Welcome to the North American Subaru Impreza Owners Club Saturday April 10, 2021
Old 12-14-2011, 11:06 AM   #251
ogintheback
Member#: 99163
^thank you for that info. Maybe I had better stay on the "beaten path". Anyone have thoughts on this one?
http://prosportgauges.com/oil-catch-can-.aspx
ogintheback is offline   Reply With Quote
Old 12-14-2011, 03:43 PM   #252
sorrowfulkiller
Member#: 170439
I <3 Lamp
I think I've found a good way to vent the catch cans without having to resort to using exhaust scavenging.
First off you need an oil catch can with 3-4 ports, obviously on hybrids and 2.5L engines keep the un-baffled vents connected to each other. connect the baffled head vents together into the catch can, run a single line from the baffled vent on the crankcase into the catch can.
Now this is where it gets different if using a 3 port catch can have a T-fitting on the top of the catch can, one side goes to the pcv valve as normal, the other side goes to a check valve that opens when boost is on the catch can side, the other side of the check valve is connected to an air filter so it is filtered out into the atmosphere. In a 4 port can you will obviously just run these two exit ports separately. Alternatively you can run the atmospherically dumped port back into the exhaust with a weld in fitting to create a venturi effect.
sorrowfulkiller is offline   Reply With Quote
Old 12-23-2011, 05:52 PM   #253
Tut4u2
Member#: 40424
05 STi
I run two of those...no issues and they work.
Tut4u2 is offline   Reply With Quote
Old 01-05-2012, 09:46 PM   #254
2002Dubx
Member#: 177337
2002 WRB Bugeye
Pilot and Xterra
I've been searching the introwebz for longer than it takes to install 10 catch cans. Can anyone just post a simple diagram or picture of proper before and after pics? Ones that simply explain what hoses need to be removed, and what needs to be connected to the new catch can please? I have a 2002 wrx and my catch can looks like the one below. Please help!
Thank you,
Frustrated Person
2002Dubx is offline   Reply With Quote
Old 01-06-2012, 03:40 PM   #255
sorrowfulkiller
Member#: 170439
I <3 Lamp
I'll post a link later when I get home but aside from that look at my post above
Old 01-06-2012, 06:35 PM   #256
2002Dubx
Member#: 177337
2002 WRB Bugeye
Pilot and Xterra
Thank you! I just need a visual. Most links/were old and didn't work or have been deleted.
Old 01-07-2012, 09:08 AM   #257
sorrowfulkiller
Member#: 170439
I <3 Lamp
If you look up diy hyundai sonata catch can on google there's a good diy to make the can you have function better.
Old 01-08-2012, 10:02 PM   #258
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Please note that many catch cans sold in the market do not have filter inside, which makes it pretty much useless.
Old 01-09-2012, 01:11 AM   #259
amalgrover
Member#: 183480
it doesn't even really need a filter...as long as it has some kind of baffle to separate the air from the oil vapor. take the peterson or element (same product just different sticker on it) for example. it works great, and all it uses is some baffling using pieces of aluminum...but you are completely correct that the cans with nothing in there do close to nothing, especially since they typically only use 3/8 inch hoses.
amalgrover is offline   Reply With Quote
Old 01-24-2012, 07:44 PM   #260
quick108
Member#: 57664
It's nice when you can add as much media as you want.
http://store.radiumauto.com/index.ph...id=15&parent=5
But too much can cause a flow restriction.
quick108 is offline   Reply With Quote
Old 02-06-2012, 07:20 AM   #261
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
The center port on the 2.5 block is unbaffled. This means raw oil (not oil vapor) is coming out of that port. You don't want to run that into a catch can unless you want to drain it every other day or do. I just went through all of this.
The proper way so solve the hybrid setup is to weld an additional bung to each valve cover and run the center port through a "T" to each valve cover. The pcv port goes to the catch can then back to the oem ports on the valve cover.
Check my build thread for some pics of how I solved mine.
5lipstream is offline   Reply With Quote
Old 03-09-2012, 12:02 PM   #262
SubaruWrxNewb
Member#: 236017
How often I should I drain my catch cans?
SubaruWrxNewb is offline   Reply With Quote
Old 03-09-2012, 12:06 PM   #263
Prosport Gauges
Member#: 124196
Do you have a level indicator? UNless your motors going through oil like crazy, you shouldnt have to drain but once a year.
Prosport Gauges is offline   Reply With Quote
Old 04-09-2012, 10:00 AM   #264
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
I just read every post. Anybody have a schematic of a dual catch can setup without an inlet?
wgr73 is offline   Reply With Quote
Old 04-09-2012, 11:30 AM   #265
amalgrover
Member#: 183480
not sure if what you mean by "without an inlet", but if you mean without lines going to the turbo inlet then here ya go (found this on page 3)...basically take the two places on the inlet where those lines would have connected and cap them off. then the catch cans will just vent to atmosphere...
Originally Posted by wrxbox View Post
if you mean without an after market inlet, then it would be identical connections to this picture.
fyi, some of the flow direction arrows on this image are incorrect, but the routing of all the lines is correct and that is why i used it.
Old 04-24-2012, 11:32 AM   #266
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Without an inlet, I meant filter directly on the turbo. Thanks! Sure ya that would work. I was trying to make sense of that setup.
Old 04-24-2012, 11:55 AM   #267
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
where's the thread? can't find it
Hyper is offline   Reply With Quote
Old 04-25-2012, 08:47 AM   #268
WheredUgo?
Member#: 207304
2006 wrx wagon
steel gray
How to properly filter your crankcase and cylinder head evacuation system :
http://www.moroso.com/catalog/images/85484_inst.pdf
WheredUgo? is offline   Reply With Quote
Old 04-25-2012, 09:59 AM   #269
WheredUgo?
Member#: 207304
2006 wrx wagon
steel gray
This is not correct, every engine is different, some evacuate moderate amounts of vapor and some very little. Your cans should be drained on a regular basis especially if the car is seeing track time. If its a modified street car it depends on how much fuel blow by, oil vapor and condensation is circulating in the engine. The design of your catch can also comes in to play. Lets look at it this way, if the catch can is designed simply for ventilation it will most likely require less draining, if its a purpose built product it will require much more attention because it is going to be separating all gasses that are passed thru it and will yield much higher collection rates.
Old 10-05-2012, 12:47 AM   #270
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Sorry if this was already asked somewhere but I did not see this anywhere on the first page of this FAQ. Besides keeping things oil free what are the power gains if any from keeping oil out of the system? And just how much can it lower effective octane rating? I understand it will help the intercooler perform better and lower the charge temperature. I would also think all of these points have an additive effect. I understand that all of this depends on a lot of variables. But has any of this been quantified at all? At least some ballpark range? Best/worst case scenario? What about an otherwise stock car?
0BlueSTi4 is offline   Reply With Quote
Old 10-05-2012, 11:29 AM   #271
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Actually this has zero impact on Intercooler performance. The objective is to prevent crankcase and valvetrain oil vapor from re-entering the intake tract and lowering the effective octane rating of the combustion charge. It's unlikely the effect can be quantified, the objective is not necessarily to "increase performance" but to prevent detonation.
At the very least it's a "good idea" for the general health of your engine. At best you're maintaining an octane rating as close as advertised to the fuel you're running.
mechatricity is offline   Reply With Quote
Old 10-05-2012, 05:11 PM   #272
0BlueSTi4
Member#: 98955
2011 WRX Hatch
And you know this how? I'll just refute your answer by quoting directly from this FAQ:
2) You've got an intercooler- by definition an intercooler is part of your intake tract, and It's generally agreed that an intercooler which is internally coated with oil won't be as effective as one that's clean.
Please, somebody that has something valid to contribute and has at least read this FAQ.
Old 03-01-2013, 08:19 PM   #273
TonyDavies
Member#: 347014
Read on the first page that to do it properly ypu need to catch cans. One for each different way of installing them.
Question: can i replace 2 seperate catch cans with one 4port hyperflow can?
TonyDavies is offline   Reply With Quote
Old 03-02-2013, 01:17 AM   #274
2002Dubx
Member#: 177337
2002 WRB Bugeye
Pilot and Xterra
Easiest way to run it is below. It's not all that hard really.
Old 03-03-2013, 01:37 AM   #275
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
do NOT confuse and/or mix up the 2.0 and 2.5 motors here
they ARE DIFFERENT
Catch can maybe reduce oil use? leighton1245 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-05-2010 06:38 PM
Oil catch can...or catch canS?? BoXinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-28-2009 05:01 PM
Installed OBX catch can... (another catch can thread) txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-10-2008 01:00 AM
WTT(HR): Greddy Oil Catch Can with Perrin Oil Catch Can scooby_wooby MAIC Private Classifieds 1 03-24-2008 09:01 PM
WTT: Cusco catch can for a perrin catch can sti charles Engine/Power/Exhaust 10 11-29-2007 01:04 AM
