#1 |
Member#: 60224
![]() Post your Legacy related part-numbers for replacement and upgrade OEM parts:
(Replacement Part numbers, Upgrade/Performance Part numbers, descriptions, details, requests, and related comments only!) Great parts guide with OEM numbers courtesy of LetItSnow: >>>Parts book x-treme<<< <DLC> No Questions folks, just parts. Ask questions in the forum please.
#2 |
Member#: 12900
Vehicle:1997 Legacy GT-Turbo Quick Silver Metallic |
![]() Part Description:
Fender Plug Model: BD/BG (noted by Wiscon_Mark: does not fit '95 models) OEM Part Number: 46059FA000 Notes/Verification: Perfect fit, snaps right in and plugs up the hole. Must have for those who have done a snorkusectomy. Picture for Reference: ![]() Last edited by Cajual; 07-24-2006 at 12:17 AM. |
#3 |
Member#: 12900
JDM Aluminum Door Sills Model: BD/BG OEM Part Number: E1017AC000 Notes/Verification: Installs directly over top the plastic sills with double sided tape and a couple of tabs that hook underneath. Adds some nice interior bling! The adhesive loses its stickiness in cold climates. Picture for Reference: |
#4 |
Member#: 60224
![]() Model:
1998 2.5 GT Sedan (BD) Part Description: Front Hub OEM Part Number: 28052AA010 Notes/Verification: Often needed while replacing wheel bearing, this number is for an AT although they *should be the same as MT. -------------------------------------------------- Part Description: Front Ball-Joint OEM Part Number: 21067GA050 Notes/Verification: Direct fit, Right/Left side same. -------------------------------------------------- Part Description: Tie-Rod End OEM Part Number: 34141AC010 Notes/Verification: Direct fit, Right/Left side same. -------------------------------------------------- Part Description: Front Wheel Bearing (cartridge) OEM Part Number: 28016AA011NT Notes/Verification: Entire bearing assembly, this is for an AT although they *should be the same. -------------------------------------------------- Part Description: Inner & Outer oil seals, wheel bearing. OEM Part Number: 28015AA070 28015AA080 Notes/Verification: Both inner and outer wheel bearing oil seal. One is pressed into hub before bearing, the other after. -------------------------------------------------- Part Description: Radio Bezel, wood grain OEM Part Number: J1310AC020 Notes/Verification: BD, 2-DIN, Radio bezel in wood grain. -------------------------------------------------- Part Description: Power antenna replacement mast (rod nut assembly) OEM Part Number: 86323AC070 Notes/Verification: Part works great, easy to replace, make sure you don’t loose the tiny screws which hold the motor unit together, also may want to use some additional grease to help with the install. Last edited by xcntrk75; 02-12-2006 at 01:17 PM. |
#5 |
Member#: 60224
![]() Model:
Various** Brake upgrade numbers: H6 rear brake upgrade: (x2) 26700AE04A Outback rear rotor (x1) 26696FC002 WRX rear brake-pad kit (early year) (x2) 26625AE000 Outback rear caliper brackets Subaru 4-pot front brake parts: (x1) 26296FA100 4-pot front brake-pad kit (x2) 26310AC040 4-pot front rotor (x2) 26232FA020 4-pot cross spring (x4) 26228FA000 4-pot retaining pin http://forums.nasioc.com/forums/showthread.php?t=623187 |
#6 |
Member#: 9972
E. Canada
Vehicle:2007 Jetta grey |
![]() Model:
BE/BH JDM parts 84001AE020 rh headlight (1 bulb system) 84001AE030 lh headlight (1 bulb system) 84001AE000 rh headlamp (2 bulb system) 84001AE010 lh headlamp (2 bulb system) 84001AE040 rh headlamp (HID) 84001AE050 lh headlamp (HID) 84201AE080 rh tail lamp (Lancaster) 84201AE090 lh tail lamp (Lancaster) 84201AE000 rh tail lamp (wagon) 84201AE010 lh tail lamp (wagon) 84201AE04A rh tail lamp (sedan) 84201AE05A lh tail lamp (sedan) 84251AE03A trunk finish lamp (sedan) 86512AE010 sedan rear wiper motor 86532AE040 sedan rear wiper arm J1018AE000 Blitzen grille J1018AE011 Blitzen badge J1018AE012 Blitzen badge 93073AE440 B4 trunk badge 93073AE470 B4 trunk badge (pink) E7218AE000** Blitzen sedan spoiler E7718AE110** Blitzen front bumper E7718AE120** Blitzen rear bumper 57711AE000 front re-bar 57711AE030 rear re-bar 57229AE010 turbo hood (steel) 57229AE030 turbo hood (aluminium) ** denotes 2 letter color code to complete If anyone is looking for something in particular for JDM BE/BH, I will try my best to find it. |
#7 |
Member#: 104066
Vehicle:1976 1976 Leone GSR White |
![]() These are for the 1991 EJ22T Legacy
I have some dealer prices listed as well... These are stock parts unless otherwise noted.... 14462AA060 Air Intake Hose (Turbo to Intake Manifold) $193.30 10105AA052 Engine Master Gasket Kit $279.86 12018AA360 Left Hand Pistons $80.39 12013AA350 Right Hand Pistons $69.87 12033AA390 Piston Rings $155.06 12209AA000 Crank Bearing Set $116.08 12108AA290 Connecting Rod Bearing Set $250.23 21111AA065 Water Pump $120.19 15010AA108 Oil Pump $140.23 13028AA102 Timing Belt $60.07 13207AA120 Intake Valve Seal (1 seal per package) $5.11 ($40.88 for set) 13211AA110 Exhaust Valve Seal (1 seal per package) $4.96 ($39.68 for set) I wonder why the pistons are different prices for left and right....? |
#8 |
Member#: 74009
Vehicle:95 Legacy GT Deep Sapphire Pearl |
![]() Just one part for now, got to go through my records and pull the other numbers.
BD/BG/BK 91017AA010 grill mounting clip, the infamous piece everyone seems to need. Price $3.92 from the dealer. |
#9 |
Member#: 9972
E. Canada
![]() 84201AC000 JDM BD tail lamp rh
84201AC010 JDM BD tail lamp lh 84001AC100 JDM projector head lamp rh 84001AC110 JDM projector head lamp lh |
#10 |
Member#: 42044
Vehicle:1998 Legacy GT Black |
![]() Part: Bracket Hanger Manual Transmission 4WD
Part Number: 44021AC030 Discription: The Bracket that attaches to the transmission then to second Cat. My Total cost was about 30 dollars ![]() On the Car ![]() Hope this helps someone. |
#11 |
Member#: 30556
Vehicle:2000 Legacy GT (BE) over 250,000 Miles |
![]() Alight guys and galls hope this helps
edit: Ok the old links got truncated.. so I redid it, hopefully this one stays allot longer. Legacy&Outback 95-99 Legacy&Outback 00-01 Last edited by NiTRoN; 03-16-2008 at 02:36 AM. Reason: Fixed Links |
#12 |
Member#: 53410
SWIC
Vehicle:BE-> GD->GR->SG->BL WAawd.org |
![]() Model: BE/BH (Baja)
Part #: 57220AE01A Desc: Hood Compl F (00+ BAJA HOOD WITH HOOD SCOOP) MSRP: $339.95 Part #: 90821AE020NN Desc: Grille F Hood (BAJA HOOD SCOOP INSERT) MSRP: $106.53 |
#13 |
Member#: 49895
Vehicle: 09 Forester 06 Legacy 2.5i Wagon |
![]() Model: 05 - 06 Legacy Wagon & Sedan
Part: Wiper Blade Refills (Inserts) Part Number: Nissan 28895-EA000 for LH side Nissan 28895-EA010 for RH side Discription: Wiper blade refills (rubber inserts only). You will need to transfer your stainless 'springs' to these new inserts. Why settle for the horrible Subaru inserts when you can have a quality insert? |
#14 | |
Member#: 108466
Vehicle:'98 GT & '95 LX Outback BH & BP |
![]() Quote:
BD/BG/BK 91017AA010 grill mounting clip upper (x 4) 91059FC090 grill mounting clip lower (x 2, these go into the headlight.) |
#15 |
Member#: 1964
RMIC
Vehicle:2012 Fit Sport 5MT Orange Burst |
![]() BD/BG/BK Grp. N strut mounts
ST203704S000 (RH) ST203704S010 (LH) Those are the original numbers... New! B0310FE010 (RH) $119.95 B0310FE011 (LH) $119.95 |
#16 |
Member#: 159963
Vehicle:2003 Subaru Baja Black & Silver |
![]() Air Pressure Sensor
Part #22098AA000 Anyone know what this part is and where it is? I have the Haynes repair manual but its not very clear about the location. Its throwing a CEL (codes P0105&P0106) and need to take care of it but dont want to pay $258 through Subaru for it. |
#17 | |
Member#: 159963
![]() Quote:
#18 |
Member#: 25516
Vehicle:1995 Legacy TURBO!!! EJ22T/TEC3 & '12 Civic |
Clutch and brake rubber cover Model: BD/BG with M/T OEM Part Number: 36015GA111 Notes/Verification: Simply sides on over the metal ________________________________________ Part Description: Key less entry remote Model: 98 BD/BG OEM Part Number: H7110AS020 |
#19 |
Member#: 102327
TXIC
Vehicle:2003 Legacy - RIP |
Bilstein HD monotube struts/shocks Model: BE/BH non-Outback Bilstein Part Numbers: F4-VE3-A168-M1 (Front L) F4-VE3-A169-M1 (Front R) F4-BE5-A170-M1 (Rear) Notes/Verification: HD series can be custom revalved |
#20 |
Member#: 131347
Vehicle:2007 Legacy 2.5i SE |
![]() For those wondering if a SPT Catback fits a non turbo Legacy...it will
Part Description: SPT Catback Model: This also fits a Legacy 2.51/SE Bilstein Part Numbers: SOA3881110 Notes/Verification: None. It took 5 minutes to bolt it on. |
#21 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
![]() Quote:
Hard rubber/plastic plug that goes on top rear of block, if removed you look down on the flywheel/flexplate: 11413AA033 - should cost you about $6. Injector seals, sit in the recesses in the intake manifold with the injectors sitting in these fat o-rings: 16608aa020 Phase I DOHC manifold gaskets: 14035aa281 (single gasket, not a pair, so order 2) Phase I DOHC valve cover outer gaskets: 13270aa062 13272aa063 Phase I DOHC spark plug gaskets, these are the oval-shaped flavor: 13293aa051 (you'll need 4, 2 for each head) pre-'99 jet-style washer nozzles 86636ac021 86636ac031 Pat |
#22 |
Member#: 188906
South East
Vehicle:1999 Legacy SUS lmt. Black Cherry |
![]() Bracket adjuster for A/C belt tensioner.
It's the plastic pieace with the threads that the tensioner bolt screw into. Part# 73134AC001 Cost me $6.75 |
#23 |
Member#: 67154
Vehicle:2007 Audi RS4 Avus |
Wiper Arm with Spoiler, Left Model: BD/BG OEM Part Number: 86532AC231 List Price: $49.95 Notes/Verification: This is the wiper arm with integrated spoiler, available on 1999 GT Limited w/ Cold Weather package. Picture for Reference: Part Description: Wiper Arm, Right Model: BD/BG OEM Part Number: 86532AC241 List Price: $39.95 Notes/Verification: This is the passenger side wiper arm. Picture for Reference: Part Description: Wiper Arm Cover Model: BD/BG OEM Part Number: 86538SA020 (x2) List Price: $1.66 Notes/Verification: This is the rubber cover for the base of the arm, you need 1 per arm. Picture for Reference: Last edited by Dan Cech; 10-16-2008 at 07:42 PM. Reason: Added Photos |
#24 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
![]() For a 1998 Legacy GT wagon, fits other years/models:
Part Description: Drivers door, master window control switch Model: BD/BG OEM Part Number: 83081AC071 List Price: $159.25 (price from a dealer 11/2009) PITA to try & work another switch in since it's a single piece with all the switches in it. If you have the woodgrain, it fits over the switch unit itself so no color is called out. My drivers window switch failed & I could not ressurect it. |
#25 |
Member#: 176006
Vehicle:1997 Legacy GT Spruce Pearl Metallic |
![]() hello. i have a 97 lgt and just started posting in nasioc after crusing the site for awhile. i used to be a tech but now work in a subaru parts dept., so if i can help anyone find any part numbers please let e know, i would be glad to help. i will post pcs of my car when i can. But i wil be at the don miller subaru show in June. Anyone close to the Madison are should check this show out, its always a good time
('93-'01) The part # thread | Hondaslayer | Impreza Forum | 186 | 07-14-2016 08:42 PM |
Moderators: We need a sticky part # thread! | xcntrk75 | Legacy Forum | 42 | 02-13-2006 05:00 PM |
