04-22-2016, 12:22 AM | #1 |
Member#: 424972
2013 wrx doing 2008+ sti tranny swap
Anyone here done this for the 2008+ above...I've searched thru the forum and Google see a lot of swaps made to the previous years but not to an 08+ I have a 2013 wrx and wanting to do a tranny swap currently looking into buying a 2011 sti swap without the sti hubs I'm wanting to keep my bolt pattern and already have front and rear brembo upgrade Not interested in upgrading the 5speed with ppg gears already making 650whp on the stock 5speed with Moore blast plates maxed out the fuel pump going to drop in a 2nd pump raise the boost make whole lot more My question is what all would I need and will the 2011 sti axles fit on my 2013 wrx with my 2013 wrx hubs
04-22-2016, 11:41 AM | #2 |
Member#: 126131
SCIC
Vehicle:11 wrx sedan black pearl |
good thing you asked this question since its never been discussed before..
04-22-2016, 11:43 AM | #3 |
Member#: 97135
NWIC
6 speed axles will not fit 5 speed hubs, and 5 speed axles will not fit the 6 speed.
custom axles, or the entire hub conversion (which isn't a bad idea). 650hp and asking these questions? talk to the tuner or shop who built the car. |
04-22-2016, 12:16 PM | #4 |
Member#: 344329
Vehicle:2008 Wrx, 6mt |
Huh? The STI axles will work if you put in the R180 along with the 6mt...
04-22-2016, 01:51 PM | #5 |
Member#: 428001
South East
Vehicle:2014 WRX 603/520 Silver |
That's also what I have been told by the people building my car. He mentioned some minor customization of the STI axles to fit, but said all we would truly need is the trans, r180 diff, and the axles. (and my car is being built for 700+hp with the option to go further if desired)
04-22-2016, 07:25 PM | #6 |
Member#: 424972
Can you run the car without the dccd controller? Pros and cons
04-22-2016, 08:48 PM | #7 | |
Member#: 424972
The fronts fit 100% The rear due to the r180 diff being different size I believe not unless you do like a hybrid sti axle with the inner being sti and swapping the outer with the one off the wrx so it will mate with the 5×100 hubs of the wrx |
04-23-2016, 02:11 PM | #8 | |
Member#: 207614
South East
Vehicle:2008 WRX Hatch VF52d SSM |
04-23-2016, 02:55 PM | #9 |
Member#: 344329
04-23-2016, 08:50 PM | #10 | ||
Member#: 97135
NWIC
The 5x100 and 5x114 hubs have different spline counts. |
04-24-2016, 11:14 AM | #11 | |
Member#: 207614
South East
http://forums.nasioc.com/forums/show...3#post39696583 Last edited by subezero; 04-24-2016 at 11:19 AM. |
04-24-2016, 08:44 PM | #12 |
Member#: 424972
Thanks for the info and link this some good info for everyone!
04-24-2016, 08:48 PM | #13 |
Member#: 424972
Is there a way to tell if the viscous coupling inside the center diff on a 2013 wrx 5speed is bad other then clunking on sharp turns? I started to experience clunking noise after about 25-30min driving highway basically when fluids get up to temp and warm and during turning doing circles in a parking lot either way. when first started cold doesn't do it?
04-24-2016, 08:50 PM | #14 |
Member#: 424972
I already drained the transmision fluid dropped the driveshaft and pulled out the viscous coupling inside the center diff
04-24-2016, 09:19 PM | #15 |
Big Ron
Super Moderator Member#: 18062
You are WAY out of your comfort zone here. You need to read the threads stickied at the top of this forum as if you think you have too much power for PPG then you have too much power for a 6MT too. If you want REAL help and plan on making this much power, you need to talk to REAL professionals like the ones at www.andrewtechautomotive.com and stop grasping at straws.
04-24-2016, 11:26 PM | #16 |
Member#: 424972
Sorry but no where near "out of my comfort zone" im not your regular bob down the street i worked as a tech for years I do all the work on my cars the only reason I won't put ppg gears in my 5speed is because it's a 5speed personal preference I rather have the 6speed never said I don't plan to put ppg gears into it later on
04-25-2016, 07:39 AM | #17 | |
Member#: 344329
I have seen ONE post where a guy used the 2008+ sti axles on a narrow body. But just one post, so who knows. 2011 widewbody's are good to go. 2008+ wrx outer(wheel side) are the same as the STI. It's the R160 vs the R180 that's different. The R180 is bigger where the axles plug in. (It also has a different pinion flange, but those can be swapped) When I put a 6mt in my 2008 WRX, I used the stock R160 & rear axles for a while. I had a R180 sitting in my garage, I just took the pinion flange off & bolted it to the R160. (Using the STI driveshaft) When I put the R180 in, I had DSS make me axles. If you have a 2011+ wrx, you can use 2008+ STI rear axles IF you put the R180 in. If you leave the R160 in, you can obviously use the wrx axles, just change to the R180 pinion flange & STI driveshaft... Last edited by point78; 04-25-2016 at 07:55 AM. |
04-25-2016, 10:36 AM | #18 | ||||
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
I have a stock 6 speed in my car and take it to the dragstrip regularly. It is driven hard. 750WHP and still going. I have also done built 5 speeds and broken them multiple times just driving on the street at 450WHP... Quote:
http://forums.nasioc.com/forums/show....php?t=2466977 The r180 and STI rear axle info is further into the thread. http://forums.nasioc.com/forums/show...3#post39696583 |
04-25-2016, 02:57 PM | #19 |
Member#: 236952
Vehicle:2010 WRX (SSM) Stg 2+ 310/370, 6sp R180 |
a lot of people are just saying "axles" without specifying front or rear. it seems most people in here are talking rear, but i wanted to clarify that for people who couldn't deduce it themselves.
08-14 WRX front hubs with 6-speed: use WRX front axles, the stub on the hub end of the Sti axles would be too long as the STi bearing assembly is deeper, WRX axles still fit into the STi trans IIRC. 08-14 WRX rear hubs with R160: use WRX rear axles 08-14 WRX rear hubs with R180: use STi rear axles (on 11-14), or hybrid/custom axles (on 08-10). the GR sti/wrx axles are the same on the HUB-SIDE, but differ on the DIFF-side. there have been reports that the STi rear axle works just fine for the narrow body too, but not many have tried it. I plan to try this out when I swap in my 6sp/R180. Last edited by gsrcrxsi; 04-27-2016 at 11:16 AM. |
04-25-2016, 10:15 PM | #20 |
Member#: 424972
Can I use my 5speed clutch (aftermarket upgrade few miles) in the 6speed? Instead of spending more money on an upgraded sti one for the time being...
04-25-2016, 11:12 PM | #21 |
Member#: 236952
Nope. Need STI clutch. Also need STI flywheel.
Conflicting opinions on whether you need an STI starter or not. |
04-26-2016, 07:43 AM | #22 | |
Member#: 344329
But you're putting in a 6mt, do it right, put in the 6mt flywheel/clutch/slave cylinder & be done with it... You can't mix and match the 5mt & 6mt clutch items though, it's all 5mt stuff, or 6mt stuff. (And check your neutral switch too. Subaru has 2 different ones. Ones "normally open", the other "normally closed". The 5mt switch will bolt into the 6mt if they are different). I forgot to do this in mine, so it's just unhooked-ecu thinks it's always in gear. Last edited by point78; 04-26-2016 at 07:48 AM. |
04-26-2016, 05:59 PM | #23 |
Big Ron
There's been some bad clutch advice given here which is a shame. My recommendation to OP is to perform a full stop and read each and every sticky thread at the top of this forum. You are overestimating your knowledge base on clutches and transmissions for Subarus and you are receiving some incorrect advice that could have been found by proper research via the sticky threads at the top of this forum. My advice stands that you, you are REALLY interested in find the best solution to your problem to consult with the link I posted as they are the #1 Subaru transmission shop on the planet earth. Talking to them is like calling the Coke headquarters in Atlanta and asking for advice on colas. Serious.
04-26-2016, 06:04 PM | #24 |
Member#: 296742
NESIC
Vehicle:'16 STI, '11 WRX, '96 328i DSP |
From the STI you need:
Transmission Linkage Clutch/flywheel Clutch master/slave Rear Diff Driveshaft Trans mount You should be able to use your stock WRX axles from what I've researched. |
04-26-2016, 10:41 PM | #25 |
Member#: 424972
I decided to do it right and buy a new clutch for the 6speed
