Welcome to the North American Subaru Impreza Owners Club Friday April 23, 2021
Go Back   NASIOC > NASIOC Technical > FB Series Normally Aspirated Powertrain
View Poll Results: Please report your oil consuption here for the vehicle you own(ed)
2011-14 Forester - Excessive Consumption 13 13.68%
2011-14 Forester - Normal/No Consumption 8 8.42%
2013 Legacy - Excessive Consumption 2 2.11%
2013 Legacy - Normal/No Consumption 4 4.21%
2012-13 Outback - Excessive Consumption 4 4.21%
2012-13 Outback - Normal/No Consumption 5 5.26%
2012-13 Impreza - Excessive Consumption 34 35.79%
2012-13 Impreza - Normal/No Consumption 30 31.58%
Multiple Choice Poll. Voters: 95. You may not vote on this poll
Old 01-20-2015, 12:59 AM   #51
zakowen
Member#: 404144
Just to clarify... SOA considers anything more than 10.7 oz per 1,200 miles (1/3 qt) abnormal. We have been replacing short blocks left and right.
zakowen is offline   Reply With Quote
Old 01-20-2015, 10:21 AM   #52
Kerplunk105
Member#: 165115
07 Impreza
My Moms Forester (2013) is going in next week for shortblock replacement due to excessive oil consumption.
Kerplunk105 is offline   Reply With Quote
Old 01-20-2015, 09:19 PM   #53
casper_actual
Member#: 410557
1998 Legacy GT 5MT
Red
Anyone think the oil consumption issues might be due to newer cars using 0-w20 oil vs. 5w or 10 w of the olden days?
casper_actual is offline   Reply With Quote
Old 01-20-2015, 11:54 PM   #54
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
I may be wrong, but I thought it was due to the bottom piston rings....
left footed whooten is offline   Reply With Quote
Old 01-21-2015, 07:54 AM   #55
Annihilator817
Member#: 296742
'16 STI, '11 WRX,
'96 328i DSP
Its part of the cause for sure.
You can put thicker oil in these motors without harming them. You will just see a very slight decrease in gas mileage.
Annihilator817 is offline   Reply With Quote
Old 01-21-2015, 02:28 PM   #56
neg_matnik
Member#: 132389
Yes, you're right, Subaru issued *four* TSBs (02-143-13R, 02-144-13R, 02-147-13R, 02-145-13R) that were basically about replacing oil control rings for both FB20 and FB25.
But, like Blur125 said, that didn't work so well for all concerned engines.
So, now, Subaru has issued another TSB (02-157-14R) calling for the replacement of the entire short block (IMO, a much better solution).
See the Oppo/Jalopnik post about this: http://oppositelock.jalopnik.com/sub...ion-1600566355
neg_matnik is offline   Reply With Quote
Old 01-21-2015, 03:53 PM   #57
movieman
Member#: 169683
2015 Forester 2.5
Red
Originally Posted by Annihilator817 View Post
You should absolutely expect to have to top off the oil on a brand new car between oil changes. Internal combustion engines burn oil, period.
Civic: six years, and never topped off the oil.
Forester: just did the first oil change, and the oil level was the same as when we got it.
Buick: after fifteen years, we had to start topping off the oil between changes to make up for the puddles it left on the garage floor.
Given most modern engines don't burn oil until you put a lot of miles on them, there's no reason to expect to have to top off a new car engine between oil changes.
movieman is offline   Reply With Quote
Old 01-22-2015, 04:46 PM   #58
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
I'm glad someone else agrees with me.
Blur125 is offline   Reply With Quote
Old 01-27-2015, 11:06 AM   #59
Subarudave09
Member#: 209316
14 XV
Default Oil Consumption Poll
2014 XV build date 01/14
2900-32,500 I had the light come on in between changes. When it first came on at 2900 I was not alarmed, most all new cars burn oil between changes. All my consumption issues seem to have stopped. Have not seen the light since the 32,500. I've never once taken the car to the dealership. I have 43,791 on the car I'm pretty sure she's done burning. I did play with 5w20 and noted 21.3mpg. The oil I've been using since the consumption stopped is Mazda Genuine 0w20 with Moly. My last change 32,500-41,331 nothing burnt or low.
Subarudave09 is offline   Reply With Quote
Old 02-03-2015, 01:55 AM   #60
somejuan
Member#: 409958
I've been following this thread with interest (from afar obviously) and for what it is worth I have a '14 Impreza 2.0 that is now 1500 miles past the first service and there is no indication of oil consumption - my average fuel consumption is in the order of 33 mpg(US).
somejuan is offline   Reply With Quote
Old 02-04-2015, 10:42 PM   #61
Scubarex
Member#: 372996
Agree with both of the above. I had a 1993 Camry with 200k miles that didn't burn oil at all. A maxima with 150k that didn't burn oil at all. Really no one I know outside of the tuning community considers it normal to top off a new car between oil changes.
My 2014 WRX with 13,000 miles on it has burned over a quart in the less than 6000K mi. OCI that the Subaru dealership has me on - a little spirited driving, no racing and vast majority just daily driving.
I'm glad someone mentioned that SOA considers 1/3 qt in less than 1200 miles to be excessive, not sure if I hit that mark or not but will ask the dealership for a consumption test as recommended.
Scubarex is offline   Reply With Quote
Old 02-06-2015, 10:22 PM   #62
CSISAC
Member#: 211687
2014 Impreza 5MT
Satin White Pearl
My oil light came on before 4,000 miles, and turned off after a few minutes.
A week or so later it came on and stayed on, at roughly 4,000 miles. I put an entire quart into the engine and the dipstick was showing the oil level in the middle of the high/low marks.
CSISAC is offline   Reply With Quote
Old 02-07-2015, 12:44 AM   #63
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
so...the light came on....turned off.....you ignored it...it came on again a week later and THEN you did something???????
THIS RIGHT HERE, FOLKS, IS WHY SO MANY OF THESE CAR BLOW THE **** UP
Old 02-08-2015, 02:30 AM   #64
subi400
Member#: 216984
1996 Impreza outback
Green
If you rely on the oil light to come on to tell you when you should add some oil you should not be driving a "car". Basic maintenance means checking the oil in the engine at least once per week maybe twice depending on the miles driven per week. That means "making" time for this 2 minute check. If you had read this entire thread you would of seen that checking the oil in the engine needs to be a priority, period. If you want to keep using a 0w20 oil, then give the Mazda 0w20 full synthetic with Moly a try for a while, it is good stuff.
subi400 is offline   Reply With Quote
Old 02-08-2015, 02:42 AM   #65
subi400
Member#: 216984
Green
Who suggested for you to use the Mazda 0w20 oil? I would be quite the scene to stroll right into a dealership and tell the service department that your oil consumption stopped after switching to a "better" 0w20 oil and that it was from a Mazda dealership...
Old 02-08-2015, 01:36 PM   #66
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
I doubt mazda manufactures their own oils. Its just another brand, relabeled as mazda.
Old 02-08-2015, 02:16 PM   #67
Subarudave09
Member#: 209316
14 XV
I'm not sure who does but their engines are using similar ideas with low friction and 0w20 with no issues. I am a spirited driver.
Edit: Idemitsu manufactures it
Old 02-08-2015, 02:20 PM   #68
Subarudave09
Member#: 209316
14 XV
Old 02-10-2015, 12:44 AM   #69
subi400
Member#: 216984
Green
Thanks for that. I wonder how many other people have tried the oil formulated for mazda engines in their subaru FB NA engines?
Old 02-10-2015, 01:50 AM   #70
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Yeah, hadnt heard any of that, thanks.
Old 02-10-2015, 02:03 AM   #71
Uncle Scotty
Member#: 16200
OK buy Nates beans
ok....I KNOW there has GOTTA BE at least ONE multi brand dealer**** out there....that sells mazda and Subaru
and MAYBE some bright boi in their service department put 2 and 2 together and had a idea and it worked
Old 02-10-2015, 06:33 AM   #72
CVT-FB20
Member#: 389102
2015 Civic Si Sedan
I'll keep using Pennzoil Ultra Platinum. It's number don't look too dissimilar from the Mazda stuff.
CVT-FB20 is offline   Reply With Quote
Old 02-11-2015, 01:34 PM   #73
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
There is one in Roseville, CA, and I believe they share the same service department. I don't recall as I stopped going there...their service dept sucked
Old 02-13-2015, 05:02 PM   #74
03SubyWRX
Member#: 200767
2006 WRX TR
2013 Crosstrek
I figured I'd post up about my mom's 2012 Impreza 5MT base model. Currently sitting at 44,000 miles and using 2.5 quarts between changes (her Subaru dealer did a consumption test and it failed). She also noticed her oil light would come on every so often. When this happened she would turn the car off as soon as it would be safe to do so and would add oil until at the acceptable level. I recommended she keep a quart in her car at all times.
Subaru is replacing the short block for free, no charge to her. Not sure what the warranty is, but I thought it was 3 years on powertrain? Either way I'm glad Subaru is helping her out. Unfortunately, I think she'll be trading it in for a 2.5L equipped OBS as she misses the torque from the EJ.
03SubyWRX is offline   Reply With Quote
Old 02-13-2015, 05:48 PM   #75
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Originally Posted by 03SubyWRX View Post
I figured I'd post up about my mom's 2011 Impreza 5MT base model. Currently sitting at 44,000 miles and using 2.5 quarts between changes (her Subaru dealer did a consumption test and it failed). She also noticed her oil light would come on every so often. When this happened she would turn the car off as soon as it would be safe to do so and would add oil until at the acceptable level. I recommended she keep a quart in her car at all times.
Did you mean 2012 Impreza? Pretty sure the EJ25 was in the 2011, and even then, it wouldn't be a short block replacement, but more likely a head gasket.
