Welcome to the North American Subaru Impreza Owners Club Wednesday April 14, 2021
Old 09-08-2010, 11:42 AM   #1
jpnovak
Member#: 221948
1975 Porsche 914 TT
Default EJ20G 1998 wiring diagram
I am transplanting a JDM ej20g and matching MT into a Porsche 914. I have the entire front of the car wiring harness including ECU and want to strip down just the minimum required to run. I will mount my own relay panel.
The ECU is a 4W pn 22611 AD412. AFIK this is from a JDM 98 Forester with MT. I am unable to find information on this anywhere.
My problem is that I can not find a wiring harness diagram. I have copies of may Impreza wiring diagrams, both domestic, Austrailian, and JDM. The color codes for the pinout are very different that my ECU. The ECU has 3 yellow connectors with 26, 22 and 16 pins.
Additionally, I will not be subject to emissions on such an old car. Can anyone show what "stuff" can come off the top of the engine to clean it up?
I could also be interested in a 2S 22611 AC731 pinout. I have found one for sale in archives and the wiring is very similar to the 4W. I believe the were both from the EJ20G. The 4w was from the Forester and the 2S from the WRX wagon (non-US). Both use the EJ20G with the TD04.
I would appreciate any help you can provide.
Alternatively, Is anyone interested in an entire front JDM wiring harness and ECU? I am " this close to dumping it all and installing a standalone from scratch.
jpnovak is offline   Reply With Quote
Old 09-08-2010, 08:13 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
PM Sent
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 09-08-2010, 09:36 PM   #3
kenikh
Member#: 212677
1999 Forester S
Bone stock...for now
JAMIE, WTF are you doing here??? Lemme see if I have what you need.
kenikh is offline   Reply With Quote
Old 09-08-2010, 09:38 PM   #4
kenikh
Member#: 212677
1999 Forester S
BTW, Matt Monson is the guy to talk to on your project.
Dude, just call me tomorrow...I am building a v4 RA spec EJ22T motor myself.
Old 09-08-2010, 10:16 PM   #5
dr3w
Member#: 222318
1993 RHD GC8
I have a copy of the ecu pinout/wire colour for an EJ20G. Pm me your email and i will send it to you!
dr3w is offline   Reply With Quote
Old 09-09-2010, 02:17 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
I have a wiring diagrams in English for you (and in Japanese aswell) in PDF format. Send me a PM with your email address. I recently figured out that the pin out and wiring is the same for EUDM and JDM 1997-1998 turbo cars (GC8).
Marnix is offline   Reply With Quote
Old 09-09-2010, 04:40 PM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
The wiring harness is from the same forester as the ECU? I assume then that the ECU is a 3-plug variant?
-Rob
rob is offline   Reply With Quote
Old 09-09-2010, 07:02 PM   #8
jpnovak
Member#: 221948
1975 Porsche 914 TT
Yes, the ECU is a three plug and is from the same car. I have all of the under dash wiring (about 60 pounds of it) including the main relay/fuse boxes, dash connections, light connections etc. I have only found two places where it was cut and I assume these go to the rear of the car (tail lights). I was very pleased to have a complete package.
Here is the wiring out from my 4W ECU.
This can go into the archives once the problem is solved.
Old 09-10-2010, 09:06 AM   #9
jpnovak
Member#: 221948
1975 Porsche 914 TT
The ECU that was for sale in this ad has a very similar pinout. However the wiring colors are different. It is possible that the circuits are the same and the wiring color is different.
http://forums.nasioc.com/forums/show...ghlight=2s+ecu
Old 09-10-2010, 10:25 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
yeah its very similar to a "k" ecu
colors are more of a suggestion with Subaru wiring than a rule
you need the pinouts for a ej20k
Old 09-10-2010, 11:19 AM   #11
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
No guarantee that this matches the Forester wiring....
Old 09-10-2010, 02:32 PM   #12
jpnovak
Member#: 221948
1975 Porsche 914 TT
Thanks Rob. I compiled this list with my other diagram. What is this pinout from?
I think there are many things I can eliminate. The question is... I have a few wires that are not identified in this output. As far as I can tell, all of the main functions are in place. I might be able to leave those extra wires disconnected.
Old 02-18-2012, 04:07 AM   #13
zurdo
Member#: 271984
1997 SF5 turbo MT
Maybe this can be usefull http://dialspace.dial.pipex.com/prod...ts/MY97ecu.pdf
Injector wiring is identical.
P.S. I am searching second ecu with SN in subject. Can any one help me?
zurdo is offline   Reply With Quote
Old 02-18-2012, 08:14 AM   #14
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
An 22611AD412 ECU? I have a spare one. Send me a PM if you're interested and willing to pay shipment from Europe.
Old 03-03-2014, 08:05 PM   #15
Clinically_ill
Member#: 356436
Ok, I'm resurrecting this from the dead sorry. I have the 4W ECU & am currently looking into my options for a stand alone. Was it found here that the 4W is compatible with the EJ20K ECU?
I am looking into something like this.
http://store.haltech.com/usastore/pl...97-98-usa.html
as well as the ViPec version for 97/98. Wanting to know if they will work with my '97 4W ECU
Clinically_ill is offline   Reply With Quote
Old 03-16-2014, 09:02 PM   #16
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
There are basically 3 types of ECU for the pre Bugeye turbo's.
4 plug (96 and earlier, V1-V2)
3 plug (97-98, V3-V4)
3 plug (99-2000, V5-V6)
The enormous amount of different ECU types using the same physical connectors is just because of specific mappings available for different countries/gasoline quality etc, but as you'll be working with a mappable ECU those are not of concern to you as you'll only need to find the ECU which connectors physically fit your loom.
The first one is pretty obvious, if the ecu has 4 plugs it's a 96 or earlier.
The difference between the 2 3 plug types is that the later models (99-2000)
have much more pins per connector..
The V3-V4 have 3 plugs, containing 16,22 and 26 pins respectively, all in 2 row pinouts
so you'll end up with thin narrow connectors
The V5-6 also uses 3 plugs, but they each contain 32 pins, and they are much higher
and narrower physically , and arranged in a 4x9 pin format.
There are pictures of the connectors in the link below.
http://www.jollygreenmonster.com/pinouts.htm
Do you plan on selftuning or going to a shop??
It usually is best to go with the ECU the tuner has experience with IMHO, so I would consult him as well.
Also ,seeing that there are more then enough PnP ECU's available I would not bother with the Haltech (again IMHO)
Dutch Scooby lover is offline   Reply With Quote
Old 10-19-2015, 09:20 PM   #17
ae86forester
Member#: 432518
can someone ples send me the diagram!
ae86forester is offline   Reply With Quote
Old 10-19-2015, 09:43 PM   #18
binny
Member#: 198108
MY98 WRX
Pin out diagram ? Go to the Vipec site has the pin outs for each MY ecu
binny is offline   Reply With Quote
Old 11-04-2015, 12:00 PM   #19
ae86forester
Member#: 432518
I'm not seeing it on there
Old 11-04-2015, 06:37 PM   #20
binny
Member#: 198108
MY98 WRX
Choose the 'MY manual to suit its in there
Old 11-04-2015, 08:27 PM   #21
ae86forester
Member#: 432518
I must be on the wrong website?!? Still can't seem to find it (I'm slow sorry)
Old 11-06-2015, 12:06 AM   #22
binny
Member#: 198108
MY98 WRX
Don't worry I just had a look the site has changed I'll upload a pic if possible
Old 11-07-2015, 11:48 AM   #23
ae86forester
Member#: 432518
That'd be great I was beyond confused lol
Old 01-09-2021, 11:11 PM   #24
VisitableSpore9
Member#: 521532
Default GC8 Wiring
Does anyone have access to the full wiring diagram that they could send me? Im currently looking to put my ej20g into a usdm impreza as I cant find a roller gc8 or gf8 as of right now.
VisitableSpore9 is offline   Reply With Quote
$$$ Reward - JDM STI ecu pin diagram and engine wiring diagram- OK $250.00 cash ! alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 01-20-2010 09:49 AM
Looking for a 1998 Legacy GT Wiring Diagram Soarer Subaru Conversions 2 08-18-2008 10:03 AM
Looking for JDM V7 wiring diagram and '01 RS wiring diagram moss Subaru Conversions 1 07-06-2006 10:52 PM
Can anyone email me a 1998 wiring diagram? Jerry Hong Warranty Issues & SOA Problems 1 05-01-2003 12:31 PM
Can anyone send me a 1998 wiring diagram? Jerry Hong Subaru Conversions 3 04-30-2003 12:13 PM
