02-27-2003, 10:54 AM | #1 |
Member#: 23676
NESIC
Vehicle:. |
UTEC fuel tuning question
To lean the mixture which way must I go? up or down?
Like if the default value is 1.5, and I want to to a timy bit leaner, would I make it 1.3 or 1.7? I would think that 1.3 would be leaner, but I thought someone said that to go leaner, you increase the numbers???
02-27-2003, 12:04 PM | #2 |
Member#: 18446
Vehicle:2002 WRX wagon psm |
Down. Leaner=less fuel. The settings you're adjusting are MAF volts, which are a function of how long your injectors are being told to hold open.
If you're pulling fuel in certain spots and the value is currently .3, then you'd want to change it to .2. |
02-27-2003, 01:46 PM | #3 |
Member#: 23676
NESIC
Vehicle:. |
cool that s what I thought.
Thanks It seems I have some "tip in" knock not bad, but I am going to try a few things to cure it. |
UTEC Fuel Cutoff Question... | striklybidnis | Engine Management & Tuning | 4 | 06-23-2003 08:01 PM |
New UTEC software/tuning questions | RIDEwrx | Engine Management & Tuning | 48 | 01-23-2003 02:20 PM |
UTEC Fuel tuning question? | muddywaters | Engine Management & Tuning | 2 | 01-17-2003 08:44 PM |
TXS UTEC sowtware/tuning question | RIDEwrx | Engine Management & Tuning | 1 | 01-12-2003 06:47 PM |
UTEC fuel tuning question | rwroth | Engine Management & Tuning | 2 | 01-02-2003 06:25 PM |
