11-22-2005, 06:20 PM | #1 |
Member#: 101298
is dealership screwing me?
the speedometer has been sticking a lot (need to hit the cluster to free it up) so we brought it to the dealer.
the dealer said the whole unit needs to be replaced for around 750, is this reasonable? also, after searching it sounds like i need to look at a couple connections that may just be loose, any other ideas? dave |
11-22-2005, 06:41 PM | #2 |
Member#: 11808
Yes; connections first and especially the ground ones. Well my dealer charged me 53 dollars for a 4 dollar replacement clock so 750 sounds about right. Terribly overpriced I know so try to find one elsewhere if you don't find bad connections.
11-22-2005, 06:52 PM | #3 |
Member#: 89234
I would do a little more research on this. When I worked at a Subie dealership, a WRX came in and the tach didn't work. They replaced the tach/speedo gauges inside the cluster. Also the temp gauge in my 96 Legacy was broke and I replaced just the gauge only and problem solved.
What kind of car do you have? |
11-22-2005, 06:58 PM | #4 |
Member#: 89234
http://www.trademotion.com/partlocat...96&catalogid=1
See. $16 for a coolant temp gauge for a 96 Legacy. Prices do vary up to $200 for some gauges, but it's still no $750. So look around on there to see if you can find what you need. |
11-23-2005, 01:33 AM | #5 |
Member#: 101298
thanks for the responses, its a 98 forester, trying to sell it now that i have the wrx
Similar Threads | ||||
Dealership screwed me over- what are my options? | 1weirdsuby | Warranty Issues & SOA Problems | 22 | 03-13-2008 01:03 PM |
need help fast is dealer screwing me?? | blue subaru | Warranty Issues & SOA Problems | 9 | 01-31-2008 06:05 PM |
Dealership screwing me over, help please? | Jeff54 | Warranty Issues & SOA Problems | 75 | 02-15-2007 01:53 PM |
martin dealership in nj screwed me | supercharged318 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 11-09-2001 01:16 PM |
('93-'01) Dealership trying to screw me (warranty) | Aspen_2.5RS | Impreza Forum | 38 | 08-04-2001 08:13 PM |
