Welcome to the North American Subaru Impreza Owners Club Sunday December 16, 2018
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-24-2018, 02:45 PM   #1
Profoxcg
Member#: 169036
2015 STI
Default Requirements to go stand alone
Good morning guys,
I have been having some general conversations with some local friends about going stand alone. I called AEM and Halltech to see if they had any offerings for a 2015 STI and they told me no.
I was under the impression that any engine could be connected to a standalone ecu.. when I inquired further, the person on the phone said something about the crank and pattern but I did not catch on. He said there were several "common" crank patterns that I should be able to just switch out on the engine?
Can someone explain what they were trying to convey ?
Profoxcg is offline   Reply With Quote
Old 08-02-2018, 11:05 PM   #2
binny
Member#: 198108
MY98 WRX
Try talking to Link ECU they have plugin and stand-alone and a great forum for the use of their gear and tuning
binny is offline   Reply With Quote
Old 08-03-2018, 01:24 AM   #3
subaru_gc8
Member#: 29292
2004 WRX wagon
if you are looking for a pnp I dont think there is anything. you can always wire it in, but yeah the only thing is there are little problems that you can run into with sensors not working very well with the ecu. so with that said, the best way is to go to a shop like element and have them install and tune the car.
subaru_gc8 is offline   Reply With Quote
Old 08-14-2018, 07:47 AM   #4
zeno15STI
Member#: 469099
The big boys run , cosworth ems PNP. https://www.rallysportdirect.com/par...BoCDwcQAvD_BwE
zeno15STI is offline   Reply With Quote
Old 09-02-2018, 11:26 PM   #5
Barge
Member#: 62941
2004 Forester XT
The biggest issue with all the 2008+ is that they are CAN based. A link ECU would have no issue controlling your engine... most standalone ECUs could... but speed source is ABS via CAN... cluster is CAN I think.. etc etc.
Barge is online now   Reply With Quote
Old 11-01-2018, 06:16 PM   #6
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
doesn't haltech do CAN? would probably need custom coding to get things to talk? i think they were talking about the crank position tooth pattern. im pretty sure all new-ish(newer than about 2000?) have the same crank position pattern on the timing pulley. a standalone will run any engine. its just a matter of adapting all the harnesses so everything is wired together right. and you might loose some OEM functions. that is one reason its nice to use open source reflash on the OEM ecu. you can retain alot of the stock functionality and add on more.
CarmelValleyWRX is online now   Reply With Quote
