Welcome to the North American Subaru Impreza Owners Club Tuesday April 13, 2021
Old 03-13-2010, 11:41 PM   #201
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Dak Jones the shop closed. Like for good?
sackytar is offline   Reply With Quote
Old 03-14-2010, 09:59 PM   #202
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Originally Posted by AlfaShoppy View Post
Thanks for all the info.
Here in The Netherlands w/m injection is relativity 'new'.
So I was forced to read all the info in English hihi.
I myself am driving a Alfa Romeo 156 1.9JTDm 16v with massimo chiptuning from Squadra and I am experimenting with the standard set of Coolingmist for the small diesel.
Again much thanks for all the info it was really helpfull.
Crazy to see people from all over getting info from this thread. Glad you guys enjoy it.
-Andy
DonkeyPunch is offline   Reply With Quote
Old 07-25-2010, 11:26 PM   #203
parker.eakin
Member#: 202538
2006 impreza 2.5i
white
ok so most people seem to run water/meth injection kits for forced induction motors. is it beneficial for N/A motors?
parker.eakin is offline   Reply With Quote
Old 08-09-2010, 12:22 AM   #204
02WRX<3
Member#: 183230
2006 STi
Best thread on this forum. Thanks for this.
02WRX<3 is offline   Reply With Quote
Old 09-01-2010, 02:46 PM   #205
sti400hp
Member#: 256556
Default meth $
How much do these systems usually cost?
sti400hp is offline   Reply With Quote
Old 09-01-2010, 02:50 PM   #206
sti400hp
Member#: 256556
Default meth ?
will meth go bad after a certain period of time?
Old 09-01-2010, 02:51 PM   #207
sti400hp
Member#: 256556
Default meth cost
how much is meth per gallon?
Old 09-02-2010, 10:46 PM   #208
bcblues
Member#: 17256
18 Outback
on the road....
depends on where you live. I was getting it from $3 - $5 a gallon bulk at the local speed shop. Much higher if you need to buy containers that are prefilled.
bcblues is offline   Reply With Quote
Old 09-03-2010, 07:16 AM   #209
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
methanol is a high concentration alcohol. as such it is hydrophilic, meaning it will tend to attract/absorb vaporized water from the air.
a VERY well sealed all metal container will probably last a long time, but not forever. the only way to really tell is to do a specific gravity test to determine % alcohol content.
in any event, the rate at which it absorbs water is proportional to how pure it is... 100% alcohol will IMMEDIATELY become diluted, whereas 50/50 will take far longer (weeks if not months) to drop to 49/51. another big factor is your relative humidity--if the air is very dry, the process slows down and vice versa.
hth
ken
Old 09-03-2010, 04:41 PM   #210
bcblues
Member#: 17256
18 Outback
on the road....
If you are mixing with water for injection purposes, or even using straight as a secondary fuel, I would not worry about it as long as you are storing it in a reasonable manner and using it within a reasonable time frame. The amount of water it will attract in a sealed container (even plastic) is probably not enough to worry about, as I expect you could not even see the differences in power output, afr, or egt.
Old 09-08-2010, 01:36 AM   #211
cb41
Member#: 215053
2014 WRX
Satin White Pearl
Great information! Now just to decide which kit to go with...
cb41 is offline   Reply With Quote
Old 10-12-2010, 04:49 AM   #212
Indica
Member#: 260596
Wow... its really great.
Indica is offline   Reply With Quote
Old 10-25-2010, 02:05 AM   #213
kirbwrx
Member#: 110450
2007 Spec.b Refugee
284hp 320tq Cobb Tuned
Will you notice a bigger power difference with meth/water injection on 91oct or 93oct? I guess what I am asking is, does meth have a max oct boosting capability regardless of the octane used?
Example: (I know not exact numbers) Meth injection = 100oct regardless so with 91oct it increases oct by 9oct but only increases by 7oct for 93oct?
Or: Meth increases octane by 10, so 93 becomes 103 and 91 becomes 101?
kirbwrx is offline   Reply With Quote
Old 11-07-2010, 10:44 AM   #214
oldman_sti
Member#: 235990
04 STI
04, 06, 08 (STI)
Does this system works with Q16 ?
or
Is this only a system to be used while on pump gas ?
oldman_sti is offline   Reply With Quote
Old 01-02-2011, 12:25 PM   #215
scoobyshahin
Member#: 204420
07 20g'd meth fed
hi there i have had a water meth kit for quite some time now and in the begining i was having problems were if i went out for a drive and sprayed it and came back the next time i went to start my car it would barley start so i purchased a selanoid that made so it opens a valve to spray in boost but when you let off it closes so that nothing drips into your engine from the intercooler pipe going into your intake manifold recently my car has been begining to have that problem again even though i have the selanoid still there any reasons you can think of that would cause this?
scoobyshahin is offline   Reply With Quote
Old 01-03-2011, 01:36 AM   #216
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
that just gave me the biggest headache ever ^
Shahin, im not sure what it is as i have not had experience with methanol kits. But if it gets worse you can hydro lock your motor. Better check to make sure the kit was installed properly.
bhhamblin is offline   Reply With Quote
Old 04-25-2011, 03:28 AM   #217
papanovemberwhiskey
Member#: 280922
does anyone know of shops in norfolk that can remove a kit? my car came with one and i dont want to worry about everything since i dont fully understand the kit or what to watch out for. for me its more then i want to worry about
papanovemberwhiskey is offline   Reply With Quote
Old 07-02-2011, 11:11 AM   #218
crazibella
Member#: 287285
2011 subaru
sti
i just bought the snow performance meth kit for my 2011 sti i have installed it but i dont know where i should tap into... any suggestions????
crazibella is offline   Reply With Quote
Old 08-14-2011, 12:28 PM   #219
panda_sti
Member#: 283499
Nice article
panda_sti is offline   Reply With Quote
Old 12-12-2011, 08:58 AM   #220
florotary
Member#: 281355
2004 STI
OK I have been reading through some of the posts but way too many to read them all. I have been contemplating going with a wat/Meth kit for a while. Mainly after my car was tuned cause I want a little more Power. I'm just curious if I would benefit from putting on a kit. Here is my current list of mods:
K&n intake
MBC
Invidia dp
Alexis gt-spec exhaust
Cobb AP with dyno tune
From my understanding I would have to have the car retuned for the Meth kit. Is it worth getting or should I wait till later IF I decide to do rotated setup. Thanks
Its an 04 STI currently 312whp and 318tq
florotary is offline   Reply With Quote
Old 01-08-2012, 10:47 PM   #221
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
K&n intake
MBC
Invidia dp
It's worth it in the fact that you will obviously gain power due to the volumetric effieciency that water/meth adds. I see that you don't have a aftermarket tuner system IE Accessport, ECUtek, openECU, in your mod list. Do you plan on adding something along with that water/meth? You are going to need to, as you car will not be able to handle just installing water/meth without tuning for it. You will be extremely rich without tuning for it. Let me say this though, with good tuning and good monitoring, it is way worth it, if you are looking for power. I picked up somewhere around 40 hp/40ft/lbs on my first water meth tune. After I did some more supporting mods and a turbo change it got even better. But you have to make sure the tuning is good, and you have a good set of failsafes in your system (most good systems have these options now), so you get the most out of your tune, and it is safe.
Old 01-08-2012, 11:14 PM   #222
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Nevermind, I just saw AP tune. It is going to pay off big time when you go rotate mount.
Water Meth will make that big turbo's air charge much more efficient, and you will be able to push the tune further...the thing you have to think about at that point maybe a built motor.
Old 01-12-2012, 07:25 PM   #223
florotary
Member#: 281355
2004 STI
Thanks for the reply. I didn't see it till now. Didn't get an email or anything. I'm wanting to get a built motor. Ill probably talk with SR in Tampa since they did my tune and see what they would charge to get me a built motor. Just need to decide what Power range I'm looking for. Ill probably look into doing Meth setup and tune for it then later do the the motor and rotated. I have to get my rx7 finished before I put anymore money into my STI. Gota do paint, haltech,suspension and wheels on it before I do anything else
Old 02-28-2012, 07:37 PM   #224
DhaRmic
Member#: 311884
Good thread very usefull stuff here.
DhaRmic is offline   Reply With Quote
Old 06-13-2012, 04:21 PM   #225
Webs1007
Member#: 315584
Good Write Up!!!
Webs1007 is offline   Reply With Quote
water / methanol injection kit -new or used blazin sti Private 'Wanted' Classifieds 3 05-27-2006 08:01 PM
Water/Methanol Injection or Race Fuel or Both ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 06:35 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 05:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 04:51 PM
