Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 11-06-2020, 10:56 AM   #1
Pupwagn
Member#: 520053
Default 06 Impreza 2.5 AT low idle issues
I'm ripping my hair out trying to find the cause for the car idling at 250 rpm or so while in gear.
I've cleaned the throttle body, MAF, replaced the upstream 02 sensor, reset the ecu and idle relearning procedure. Checked for vacuum leaks, exhaust leaks, changed the fuel filter. Spark plugs were changed about 10k miles ago.
Other than the low idle, the car runs just fine. Accelerates at partial and WOT fine, no missing or power loss. When I come to a stop the car dips down to 250rpm. I had one CEL p0171 at the start of the issue but it has not come back yet.
Any advise on where to look next?
Pupwagn is offline   Reply With Quote
Old 11-06-2020, 11:06 AM   #2
kos
Member#: 118334
2006 Red GDA-F
2005 Aspen White GDA-E
Does the idle increase properly when AC is switched on?
kos is offline   Reply With Quote
Old 11-06-2020, 11:30 AM   #3
Pupwagn
Member#: 520053
The idle stays the same while in gear and at idle with the AC on as well as the defrosters. I can hear engine take a bit of load but no fluctuation in the RPM.
bad AC clutch?
Old 11-07-2020, 10:12 AM   #4
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
You had a P0171, so I'd start with that. I know the light isn't on now, but you can have a lean condition that's enough to cause symptoms, but not enough to turn the CEL on.
A vacuum leak would cause a low idle for sure. If you have access to a scan tool that shows live data, you can check the fuel trims at idle- anything over 10% can cause symptoms. The code doesn't usually set until 18%-20% or so.
CaptainSlowbaru is offline   Reply With Quote
Old 11-09-2020, 06:07 PM   #5
serrilion
Member#: 348982
2002 TS
Multi
Also the break booster could be going bad maybe? With the vacuum pressure en such could be another place to look. I would also check to make sure all the intake parts are tight. The fuel pressure reg could have gone, very unlikely but maybe not enough fuel pressure even though your saying it is fine on WOT. I'm just spit balling ideas for ya
serrilion is offline   Reply With Quote
Old 12-04-2020, 11:35 AM   #6
thenick
Member#: 199580
i been hatin'
Hellas since 2012
Could it be a loose throttle cable? A question of tightening the nuts or is it drive by wire?
thenick is offline   Reply With Quote
Old 12-06-2020, 09:40 PM   #7
Bluefoton
Member#: 141373
2019 Crosstrek Sport
6MT
Just to make sure - how do you know it idles at 250 rpm since the tachometer starts at 500?
A 250 idle would be rattling as hell, not to mention probably triggering the battery light due to insufficient alternator output voltage.
Just checking!
Old 01-16-2021, 10:27 AM   #8
Zhen4
Member#: 521706
Pupwagn, did you solve the problem? I am having the same problem although manual car. No codes. Also did all the things you mention here except O2 and fuel filter. Also, I have some hardly noticeable misfire (popping exhaust) at idle when hot. But for me, idle climbs slightly when AC is on. Also when driving at very low speeds and very soft throttle the car is "jumpy", I think it's related to the grumpy idle.
When I start the car (cold or warm) I have noticed that it sounds "heavy" in a way. You don't have to crank it for long but it sounds somewhat sluggish and doesn't fire up as strong and eagerly as my 3.0 H6 does (this is my first 4 banger Subaru so I don't know what to expect really). Battery holds charge well so I don't think it's that simple. Maybe bad ground somewhere?
I have access to a computer to log but I don't know what to look for.
Zhen4 is offline   Reply With Quote
