carry for the WRX/STi cars, it flows 580CFM and is capable of supporting over 400 crank horsepower. It has our most efficient turbine wheel, paired with our smallest compressor wheel. This combination produces the quickest turbo spool up time, and delivers more than enough power for the EJ-20 and EJ-25 engine.
Unlike competitors turbochargers, the EJ Line of turbos are journal bearing units. This keeps costs down and adds a factor of reliability that most ball bearing turbos simply cannot match. Momentum is confident in the design, performance, and reliability of the journal bearing system, and includes a 1 year 12,000 mile (20,000 KM) warranty for every journal bearing turbo we sell. Ball bearing units donít offer a warranty like this because they simply are not as durable as journal bearing systems, and most ball bearing turbo cartridge failures are not easily corrected. A majority of ball bearing unit failures require total replacement of the turbo cartridge.
The EJ5-40T turbocharger is a direct replacement turbocharger for the WRX and WRX Sti. For European appliactions, this means the 1997-on series of cars. Any Subaru car that can take the VF series of turbochargers can adapt the ej5-t series. For these cars, no cutting, welding, custom manifolds, or engineering required to install this turbocharger. Take off the old turbocharger, put the EJ5-40T in itís place, install the oil and water lines, and thatís it. The turbocharger unit is internally wastegated, and comes with the adjustable wastegate actuator.
Of course, with any larger turbocharger, modifications to the factory fuel system are required. These modifications include larger fuel injectors, a higher volume fuel pump, and some sort of fuel control computer. Momentum Turbos does not and can not recommend any brand over another with this turbocharger.
FAQ
* Direct bolt up to EJ20 engine (wrx)
* Comes with water lines, oil return lines, and gasket
* Has 12 month 12,000 mile warranty
* Supports as much HP as vf22 turbo, spools up like vf24 turbo
* Journal bearing, NOT ball bearing turbo
* Turbo flows 580cfm supports 400 crank HP
* The VF22 has a 40mm inducer on the compressor side, the EJ540 has a 48 mm inducer this means the EJ540 can and does flow more air than the vf22
and if you want to be a subaru turbo nerd, here's the link
http://scoobytuner.com/tuning/?tSfID...=4&tuningID=43
TURBOXS DEALS!!
TURBO XS FMIC FRONT MOUNT INTERCOOLER WRX| STi
REG:$1070 w\FREE SHIPPING
YOUR COST $= PM OR EMAIL [WE WILL BEAT ANY LEGITIMATE DEALS]
TurboXS WRX Top Mount Intercooler w\FREE SHIPPING
REG:$747.00
TURBOXS WRX OR STi UTEC
REG:$945.00
REMOTE MAPS SWITCHES ALWAYS INSTOCK ::ASK 4 COMBO
TURBOXS TURBO BACK RFL OR REG | RACE OR CATTED
BOOST CONTROLLERS::HUGE DISCOUNT $COUPONS$ ARE AVAILABLE .::- EMAIL| PM JAY -::.
Apexi Super AVC TYPE-R
$479.00
Blitz D1 SPEC SBC i-D (Limited Edtion) Boost Controller
$575.00
Greddy PRofec e-01 Electronic Boost Controller
$559.00
[url=http://www.importboostwholesale.com/images/hks_evc_100.jpg]
GREDDY AND OTHER BLITZ AVAILABLE AT WWW.IMPORTBOOST.COM
Turbosmart Dual Stage Boost Controller
$200.00
Turbosmart E-boost2 Boost Controller
$550.00
TurboXS High Performance Dual Stage Boost Controller
$229
ImportBoost is offline
Old 08-17-2005, 02:56 PM   #2
ImportBoost
Vendor
Member#: 80912
Default Ej5-40t Vs Vf34
EJ5-40T VS VF34
Old 08-18-2005, 01:51 AM   #3
checque
Member Sales Rating: (13)
Member#: 68562
RIP Edwin
Price for EJ5-40T shipped to 15642
checque is offline
Old 08-18-2005, 01:43 PM   #4
ccbad
Member Sales Rating: (3)
Member#: 16512
Gone WRX Wagon
Currently: F80
Sent PM
ccbad is offline
Old 08-18-2005, 05:09 PM   #5
ImportBoost
Vendor
Member#: 80912
Default Pmed
Everyone Check Pms..
Old 08-19-2005, 02:59 PM   #6
ImportBoost
Vendor
Member#: 80912
Default Info
UPDATE!
June 21st, 2005
EJ5-40T test turbo #3 makes 331 HP/336 ft/lbs of Torque with an exhaust leak! Click Here for the dyno chart!
June 16th 2005
EJ5-40T test turbo #3 installed with no problems. EJ20 powered wagon undergoing testing. Turbo has made 304 HP on 91 octane gas @ 18psi. Momentum Power? Momentum POWER!
Thanks to MAC autosport in Parker, Colorado for testing and tuning EJ5-40T test turbo #3. Nick certainly is a UTEC Jedi!
Dyno charts coming SOON!
June 15th 2005
EJ5-40T test turbo #2 installed with a hitch-see "Installation Notes"
EJ5-40 Test turbo installed with too small oil feed banjo bolt on the insistance of Momentum Turbochargers staff. Turbo failed within two dyno runs. Proof positive that turbochargers need oil. Note to dealers-The stock banjo bolt needs a bit of enlargement.
EJ5-40T test turbo #2 (RIP) makes over 300 wheel HP/Torque while dying. Momentum POWER!
June 8th 2005
EJ5-40T test turbo #1 installed without a hitch. Still waiting for test data from test turbo #1. Thanks to Vivid Racing for testing unit #1!
Old 08-20-2005, 02:33 PM   #7
ImportBoost
Vendor
Member#: 80912
Default CHeck
Check pms. Thanks for sales
Old 08-21-2005, 05:53 PM   #8
ImportBoost
Vendor
Member#: 80912
Default Fmic
Massive Fmic Instock. Momentum Turbos Also
Old 08-22-2005, 03:39 PM   #9
ImportBoost
Vendor
Member#: 80912
Default Check
Sent PMS
Old 08-23-2005, 02:24 PM   #10
ImportBoost
Vendor
Member#: 80912
Default Bump
Bump Up!
Old 08-24-2005, 08:40 AM   #11
ImportBoost
Vendor
Member#: 80912
Default Pms Sent
Pms Sent. Massive Txs And Turbos Instock
Old 08-24-2005, 10:44 AM   #12
theo001122
Member Sales Rating: (1)
Member#: 87369
04 wrx
jbp
how much for the utec? send me an email
theo001122 is offline
Old 08-24-2005, 04:15 PM   #13
Porkchop-WRX
Member Sales Rating: (6)
Member#: 33293
2011 4-door STi
Plasma Blue
Price shipped to 08854?
Porkchop-WRX is offline
Old 08-24-2005, 04:30 PM   #14
ImportBoost
Vendor
Member#: 80912
Default Sent
Sent thankx
Old 08-24-2005, 05:18 PM   #15
Rick539
Member Sales Rating: (4)
Member#: 35997
priced shipped to 67204
Rick539 is offline
Old 08-24-2005, 06:04 PM   #16
ImportBoost
Vendor
Member#: 80912
Talking Sent
Asuming you guys wanted Turbo Prices I sent if not pm me back
Old 08-25-2005, 06:33 AM   #17
ImportBoost
Vendor
Member#: 80912
Talking Sent
Hey Sent thoses Charts
Old 08-25-2005, 05:28 PM   #18
ImportBoost
Vendor
Member#: 80912
Default Info
EJ5-40T
It spools up faster than the vf34 but holds power to redline, the VF34 spools up slower and falls off at 5000 RPMs. The VF34 is operating outside of it's optimal boost range when turned above 18psi.
In fact, the vf39 which is VERY similar to the vf34, has shown that it cannot tolerate "overboost" conditions-quite a few vf39 turbine housings have shown cracks around the wastegate flapper because of the heat generated when these series of turbos goes out of it's operating range. The vf34 vs ej540t chart is 20psi vs 20psi.
COBB 2.5 MAPS:
The cobb stage 2.5 map is for a vf34-this turbo, because it is SO MUCH bigger than the vf34, will cause a lean condition above 5000 RPMs if you run high boost on this map.
If you have no way of monitoring your air fuel ratio, DO NOT run the EJ540t past STOCK boost levels on any cobb maps for the VF34.
Old 08-25-2005, 05:34 PM   #19
ImportBoost
Vendor
Member#: 80912
Default More Info
DYNO INFO:
The dyno results were made with a front mount intercooler. This is VERY VERY important, not because of the location of the intercooler, but the VOLUME of the intercooler. When you take a set volume of air and compress it, you raise the temperature. When you take the same volume of air and expand it, you lower the temperature. Why is this important? Well, the stock WRX top mount intercooler is NOT that large, overall. If you take off the stock td04 turbo and put on the larger EJ540T turbo, the turbo is still moving the same volume of air.
Old 08-25-2005, 05:38 PM   #20
ImportBoost
Vendor
Member#: 80912
Default Missed Some
Because the volume is the same, when you run boost levels higher than stock, you are actually compressing the air, thus raising the temperature. You turn the boost WAY up, and you are radically compressing, thus radically raising the temperature of, the intake air, sometimes to unsafe levels.
If you take off the stock top mount intercooler, and put on a larger one, you are increasing the VOLUME of your air intake sytemI(expanding), which COOLS the air.
Old 08-26-2005, 03:05 AM   #21
0db
Member#: 33879
2003 WRX Sporkwagon
Watch your back, man... if any thermodynamics professors see this, they won't be able to sleep until they kill you.
0db is offline
Old 08-26-2005, 04:17 PM   #22
ImportBoost
Vendor
Member#: 80912
Default Ehh
Ok? LOL
Old 08-28-2005, 05:33 PM   #23
ImportBoost
Vendor
Member#: 80912
Default Bump
Check Pms !!!
Old 08-29-2005, 09:29 PM   #24
ImportBoost
Vendor
Member#: 80912
Default Bump
Bump For The Industies Best Pricing And Highest Customer Feedback.
Old 08-30-2005, 03:37 AM   #25
ImportBoost
Vendor
Member#: 80912
Default Info:
Closed Thread
Momentum EJ5-40T turbo in PA boosted02suby Engine/Power/Exhaust 2 12-04-2008 04:44 PM
anyone using Momentum EJ5-40T turbo?? boost4life Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 115 09-08-2007 11:05 PM
FS: Brand New Momentum EJ5-40T turbo Bad Dogg TXIC Private Classifieds 23 02-01-2006 08:18 PM
Momentum EJ5-40t Turbo FS sandwood Private 'For Sale' Classifieds 10 01-04-2006 11:06 PM
momentum ej5-40t turbo ? dElKwOn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-21-2005 05:11 PM
