Welcome to the North American Subaru Impreza Owners Club Monday April 19, 2021
Old 01-22-2021, 02:39 PM   #1
00imprezaRS1229
Member#: 303720
Default Engine harness and ecu?
So I came to the conclusion that my ecu got damaged from an engine swap ( 08 2.5l engine into an 2011 Impreza with the same motor ) we kept the harness from the 08 on , plugged it into the 11 body harness and tried to run it ... iag just told me they’ve never heard of that being a problem and that it must be a short in the wiring somewhere . Car ran before , it now has the original harness with new motor , it cranks but has no spark . Checked the forums and did all the diagnostics thinking it was a sensor , wrong crank / cam pulleys, grounds , main relay , fuses , exc... still can’t find the problem and the dealer wants around 1000$ for a new ecu and installation . If anyone could help or give suggestions I’d appreciate it . Thanks
00imprezaRS1229 is offline   Reply With Quote
Old 01-23-2021, 09:42 PM   #2
Stojicsubaruguy
Member#: 504663
I always keep the factory intake when I do a swap. If you have the factory intake manifold I’d try swapping it over. Did you open the timing cover up at all or just drop it in?
Stojicsubaruguy is offline   Reply With Quote
Old 01-26-2021, 04:47 PM   #3
00imprezaRS1229
Member#: 303720
I swapped over cam an crank gears so yea and it’s the same intake manifold as the original
