Welcome to the North American Subaru Impreza Owners Club Friday April 16, 2021
Old 05-28-2020, 09:14 AM   #301
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Originally Posted by Delphi View Post
Has anyone here gone direct port? I've been thinking about going to an Aquamist setup for safety and the fact its the best Methanol Kit on the market without standalone controllers and what not.
I know a Aquamist had their PDM controlled kit (model number escapes me) but running it port style was common from what I recall. If I recall they had the check valves to keep vacuum from sucking fluid into the port as well.
My goofy engineer ass whats to run a tiny nozzle pre compressor (I'm aware of the risks), then another small one post compressor (not enough for it to condense in the intercooler) and then post intercooler.
Get all that heat out. Then again, if you can shoot directly over the valve, and keep your air mass fraction up by not vaporizing the water/meth charge....
Would be an interesting test. I've seen how this principle works with high secondary injectors and the addition time for latent heat of vaporization won out over shooting past the valve.
Old 05-28-2020, 10:20 PM   #302
Delphi
Member#: 239335
I wish I was more capable with tuning because I would love to try that.
With the Aquamist setup from what I understand is that you run the port injectors along with a pre throttle body injector that is 2x the size of the port injectors. I've been talking with my tuner to see what the best avenue is for me, he has a lot of experience with the Aquamist stuff so who knows I may stay single injector. I plan on adding some BC 272 cams as well and I am looking at a bigger hotside for the turbo to carry out the power. The T3 0.63 on my SX257 is awesome on the street but adding an extra 500-600rpm might make it a restriction. A T3 0.82 without e85 here in Canada should be the sweet spot with Cams and a good meth system.
Delphi is offline   Reply With Quote
Old 05-30-2020, 12:59 PM   #303
Grantmac
Member#: 498493
I'm running a single nozzle in the upstream end tank of my TMIC right now with success. I wasn't convinced that I'd get even fluid distribution with the nozzle close to the TB.
I may eventually go for a dual nozzle system with each positioned adjacent to the inlet pipes but for now the nozzle is simply positioned between them.
I do get a little excess fueling on shifts which is likely residual fluid in the IC but not enough to cause an issue. My system allows me to prime from the driver's seat so I can also use it to combat heat soak in theory although the car obviously doesn't idle that well ingesting fluid so I need to pulse it for a second or two at a time.
Grantmac is offline   Reply With Quote
Old 05-31-2020, 07:43 AM   #304
pcampbell
Member#: 437670
2005 2.5 SC OB
Just curious, why not after the intercooler?
pcampbell is offline   Reply With Quote
Old 06-04-2020, 02:57 AM   #305
Grantmac
Member#: 498493
I wanted to give the fluid longer to phase change, help improve IC efficiency and also possibly distribute the fluid more evenly.
In theory it should do all that. In practice I don't have any way to confirm that it's better than just before the throttle plate.
Old 06-04-2020, 07:49 PM   #306
blurred
Member#: 47143
No, its actually not good before the intercooler, you need it to be mist when in the intake manifold in order to take some heat away from combustion and allow the meth to act as a fuel. You are doing more harm than good.
blurred is offline   Reply With Quote
Old 06-04-2020, 09:07 PM   #307
Delphi
Member#: 239335
A small nozzle pre intercooler does help cool the charge a lot. But you still require a big nozzle in a standard place.
Old 06-04-2020, 09:51 PM   #308
Homemade WRX
Member#: 33782
96 3MI Racing
And a small nozzle pre-compressor can actually increase mass flow rate but if done incorrectly, it can etch/damage the compressor wheel.
Old 06-05-2020, 07:25 AM   #309
pcampbell
Member#: 437670
2005 2.5 SC OB
Any guideline for what is too big of a single nozzle? I know devils own makes bigger single nozzles than snow. I’m on a DO5 now and it’s great but with more boost would like to move up to the next size which is a DO7.
Old 06-05-2020, 07:32 AM   #310
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
back when i had my smc kit, i had the nozzle underneath the tmic outlet directly in front of the throttle body. it seemed to work well for added boost in the higher rpm's, this was on the stock v8 ej207 with the vf37, hitting 25psi.
murrdogg24 is offline   Reply With Quote
Old 06-05-2020, 10:52 AM   #311
Homemade WRX
Member#: 33782
96 3MI Racing
I simply made my own sizing calculator for nozzle selection as there are so many nozzles and pressures on the market. So first calculate what your nozzle is really putting out.
Old 06-05-2020, 04:58 PM   #312
Grantmac
Member#: 498493
I disagree. The methanol will still burn as a vapor and I'm nowhere near the temperature required to vaporize water. The fluid remains as a mist while it travels through the intercooler where it helps pull heat. Also allows better distribution compared to aiming it at just one spot near the throttle body.
Running 20psi with a k04 on crappy Canadian fuel (91 equivalent) and 13 degrees of timing at peak torque.
Old 06-17-2020, 06:08 AM   #313
RakumiAzuri
Member#: 472102
2018 WRX
Gunmetal
Has anyone added one of these kits to the 2015-2020 WRX? E85 isn't a, reasonable, option where I live for a few reasons. Were there any issues or unforeseen draw backs?
RakumiAzuri is offline   Reply With Quote
Old 06-17-2020, 09:18 AM   #314
Homemade WRX
Member#: 33782
96 3MI Racing
Yes, lots of people have added meth injection to the FA20DIT engines.
Old 09-25-2020, 12:33 AM   #315
Manny.mo1
Member#: 456257
2016 WRX Limited
World Rally Blue
Hi, not sure if I missed it, but are there any recommendations for a failsafe for the AEI30-3300 AEM Electronics Water / Methanol Injection Kit V2 (up to 35psi) w/ 1 Gallon Tank - Universal
I'm trying to use the failsafe pn 30-3020 but I can't seem to figure out where to tap into/wire the rest of the failsafe to my GrimmSpeed electronic boost controller solenoid (3port)
Manny.mo1 is offline   Reply With Quote
Old 01-02-2021, 04:15 AM   #316
thiessentr
Member#: 469678
2010 STI hatch
Would running a WMI kit just above wastegate spring pressure to target boost yield maximum safety? The failsafe would be both a low level indicator and flow meter attached to the ebcs. This way, if a failure of some sort occured or the tank couldn't be filled, you could still safely drive the vehicle indefinitely without negatively impacting your AFRs.
Would there be enough of a benefit in terms of performance and anti det to run a kit for such a small range? eg. Spring pressure ~14.5 psi WMI spray 15-20psi.
Does anyone have experience running WMI in extreme cold? In Canada, I regularly see winter Temps ranging from 5f to -40f. Im also worried about pump operation.
thiessentr is offline   Reply With Quote
Old 01-15-2021, 03:38 PM   #317
blurred
Member#: 47143
Mine ran from about 10psi using 125cc jet using washer fluid. The way it was tuned it didn't matter if it ran out or the jet clogged etc, it wasn't used to make more power through chemical efficiency but as more of a safeguard against worst case conditions (fuel/temps/etc). The car could easily run the power (365whp) on pump gas.
Running -40 washer fluid (the best to use is the Turbo Power brand which is 50% methanol). Of the roughly 50 aem wmi kits my friends and I have used over the past 10+ years we haven't had any failures using in winters down to -15c
Old 01-18-2021, 03:27 AM   #318
thiessentr
Member#: 469678
2010 STI hatch
Thanks for the reply. This helps out a bunch
Old 01-27-2021, 05:19 PM   #319
Rootini
Member#: 521983
Good info, looking to go meth soon
Rootini is offline   Reply With Quote
Old 03-15-2021, 06:59 PM   #320
Gluis
Member#: 245584
07 Impreza WRX STI
Default HFS 3 not working
I bought an HFS-3 system from Jeff Howerton in 2011 (S/N 10444) for my heavily modified 2007 STI. It didn't worked for a while as the cable that goes to the ECU was crimped incorrectly (The wire that goes to injector 1 on the ECU was the wrong color). After troubleshooting that and wiring the correct cable, it worked perfectly for a long time. I don't drive my car often though. When I'm not using it, I usually fire it up once a month, let it get to operating temp, Check several things, among them that the HFS-3 is working then switch the car off and cover it again. A month ago the HFS didn't turned on. Nothing happened in it. I thought it might be a minor problem and decided to check it afterwards. I did it this month. I checked fuses and connectors, measured voltage on proper pins, connection to ground, and swapped the gauge cable for a CAT6 cable to see if the cable was ok, but nothing happened. I also checked for voltage in all pins on the cable going to the gauge and none has voltage. I checked on the controller but nothing happens if the gauge is not working, so I have no clue what the problem could be. I'm out of basic troubleshooting ideas, and would love any suggestion to what might be happening. I barely use the system as I have different maps on my Accesstuner, and just use the high boost with the aquamist map when I'm up to no good (which is not very often).
I will appreciate any help to troubleshoot and fix it.
Gluis is offline   Reply With Quote
water / methanol injection kit -new or used blazin sti Private 'Wanted' Classifieds 3 05-27-2006 08:01 PM
Water/Methanol Injection or Race Fuel or Both ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 06:35 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 05:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 04:51 PM
