Welcome to the North American Subaru Impreza Owners Club Wednesday November 20, 2019
Old 08-04-2014, 07:44 PM   #176
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Gosh I wish you were closer i have my stock 02 cat back with only 2500 miles on it Id love to sell. Shipping it to you would be silly expensive
The WRX will fit in terms of hangers but you need to weld up some piping on the mid section as the exhaust run from the DP to Cat Back are different in routing vs the NA stuff. If you can score a cheap WRX cat back system ( with larger muffler ) it should only be $75-100 to have a meineke or midus exhaust shop weld up an adapter pipe.
dangerousatom is offline   Reply With Quote
Old 10-17-2014, 05:00 PM   #177
BigFag
Member#: 402856
02 Wrx
Does anyone know if struts and suspension would be interchangeable between an 02 wrx and an 06 Impreza?? Thanks
BigFag is offline   Reply With Quote
Old 11-06-2014, 11:31 AM   #178
gitnbye
Member#: 405662
1998 Forester
Green meaning
Default dohc-sohc swap general info
hey im a bit new I tried to ask a question on another related thread but it wouldn't allow me my question is when swaping from a phase 1 dohc 2.5 to a phase 2 sohc are there any issues I intend on using the dohc intake manifold, harness and ecu on the sohc but I wasn't sure if its that easy i.e if the cam positioning sensors are the same exhaust manifolds or if there is anything else im missing any help would be great
gitnbye is offline   Reply With Quote
Old 11-12-2014, 12:57 PM   #179
SKopsidas
Member#: 404375
2012 Forester X 4EAT
Navy
Does anyone know if the brake lines for 08+ wrx will fit 09+ forester sh? Thinking about putting stoptech's on my foz
Sent from my SM-G900V using NASIOC mobile app
SKopsidas is offline   Reply With Quote
Old 11-13-2014, 01:29 AM   #180
bcvngfhf
Member#: 406207
Hunt around on the Private for sale forums or post something. Im sure someones upgraded there suspension and has the old lying around, or may know someone.
bcvngfhf is offline   Reply With Quote
Old 12-12-2014, 08:16 PM   #181
Jaybird2013
Member#: 408467
05 LGT MT
ABP
could someone tell me if a CNT catted DP for a wrx-02-07 is a direct fitment for 05 LGT MT? thanks
Jaybird2013 is offline   Reply With Quote
Old 12-12-2014, 11:51 PM   #182
YouCantSeeMe1220
Member#: 408462
are WRX parts too expensive. I've been told that owning a WRX is too high maintenance.
YouCantSeeMe1220 is offline   Reply With Quote
Old 12-13-2014, 02:27 AM   #183
CarbonLip2237
Member#: 398311
02 WRX
Sedona Red Pearl
Originally Posted by quentinberg007 View Post
i'm curious about the WRX to GC8 interchangability. i know the engines swap with out toooo much hell. but what about suspension wise? i'm looking to overhaul my sad sad my93 L suspension, and it's kinda hard finding RS suspension parts.
~~Quentin
Rs is sedan ts is wagon, there is no ts sedan.
CarbonLip2237 is offline   Reply With Quote
Old 12-13-2014, 09:08 AM   #184
quentinberg007
Member#: 7887
2016 Toyota 4Runner
Barcelona Red
Huh?
1) that original post was from 2002... 12 years ago. Thankfully I'm doing better in life than having had to drive a 1993 Impreza for the past 16 years.
2) Where did I mention a TS? I was asking about GD struts and springs on a GC. IIRC, they will fit, but the geometry will be wonky.
quentinberg007 is offline   Reply With Quote
Old 12-13-2014, 10:50 AM   #185
m71owner
Member#: 332321
1998 2.5rs
wrb
Huh?
He's talking about Jacks post above yours.
m71owner is offline   Reply With Quote
Old 12-13-2014, 11:15 AM   #186
quentinberg007
Member#: 7887
2016 Toyota 4Runner
Barcelona Red
Ok, I see that now that I've looked back at the original posts... from the early 2000s.
Old 12-14-2014, 05:50 AM   #187
hghjgjh
Member#: 408548
hghjgjh is offline   Reply With Quote
Old 11-09-2016, 03:24 PM   #188
sol_tegra
Member#: 259406
02 WRB WRX
hey guys, will a 02-03 wrx wagon passenger front door fit on my 02 wrx sedan? will the front doors fit up to 07?
sol_tegra is offline   Reply With Quote
Old 03-01-2017, 11:49 PM   #189
sailingchris
Member#: 463837
Default Transmission Swap from 2.5 Legacy Outback to 2.2 Legacy both 1996 Model
I'm wanting to pull transmission from a 1996 Legacy Outback with a 2.5 liter fit and plug into my wife's Right Hand Drive 1996 Legacy with a 2.2 liter and work??? And I've done some research and I'm going to pull strut towers out and lift the Legacy L RHD up to Outback height and change rear brake drum system to rear disc brakes. I guess if rearend gear ratio is different will be changing out rear end diff. too? If anybody could help answer would be great but this looks like going to be an adventure for me. I should have an answer in a few days if nobody does to my questions and will post the out come on this. I do know some of this can be done the transmission is what is worrying me. Subaru help getting your mail to you rain sleet or snow Trying to make my wife's job just a little bit easier for this one is for work and not play.
sailingchris is offline   Reply With Quote
Old 03-09-2017, 12:57 PM   #190
Eastpierce
Member#: 214594
2004 Impreza TS
Mostly silver...
Yes, but the windows are different. You'd have to swap the windows and adjust the stops. In 05 the power mirror switch moved from the console to the door panel, you'll lose your power mirror if you swap across those years, save for major rewiring.
Eastpierce is offline   Reply With Quote
Old 11-15-2018, 12:29 PM   #191
dshiznit1489
Member#: 252086
2006 Rx8
Bumping this! Does anyone know if the side rearview mirrors between a 2015 WRX, Outback, Legacy, Crosstrek, etc. are interchangeable?
I just need the mirror cover, doesn't even need to be paint-matched.
dshiznit1489 is offline   Reply With Quote
Old 12-15-2018, 12:27 AM   #192
CBDslappy
Member#: 491899
would a 03 wrx radiator and fans plug right in and work with an 03 outback sport? I know itll bolt right up but will my ecu run them
CBDslappy is offline   Reply With Quote
Old 12-15-2018, 07:48 PM   #193
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
With or without turn-signal, the following are interchangeable:
WRX 2015-2018
WRX STI 2015-2018
Crosstrek 2015-2017
Impreza 2015-2016
Old 08-26-2019, 04:49 PM   #194
SubNation
Member#: 140747
2004 WRX Sedan
Does a 03 WRX sedan rear driver side door fit a 04 WRX sedan?
SubNation is offline   Reply With Quote
Old 10-31-2019, 11:46 PM   #195
davros
Member#: 208945
03 Forester
Red
what wrx/sti's cat backs fit on foresters?
forester in an 2003 xs na already fitted with uel and tsudo cat delete
i have an 04 STi axle back which will fit. What my issue is what mid pipe(resonator)? my stock one is 48ish inches long. I'm guessing the 04 sti/wrx/imprezas are the same length 48ish ?
davros is offline   Reply With Quote
Interchangeable parts? 04-07/08-10 WRX mista jc Newbies & FAQs 7 08-23-2010 01:29 AM
EJ intake interchange... any list? B-Kerr Subaru Conversions 2 03-17-2009 10:27 AM
Subaru WRX parts list zuczek Canada Region Forum 2 09-05-2004 04:03 AM
Subaru 4 pot brake kit (not STi Brembo) parts list inquiry Cosworth Brakes, Steering & Suspension 3 02-28-2004 04:38 PM
Subaru STi parts list for GC8's?? Tokay Normally Aspirated Powertrain 3 07-16-2002 07:38 PM
