#76 |
Member#: 99573
SCIC
Vehicle:2015 FXT SWP |
![]() I have 2 greddy style catch cans, what kind of element do you guys suggest I put in them? I'm weary of putting stainless steel wool inside of them because it might break up and get sucked into the engine.
#77 | |
Member#: 115479
Vehicle:2000 FF pearl |
![]() Quote:
Catchcans experience a drop in pressure, but I don't believe that vapor is "rushing" through them. I would be more weary of steel wool because water moisture will cause it to oxidize and turn to junk. I would also avoid copper wool because it acts as a catalyst to oil and it sludges up in your catch can. |
#78 | |
Member#: 99573
SCIC
![]() Quote:
#79 |
Member#: 115479
![]() That is one thing I have wondered about, but I have worried about the temps of the oil vapor.
I like the idea of stainless mesh because it holds its shape and doesn't bunch up like softer materials such as green scotchbrite pads, and loofahs ![]() It is important to keep whatever you put in a catchcan loose. If it bunches up, then it blocks the path of the oil vapor and defeats the normal function of the PCV system. |
#80 |
Member#: 102922
TXIC
Vehicle:2012 WRX Wagon |
![]() In reference to using the air compressor filter setups like this:
http://www.pbase.com/rsrock/oil_catch_can Can I just buy two of those and the appropriate fittings and just run them inline between PCV/turbo inlet and crank case/inlet? Is it really necessary to run more lines around the engine bay? I would just like to cut the correct amount from the current lines and run these little filters inline to catch the oil. Please let me know if this would be a wise course of action. |
#81 |
Member#: 58294
Vehicle:2004 WRX / 1998 Foz SoCal F4 #20 / Area1320 |
![]() anyone have the cusco wrx specific catch can installed? i need some flippin help on this one..i have that other hose from the can just kinda sitting there not going into anything..that cant be right...can it?
#82 |
Member#: 85938
NESIC
Vehicle:2004 WRX WRB |
![]() As a filter element i used a lawnmower air filter. Cut it a little oversized so it fits tight. It works great. It is amazing the crap that comes out of the can.
#83 | |
Member#: 102922
TXIC
![]() Quote:
#84 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
![]() I'm using two of those filters but I extended the lines a little bit. I don't see why your idea wouldn't work, as long as the filters aren't mounted sideways or upside down.
#85 |
Member#: 116103
International
Vehicle:2006 OBP WRX STI Blouch 2.5 XTR |
![]() This is a set up that I did on my 06 WRX STI.
#86 | |
Member#: 34882
Vehicle:2003 WRX Stage 4 |
![]() Quote:
#87 |
Member#: 32459
Vehicle:02 WRX VF34 (SOLD) Junior Tuned 301whp |
![]() you can buy a set of hoses for around $70. They come ready to be installed.
#88 |
Member#: 7891
RMIC
Vehicle:2005 wrx STI Aspen MF white! |
![]() more pics ^^^^
#89 | |
Member#: 34882
![]() Quote:
#90 |
Member#: 59136
BAIC
Vehicle:04/5 APRWidebody STi 500/500 - Snail Tuned |
![]() I too would like to know where that TRICK set of hoses came from...
![]() But I wonder if they'll clear a 20G..... ![]() |
#91 | |
Member#: 75856
Vehicle:2005 WRX WR Blue Pearl |
![]() Quote:
![]() http://www.iwsti.com/forums/showthre...dual+oil+catch I'm not sure why this guy isn't selling these on all subie forums. From what ppl are saying its a quality product and he will do custom fabrication. |
#92 |
Member#: 59136
BAIC
![]() Thanks mang!
#93 |
Member#: 7891
RMIC
![]() seriously... product of the year...
#94 |
Member#: 96204
W. Canada
Vehicle:2013 STI GR White |
![]() I lose about 1 liter of oil every 800 miles. I had an oil analysis done and all is good. Power is good. Everything seems fine. (COBB stage2 with gutted DP) No oil leaks. Really don't know where the oil is going except the PCV system.
Will a catch can like this be beneficial for my daily driver? |
#95 | |
Member#: 86986
![]() Quote:
#96 |
Member#: 40983
Vehicle:2004 STI Blue |
![]() I am looking for the PCV valve and plastic fitting part number for a 2004 STi
Thanks' |
#97 |
Member#: 25859
South East
Vehicle:1965 MGB yellow 2008 Black Miata |
![]() good read
#98 | |
Member#: 74268
NESIC
![]() Quote:
I'm trying to get to the bottom of the mystery as to whether i need one or two cans... |
#99 | |
Member#: 42376
RMIC
Vehicle:2006 92x Aero |
![]() Quote:
The above is the conclusion that my research and reasoning led me to. It's entirely possible that I'm mistaken. Maybe you can get some clarification as to why this would be true for the 2.5's and not the 2.0's? |
#100 | |
Member#: 88501
BAIC
Vehicle:2011 WRX Hatch Dark Grey |
![]() Quote:
Not that I'm going to do it, but if one was ONLY to put a catch can on one of the lines (either crankcase or valve, is that right?) then which would be the prefered one? aka... which one spits more oil? |
Catch can maybe reduce oil use? | leighton1245 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 18 | 06-05-2010 06:38 PM |
Oil catch can...or catch canS?? | BoXinWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 07-28-2009 05:01 PM |
Installed OBX catch can... (another catch can thread) | txl146 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 09-10-2008 01:00 AM |
WTT(HR): Greddy Oil Catch Can with Perrin Oil Catch Can | scooby_wooby | MAIC Private Classifieds | 1 | 03-24-2008 09:01 PM |
WTT: Cusco catch can for a perrin catch can | sti charles | Engine/Power/Exhaust | 10 | 11-29-2007 01:04 AM |
