Old 05-10-2013, 10:02 AM   #26
06rexwagon
Member Sales Rating: (16)
Member#: 114730
2006 WRX Limited Wag
9.8@150
Originally Posted by mav1c View Post
Bringing back...
I assume the thread on this sensor is the same as the Defi? You just unscrew the Defi sensor from the bung and screw this one in?
Threads are the same you just need to pin the wires or splice them to the old connector.
06rexwagon is offline   Reply With Quote
Old 05-10-2013, 01:38 PM   #27
mav1c
Hoodbridge!
Member Sales Rating: (52)
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
OK. I'll give it a try!
mav1c is offline   Reply With Quote
Old 09-12-2013, 01:48 AM   #28
Impreza4ever
Member#: 62510
2005 Impreza Wrx Sti
WR BLUE PEARL
Smile
Just finished installing this EGT Probe from thesensorconnection.com and i can tell ya it works just as the original Defi Probe.
Just make sure like they say previously to reverse the leads as Yellow is the positive wire on the sensor.
Thanks to OP for the finding.
Impreza4ever is offline   Reply With Quote
Old 09-12-2013, 01:51 AM   #29
06rexwagon
Member#: 114730
9.8@150
Glad it helped you.
Old 11-13-2013, 02:31 AM   #30
awdboostftw
Member Sales Rating: (1)
Member#: 178656
14 WRX hatch
& 06 Evo IX
so it seems as thought i cannot use this if i have no existing egt probe to replace? as in i bought a defi egt gauge with no sensor (but have the half of the wire that connects to the control unit), this is unusable? or is there a way to bypass the plugs on the defi harnesses?
awdboostftw is offline   Reply With Quote
Old 11-13-2013, 10:34 AM   #31
06rexwagon
Member#: 114730
9.8@150
If you have the wire that is supposed to connect to the Egt you can cut and solder them.
Old 11-13-2013, 12:15 PM   #32
APM Tuned
Vendor Sales Rating: (1)
Member#: 282460
2005 Evo-STI
R.R.-WRB
sensor connections, chris, great guy and up front. We were looking for numerous other sensors as well and yup, he's gone as far as sourcing them to make sure we get what we need. Even letting us try a couple out to make sure they are within operating measures.
-Mark
__________________
[B]APM Tuned[/B]
Phone: (630) 833-8911
Email:
[COLOR="Black"][B][SIZE="1"]Fill out our online survey for up to $50 off your next order from APM -
[/SIZE][/B][/COLOR]
APM Tuned is offline   Reply With Quote
Old 05-08-2014, 06:29 PM   #33
resu
Member Sales Rating: (2)
Member#: 78288
2006 Subaru STi
CGM
Bump to 2014 - this just saved me some serious cash. $50 vs $200+ for the same thing. Be mad all you want that I'm bringing it back but it's too good.
resu is offline   Reply With Quote
Old 06-01-2014, 06:16 PM   #34
neo8222
Member Sales Rating: (6)
Member#: 311321
2002 WRX STI
thanks for that, I hit a "bump" and broke my sensor in half, This will save me a good chunk of cash.
neo8222 is offline   Reply With Quote
Old 04-15-2015, 08:05 PM   #35
relliMmoT
Member Sales Rating: (9)
Member#: 206931
2004 WRX Wagon
6MT JBP 318WHP//300WTQ
I'm glad I remember seeing this thread from a few years back because my sensor is busted now. I can't thank you enough OP!
Shame on Defi for wanting $200 for a simple thermocouple (two wires welded together inside a metal casing)
relliMmoT is offline   Reply With Quote
Old 04-15-2015, 08:41 PM   #36
iNfEk
Member Sales Rating: (3)
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
12.9@103MPH EJ205 4EAT
Exactly my thought the other day when I saw my sensor.
iNfEk is offline   Reply With Quote
Old 04-16-2015, 10:12 AM   #37
06rexwagon
Member#: 114730
9.8@150
Thanks. I'm glad it helped you out.
Old 07-16-2015, 03:57 AM   #38
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
Yes, this is a little late, but I was wondering people that said my original defi sensor failed...What were the symptoms when your sensor went bad ?
My EGT readings have always been a near 1400 @65mph, lately its been drifting upto 1600, then back to 1500, then 1400 then 1600 again. Even at idle, use to be 850, now 950 to 1000. WBO2 gauge shows around 14.5 as always at light cruise and 14.6 to 14.8 at idle. And fuel trims are still in the -2 to +4 range, not showing the engine is lean or the ecu is needing to add a bunch of fuel. I am thinking the gauge is not telling me the truth.
bobjr94 is offline   Reply With Quote
Old 07-16-2015, 09:05 AM   #39
06rexwagon
Member#: 114730
9.8@150
Timing and boost effect EGT as well. If you have a short ram or other hot air intake, your car will be running less timing during hotter weather. Less timing=hotter EGT. If the car is detonating and reducing timing it will also have a higher EGT.
Old 04-14-2016, 08:23 PM   #40
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Default Affordable replacement EGT probe for Defi gauge
Installing mine now after buying it a while ago. LOL. hand to change out my header so need a new probe too. Anyway, my wires are kind of old for my Defi link meter gauges and when I cut back the metal braids I have fiberglass and looks like bare wires in them. At the end before the connector end I have red and white wire sheeting.
How did you determine which wire is what and what's the easiest way to connect this up?
Old 11-22-2016, 05:17 PM   #41
resu
Member#: 78288
2006 Subaru STi
CGM
Connectors confirmed.
This thread helped me out big time. I had purchased the sensor some time ago and just installed it. Saved me well over $100+. Hope the below proves useful for some! Thanks again to the OP for the information on the sensor.
If you're OCD like me and wanting to replace with exactly what DEFI uses; below are the part numbers and model names for the connectors. They are made by TE Connectivity (who makes Deutsch connectors, Raychem and much...much more.
Sub-brand for these - called "AMP" by TE Connectivity
Housing for female terminal
Econoseal - J Mk II
Mfr. Part# 174352-2.
http://www.alliedelec.com/te-connect...52-2/70283636/
Male terminal (on the end of the Defi EGT Sensor)
Econoseal - J Mk II
Mfr. Part #881772-1
http://www.te.com/usa-en/product-881...-docs-features
Last edited by resu; 11-28-2016 at 09:10 AM. Reason: Confirmed connectors are correct
Old 06-23-2020, 10:10 AM   #42
06rexwagon
Member#: 114730
9.8@150
Bumping again, as the one I ordered 10 years ago finally bit the dust, so I ordered another.
WTB: EGT probe for greddy egt gauge pannell77 Private 'Wanted' Classifieds 1 04-24-2009 09:40 AM
EGT probe for old Defi-D? tazswing Electrical & Lighting 2 03-19-2009 12:06 PM
What EGT fitting for Defi probe illmatic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-01-2006 04:27 PM
Teamrip EGT probe and Defi Gauge Lunchbox027 Electrical & Lighting 6 07-24-2005 11:56 PM
Westach EGT Probe with different gauge TurboRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 06-22-2002 02:24 PM
