Welcome to the North American Subaru Impreza Owners Club Thursday April 22, 2021
Old 01-19-2020, 12:36 PM   #1
Lancaster
Member#: 476041
2014 WRX
Default VA WRX 6 speed into GR/GV details
WRX 6 speed?! No not the famous STI 6 speed, the VA chassis split case 6 speed.
Before we go further someone will inevitably ask why not STI trans and why a weaker WRX 6 speed. First the car is a 2012 WRX GR I picked up for 5000 bucks! Sadly the clutch and 3rd gear we’re toast. Good news I had a full 2015 WRX 6 speed with rear diff and all the shifter box parts and cables I removed from our 2015 that we STI swapped. Also this car will always be stage 1 and not meant to be a power house, it’s a commuter and the 15 wrx 6 speed definitely has better gears for that.
Also because I can do all this work myself there is zero labor cost.
So here it is. There is no fabrication work required. Simply install the 6 speed and rear diff using your 5 speed clutch, axles and driveshaft. The shifter box bolts right into the trans tunnel no problem. Remove your 5 speed trans harness and switches and place them in the 6 speed. Have your tuner update your gear ratios and enjoy! I added a cheap shifter stop and cable bushing ( not short shifter) and it’s honestly not bad, the shifter stop improves the feel of 1-2 and 5-6 drastically!
Sorry I took so little pics. It’s my daily and last weekend was crazy lol.
Lancaster is offline   Reply With Quote
Old 01-31-2021, 01:03 AM   #2
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
wonder if this will bolt up in a GD chassis ???
murrdogg24 is online now   Reply With Quote
Old 01-31-2021, 12:18 PM   #3
ether947
Member#: 297799
2003 WRX
EJ207 version 8
Interesting. I just assumed the split case 6MT was longer because of the extra gear.
ether947 is offline   Reply With Quote
