10-27-2012, 09:09 PM | #1 |
Member#: 234613
Flywheel Crank bolt circle pattern?
I am wondering if anyone has a drawing or knows the exact dimensions of the EJ series flywheel/crank bolt pattern? I don't have any old flywheels handy at the moment and I certainly don't want to pull an engine to find out. I am looking to make a flywheel adapter for an engine swap that I am considering
Thanks!
10-27-2012, 11:26 PM | #2 |
Member#: 101865
Vehicle:88 GL-10 STi silver |
i have a spacer from an auto EJ trans, it's about 1/16" thick, but would work as a template.
PM me if interested. will ship it for $3 to cover cost of shiping. -=Suberdave=- |
10-28-2012, 04:54 AM | #3 |
Member#: 149674
SCIC
Vehicle:2006 LimitLess STI SGM |
All measurements taken off of flywheel.
All measurements in inch Center hole for pilot bearing "Diameter" = 1.2560 Flywheel bolt hole size "Diameter" = .4115 x 8 bolt holes Edge of "center hole for pilot bearing" to Edge of "flywheel bolt hole" = .4695 x 8 equal spaces Edge of "flywheel bolt hole" to Edge of "flywheel bolt hole" = .5850 x 8 equal spaces Hope this helps just hit me up if you need mor info. |
10-28-2012, 06:39 AM | #4 |
Member#: 234613
awesome, that should do it! thanks!
12-04-2012, 09:25 PM | #5 |
Member#: 336702
South East
Vehicle:1994 Impreza FWD 5mt Burgandy |
so all of the EJ series share the same bolt pattern?
12-04-2012, 09:48 PM | #6 |
Member#: 206851
Vehicle:56 Belair Pro Street |
yes, and eg and ez
