#1 |
Member#: 210593
Vehicle:2002 WRX PSM Epic tuned 300whp |
![]() I burn or use about 1/2 to 1/4 qt. Of oil about every 800 or so miles and I know this has been asked 1berrrzillion times before, but has anyone noticed they use less oil with a catch can on there setup? If so which can are you using? Thanks
#2 |
Member#: 136396
Vehicle:2015 WRX, 2012 WRX, 2013 BRZ, 2006 STI |
![]() Both catch cans and air oil separators have been proven to dramatically reduce the amount of oil consumption on subarus. I'd call around to a few vendors on here and see what they recommend for your situation and budget!
Mike |
#3 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
![]() using the right oil reduces usage
if yoar using oyl you are likely using the wrong oyl Last edited by Uncle Scotty; 06-02-2010 at 11:08 PM. |
#4 |
Member#: 210593
![]() thank you for that but not likely I have went through almost every brand out there synthetic, non-syn, syn-blend almost all the same. My leak down test showed less then 6% loss on 2 cyl. And less then 10% on the other 2 so I know no issue there. Thus the reason asking about a catch can in hopes of stopping most of the oil usage.
#5 | |
Member#: 16200
![]() Quote:
how about changing the pcv valve and 5w30 is NOT 'required' either |
#6 |
Member#: 210593
![]() I changed the PVC valve about 300 miles ago is there any other componets that might effect oil use? I have also tried 5w30,5w-40, 0w-30 didn't know about 0w-40 or going 10w-30 since it is like 90 degrees here? Thanks for all the help
#7 |
Member#: 115070
Vehicle:2009 DGM LGT Spec.B 08 Audi Q7 4.2 PRM |
![]() A quarter quart of oil every 800 miles? How do you recognize cup (8 oz) being lost??? That represents a significant amount but strange how you can tell.
Anyway you need a compression test also. If the oil is not leaking away it's burning/blowing away. There could be a number of issues from rings to headgaskets to turbo seals to valve lash. If the oil is blowing out the crankcase a catch can won't stop the consumption it will just catch it. And if you change your oil on intervals longer than 200 miles you don't want what ends up in the catch can back in your crankcase. Before adding an apparatus to the car to catch oil you should eliminate the possible sources of the problem you are having. Oil is not your issue unless you are using the wrong oil; one which is too thin or not strong enough to protect and properly cool a tuned Subaru motor. How many miles on this car? -soobaviator |
#8 | |
Member#: 210593
![]() Quote:
#9 |
Member#: 67004
SCIC
Vehicle:02 vf30 pnp wagon silver and cf |
![]() Try an aos. It worked for me.
#10 |
Member#: 136396
![]() An aos is an extremely effective unit at preventing oil consumption, while a catch can works its still taking oil out of the engine and essentially throwing it away.
Will |
#11 |
Member#: 210593
#12 |
Member#: 67004
SCIC
![]() Easy install
#13 |
Member#: 67518
NESIC
Vehicle:2013 Focus ST TB |
![]() Oil consumption on a subaru, you got to be joking
![]() I burn a qrt every 700mi but I do know where mine is leaking I can see it in my rearview Turbo seal has been leaking for a while now started at 97k now at 124k The freaking turbo will not die. ![]() |
#14 |
Member#: 115070
![]() ^The turbo is dead, it just has not stopped working... Why don't you get it fixed? New seals on a TD04 is not an expensive deal, better yet at current prices you could get a used one in decent working order for about the price of a years worth of the extra oil you are shooting out the exhaust... Assuming you are running a TD04
#15 | |
Member#: 16200
![]() Quote:
wonder why ![]() ![]() ![]() ![]() |
#16 |
Member#: 16200
![]() and as asked above......how can you be so sure that you are using 8oz of oil with such precision???
#17 |
Member#: 178426
Vehicle:2010 S4 Gray |
![]() It's a guess, as he mentioned. Technically, it would be extremely easy to measure if 8oz are being blown out the engine. Check you oil every time you run it and simply measure the oz off the quart bottle you use to fill it up. Simple.
#18 |
Member#: 210593
![]() Lol excatly! For some I guess this concept or method wouldn't be accuarte enough for some, but as long as I don't run low on oil I'm happy. I will be getting a AOS to help fix the issue thank you Grimmspeed always very very helpful. As for Uncle Scotty thanks for trying to help on checking the compontes.
#19 |
Member#: 115070
![]() Buying an AOS to solve an oil loss issue is like taking a Tylenol for a backache. It may help the symptoms, pain, but it won't heal the muscle or bone that is causing the pain. In the same sense the AOS will only take the oil (also the fuel and whatever heavy crap that's in it) out of the blow by gas and put it back in the pan. It does nor fix the reason the oil is escaping. And it will only capture stuff that comes out of the crankcase. If your oil is burning in the combustion chamber an AOS will do absolutely nothing.
The first thing to do is source where the oil is getting out and why. Then you buy parts to fix the actual problem, not put a band-aid on it and kick the can down the road on solving the issue. I've owned four Turbo Subarus and one N/A Subaru. None of them used oil to any significant degree. If an engine is using oil there is an issue with the engine or component on the engine. The problem is not that your engine does not have a cleverly designed aftermarket piece of kit. |
oil catch can or air oil seperator??? | jaytech | Newbies & FAQs | 11 | 09-21-2009 12:03 AM |
WTT(HR): Greddy Oil Catch Can with Perrin Oil Catch Can | scooby_wooby | MAIC Private Classifieds | 1 | 03-24-2008 09:01 PM |
FS:OH: 3" flat flange, perrin catch can cover, fp oil outlet flange | mikkellucci | Engine/Power/Exhaust | 3 | 08-16-2006 08:50 PM |
have oil catch can, but still oil in IC | TyranosaurusWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 05-05-2005 11:46 PM |
DO oil catch cans help with oil consumption? | 1/500yellowwrx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 01-10-2005 02:57 AM |
