Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 11-01-2005, 05:13 PM   #1
83Rabbit
Member#: 5050
Default Air assist injectors... what are they? whats it do?
How does this system work? What do they do? What are they? etc... The reason Im asking is that I just did an EJ25 swap into my impreza and I dont have this system hooked up yet.... anyone have a diagram of the system for either an EJ18 or EJ25? Or can anyone explain exactly how it works etc...
83Rabbit is offline   Reply With Quote
Old 11-01-2005, 10:04 PM   #2
redwagon
Member#: 2181
2003 Forester XS
Which ECU are you going to use?
If it's a 99+ EJ25 ECU it will throw a code if the solenoid is missing. If it's any other ECU it will not have this 'feature' and so it won't care if the thing is not there. Blank it off, leave it disconnected, whatever.
This thing seems to be some kind of evil uncle that noone wants to talk about...
redwagon is offline   Reply With Quote
Old 11-02-2005, 02:21 PM   #3
AutoAviat
Member#: 77929
2006 Saab 92x Aero
Arctic Silver
During cold start conditions it injects extra air into the exhaust stream to make the emissions appear more cleaner (by adding cleaner air mixture to modify the ratio of bad emissions in exhaust). At least, this is how it worked on my S2000. Once the car is warm I believe it shuts off.
AutoAviat is offline   Reply With Quote
Old 03-01-2011, 05:16 PM   #4
Skidd
Member#: 1853
GC6 Supercharged
STM
Since I've had to research what the Air Assist Injectors on my car are all about to figure out it's affect on Injector Scaling in my EManage Ultimate... I figure I might as well clarify for the benefit of others.
First of all, It's nothing to do with air into the exhaust stream.
The Air Assist system on the 00-01 RS is a system designed to route air from the IAC valve directly to the base of each injector. During idle and high-vac cruise, the Air Assist Soleniod (just to the left of the alternator) will open up and allow a measured amount of air to feed from the IAC to the ports on the side of the intake manifold beside the injectors. The air is fed into the injectors, where it swirls and mixes with the fuel near the pintle. This increases the atomisation of the fuel as it enters the intake and is intended to increase fuel economy.
Skidd is offline   Reply With Quote
Old 01-24-2021, 02:59 AM   #5
sebastian323
Member#: 510671
2006 WRX
Gray
I take it this feature is no longer found in the drive by wire cars since there is no IAC valve?
sebastian323 is offline   Reply With Quote
Trespassers... What are they doing? What should I do? markman Off-Topic 102 04-08-2008 01:42 PM
Pizza stones. What are they, and do they matter for homemade pizza? recipe ideas? plunk10 Off-Topic 39 12-21-2005 05:58 PM
so teh redwings are not playing hockey...what ARE they doing then? The Tree Off-Topic 10 02-23-2005 06:08 PM
what are they doing on route 3? re92 New England Impreza Club Forum -- NESIC 7 05-08-2001 07:39 AM
