Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 08-17-2001, 12:55 PM   #1
ZMANNH25rs
Member#: 9401
. Truth is a
pathless land...
Default New to the club, need some advise on suspensions
Hello all. I have some questions for the masses regarding what is best for my car/driving style.
Car is a 99' 2.5 coupe, I drive hard, I use alot of weight shifting to help me around the turns(acceletor control, braking to shift weight, and dipping out then in - Im sure there is a proper term for this but I do not know what it is.
I am looking for a top of the line 18-20/21/22mm adj. sway bar, shocks struts and springs that WILL NOT LOWER MY CAR !!!!
Any advice and reccomendations would be greatly appreciated.
Drive Tight !
ZMANNH25rs is offline   Reply With Quote
Old 08-17-2001, 01:19 PM   #2
Basshead
Member#: 112
2011 Jetta TDI
all aftermarket springs lower the car...due to increased spring rate and lowering the center of gravity..sounds like you need to save for coilovers so you can have the great handling and be able to adjust your ride to the desired height also..
Basshead is offline   Reply With Quote
Old 08-17-2001, 01:34 PM   #3
ZMANNH25rs
Member#: 9401
. Truth is a
pathless land...
Default Coilovers ?
What will the coil overs due ? And if I got adjustable KYB/AGX's or equiv. and coilovers would I still need new springs ?
Drive In front !
Old 08-17-2001, 02:05 PM   #4
bensonwrx
Member#: 6904
Dark Machine
Color: Um...Dark?
Basically Coilover is a combo of springs/damper together, which is fully adjustable; that's why it costs way more than the Struts/Springs setup. In other words, you get either Coilover or Struts/Springs, NOT both.
If you change your suspension (plus great mount), then changing your sway bar to larger diameter is a good idea; usually 20/21mm works wonder.
Myself got the Prodrive WR, which will lower my car ~.75 inches, but nothing major. However, with my STi mounts I will be looking at a pretty stiff setup there
Agreeing with Basshead, you need Coilover if you want original ride height after changing suspension, but it will usually run you anyway from $1500 to $2500 (Yes, there are some cost way more but I am talking about the general).
Top of the line sway bar? Well I suggest Cusco
Good Luck!
-Alan (Another MY98 Owner)
bensonwrx is offline   Reply With Quote
Need some advise on what to buy (06-07) WRX vs STI GTIzzle07 General Community 55 06-16-2009 09:14 PM
Brand New To The Forum Need Some Help!!!! unreal2979 Newbies & FAQs 2 06-21-2007 02:18 AM
New to AWD and need some suspension advice ap0kalypse Brakes, Steering & Suspension 13 01-12-2005 05:13 PM
I new to the Subarus..need some help MyLegacyHits152.5db' Legacy Forum 22 05-13-2003 07:05 PM
Newbie: Looking at a new wrx, can I get some advise on power mods? Demon_Dub Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 09-05-2002 12:25 PM
