Welcome to the North American Subaru Impreza Owners Club Saturday April 10, 2021
Old 08-05-2016, 12:50 AM   #301
ITS_SOY
Member#: 452026
2006 Impreza Wagon
Originally Posted by joek92 View Post
Saw the perfect configuration at IA and now running it.
Dual can
1. T in from valve cover breathers, out to turbo inlet
2. In from crankcase, out to pcv
This requires relocating the pcv itself. Unfortunately there are a bunch of random hose diameters. But it's the only way to filter everything.
Would you have pictures of this setup?
ITS_SOY is offline   Reply With Quote
Old 08-09-2016, 04:21 PM   #302
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Yes, behold this ms paint masterpiece.
joek92 is offline   Reply With Quote
Old 08-09-2016, 10:23 PM   #303
Prosport Gauges
Member#: 124196
That's impressive
Prosport Gauges is offline   Reply With Quote
Old 08-16-2016, 11:32 AM   #304
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Originally Posted by Prosport Gauges View Post
That's impressive
Thank you. Can't take credit for the idea, saw it on a white hawkeye at Import Alliance Atlanta. Smart guy.
Old 08-18-2016, 03:15 PM   #305
Jonahhaddad1
Member#: 396155
2006 Impreza WRX
Looks like the main benefit of that system is that the pvc valve is after the catch can which would keep the pvc valve cleaner?
Jonahhaddad1 is offline   Reply With Quote
Old 08-19-2016, 11:44 AM   #306
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Because the pcv has 2 outlets, this is the only way to filter both using one can.
That allows the second can to be used for valve cover breathers or whatever.
Old 10-15-2016, 08:33 AM   #307
jj94auto
Member#: 203929
Could someone help me create a catch can setup for an 06 ez30d Tribeca? I know it is naturally aspirated. I am getting a pretty bad plume of blue smoke at startup and would like to at least eliminate that.
I know that if I am getting blowby I have much more to worry about bla bla bla.
Anyways, could you all please help me with a setup?
Thank you!
jj94auto is offline   Reply With Quote
Old 10-19-2016, 04:40 PM   #308
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
A catch can won't help start up smoke from worn rings or valve guide seals.
All an NA car needs is a single two port can between the PCV line and intake manifold.
Hoon Goon is offline   Reply With Quote
Old 10-23-2016, 01:56 PM   #309
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Correct, or between the block and pcv if it has 2 outlets. Sorry that might be hard to understand without pics.
Old 10-26-2016, 06:49 PM   #310
jj94auto
Member#: 203929
Thanks guys. There are 2 ports on it. My research shows that all I need to do is install 2 catch cans. One coming off the PCV to wherever it goes, and one coming off the breather right next to the PCV to wherever it goes.
Under what circumstances would a catch can stop smoking at startup? I have read that it can, but just wasn't sure *when*. I mean the cans will at least serve as a nice diagnostic tool.
Old 11-22-2016, 04:40 PM   #311
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
If there is a bunch of oil in the throttle body or intake tubes. Which means it would either come from crankcase or valve covers.
Now, I don't know what problems cause the oil/coolant vapor concentration to be higher in either. I assume that something is getting into the combustion chamber, so a catch can would rule out anything coming through intake valves. The other points of entry are piston ring and head gasket. My old sti smoked on start up, cyl 3 had 90 psi compression.
Recommend doing a leak down test. Not too hard and will properly identify the issue.
*whatever is leaking, it seals after the engine warms up... thermal expansion. Hope that helps.
Old 11-22-2016, 06:52 PM   #312
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
anyone have any photos of a dual catch can set up on car that have no PCV valve ? do you just hook 1 to the crank case to intake then the other 1 to the breather ports on the heads and intake ? thank you
bmxhotsauce is offline   Reply With Quote
Old 12-12-2016, 11:04 PM   #313
jj94auto
Member#: 203929
It does help.
Well I finally got around to installing 2 Ebay VMS style baffled catch cans. The one from the PCV is filling up very quickly, but it *seems* to have stopped the blue smoke at startup so ignorance is bliss for me.
Any way to run the drain of the can via tubing outside of the frame so that it doesn't fill up so fast...strictly for offroad use...COUGH COUGH or alternatively outside the frame with a valve so that I could empty it easier than having to dismount it every 300 miles?
Old 12-13-2016, 04:28 AM   #314
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
on right, there is this thread..
has anybody tried to drain a catch can/aos into the turbo oil drain?
Hyper is offline   Reply With Quote
Old 01-06-2017, 07:19 PM   #315
methaddict
Member#: 159738
2004 WRB STi 620awhp
OFCD V3, FR TS, BW8374EFR
I'm using the Radium Engineering standard catch cans. One hose from the crank case to one catch can. A hose on each breather port of the left and right valve covers T'd together to another catch can's inlet port using the oem steel pipe but a T fitting near the windshield wiper reservior. Then I have both exit ports from both cans Y'd together ran under the car all the way to the rear next to the muffler. On the dyno at high boost, a blowby gunk spits out of the end of this hose.
methaddict is offline   Reply With Quote
Old 02-02-2017, 09:07 PM   #316
kris142b
Member#: 450777
Sedona Red Pearl
Originally Posted by 2002Dubx View Post
Easiest way to run it is below. It's not all that hard really.
what is the direction of flow for that setup across the crankcase vent cross over tube
kris142b is offline   Reply With Quote
Old 04-27-2017, 11:09 AM   #317
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
It does help.
Don't drive with the drain open or it won't pull a vacuum & you'll have a post-MAF leak. (unless I took it wrong)
Vacuum sucks out fumes when there isn't enough pressure to push them out.
Old 05-10-2017, 07:14 PM   #318
pcampbell
Member#: 437670
2005 2.5 SC OB
I'm trying to figure out how to set this up on a supercharged EJ253 .
Obviously the 2 stock breathers that go into the intake can't be there because they would be pressurized. I assume these go to a catch can (vent/intake to/from atmosphere OK?). I've read that this air needs to be metered going into the breathers, so how can we do this with a blow through supercharger?
What about the PCV.. Do I need a separate catch can that sits in between the PCV and the intake manifold?
Will the PCV even work properly, since it will mostly be operating under boost instead of vacuum?
help!
pcampbell is offline   Reply With Quote
Old 01-16-2018, 08:42 AM   #319
Booki
Member#: 465246
2009 Forester XT
I have a 2009 SH XT Forester.
Picked up two catch cans for a dual setup, but got a bit confused on how to actually plumb it up correctly.
There is a mishimoto YouTube video, but it confused the hell out of me....
Has anybody installed a catch can and can give me some pointers or advice on how to plumb them up ?
Booki is offline   Reply With Quote
Old 01-16-2018, 03:15 PM   #320
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
V4 GF8 White
Lightbulb
As you might imagine, there is a ton of mis-information on catch can installation on the 'net. It's apparent a lot of people have no idea how the PCV and breather system work.
I installed two oil catch cans on the EJ20K in my '98 JDM Impreza STi wagon. I'm very pleased with how well it all appears to function. I don't know how different your Forester's breather system might be from what I have, but you can have a look at this thread HERE where I was involved in a discussion on this topic.
Last edited by Vancouver98STi; 10-25-2020 at 11:04 PM. Reason: Replaced missing image
Vancouver98STi is offline   Reply With Quote
Old 01-27-2018, 03:13 AM   #321
fleezy
Member#: 436768
2004 WRX
do you need 3/8s fittings on the catch can?
fleezy is offline   Reply With Quote
Old 02-03-2018, 12:56 AM   #322
Vancouver98STi
Member#: 459287
V4 GF8 White
Lightbulb
I found this image online of what I used, Watts A-385A (1/2" ID x 3/8" MIP)... which meant I also had to re-tap the threads (3/8NPT18) in the catch cans.
Last edited by Vancouver98STi; 10-25-2020 at 11:06 PM. Reason: Replaced missing image
Old 03-17-2018, 10:05 PM   #323
KCRS01
Member#: 466673
2009 STi
Just quick question. if i were to vent a catch can/air oil separator i would need a tune right since im still using MAF? but when i switch to Speed density i wouldnt need one at all?
KCRS01 is offline   Reply With Quote
Old 03-18-2018, 10:57 PM   #324
Vancouver98STi
Member#: 459287
V4 GF8 White
Question
Originally Posted by KCRS01 View Post
if i were to vent a catch can/air oil separator...?
What's the benefit of venting a catch can/air oil separator?
Old 03-26-2018, 10:52 PM   #325
KCRS01
Member#: 466673
2009 STi
when you use a closed loop system the oil just recirculates in the system, meaning, if it has dirt/contaminants it just go back to the engine.
while vent to atmosphere AOS vents the oil going to the pipe and going to the street. the dirty oil in the system is then completely removed and not recirculated.
Catch can maybe reduce oil use? leighton1245 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-05-2010 06:38 PM
Oil catch can...or catch canS?? BoXinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-28-2009 05:01 PM
Installed OBX catch can... (another catch can thread) txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-10-2008 01:00 AM
WTT(HR): Greddy Oil Catch Can with Perrin Oil Catch Can scooby_wooby MAIC Private Classifieds 1 03-24-2008 09:01 PM
WTT: Cusco catch can for a perrin catch can sti charles Engine/Power/Exhaust 10 11-29-2007 01:04 AM
