03-28-2017, 02:04 AM | #201 | |
Member#: 297202
Vehicle:2011 Impreza WRX DGM |
That's a bummer but I doubt Subaru's going to do anything for a car with that many miles. Can't hurt to ask when you get the work done, though! A squeal when the clutch is depressed is most likely the throwout bearing. I've never heard of a recall related to this issue.
03-28-2017, 01:50 PM | #202 |
Member#: 465108
Vehicle:2012 impreza 2.0L Black/grey |
@rationull ya that's what I thought but was just trying save some cash.... since now that I am going to replace it I am better off replacing whole clutch....
anyone know if there are performance clutches for our cars? or any clutch kits you guys might suggest? thanks |
04-16-2017, 09:01 PM | #203 |
Member#: 407127
Vehicle:2013 WRX Limited WR Blue |
2013 WRX, basically stock.
I've also had the "5500-6k RPM causing a shudder in the clutch pedal" issue. It used to be pretty bad, occurring around 4500 RPM when getting onto the highway. After installing a Beatrush Pitch Stop Mount and a Group N trans mount, it only happens once I hit 6k RPM, which I only need to do to see if it's still an issue. I'm curious to try firing some grease into the clutch fork assembly, but since I spend 99% of my time under 4k RPM, I don't know that it's worth the effort. There are plenty of other shortcomings to fix, first. |
06-11-2017, 10:52 AM | #204 | |
Member#: 96511
RMIC
Vehicle:2013 DGM WRX 2013 DGM XVC |
Any one tried bleeding the clutch/replacing the fluid? |
07-28-2017, 07:19 PM | #205 |
Member#: 39709
RMIC
Vehicle:2006 WRX Wag Stage 2 Black Pearl / Gold BBS |
Just got my first clutch replacement on my ‘06 at 107K (done at a dealership). The clutch now engages pretty sharply at the top of the pedal. Pushing the pedal in and out is now also pretty gritty (not heavily, but just enough to be noticeable in your toes). I’m about 50 miles on the new clutch. Unfortunantly I’m not totally sure if it was doing this when I drove away, because I was so focused on where the clutch was engaging which was throwing off my shifting ability. The original clutch was smooth as butter and engaged around the middle of pedal travel. :: annoyed::
04-22-2020, 05:56 PM | #206 |
Member#: 510601
Clutch stuck on floor.
06-29-2022, 01:36 AM | #207 |
Member#: 212598
2019 wrx here, same issue. Had the clutch replaced around 30k for a "pop" in the pedal, felt great initially (smooth and light) and 2 weeks later got the grittiness/vibration. Replaced/bled clutch fluid to no avail. Went to 2 different dealers, they acknowledged the feeling, but said it was "acceptable". Mine doesn't do it so much when cold, but gets worse as the trans gets hotter. For as many issues as I've had with this "new car" purchase, this will be my last Subaru.
06-29-2022, 10:10 PM | #208 | |
Member#: 297202
07-11-2022, 02:19 AM | #209 | |
Member#: 530655
Similar Threads | ||||
Heard a Loud Crack and then the Clutch Pedal Flew to the Floor :( | greenc51 | Transmission (AT/MT) & Driveline | 16 | 09-17-2009 01:32 AM |
Wierd subtle vibrations in acceleration and clutch pedal. | GlenCastleberry | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 03-16-2005 01:45 PM |
Is It Possible to Lighten the Clutch Pedal? | stewgod | Transmission (AT/MT) & Driveline | 13 | 09-29-2004 02:06 PM |
Whats a good aftermarket clutch that isn't too stiff on the clutch pedal | edkwon | Transmission (AT/MT) & Driveline | 6 | 09-09-2002 11:15 PM |
We're midway through the clutch install | BugBomb | Mid Atlantic Impreza Club -- MAIC | 3 | 09-09-2001 09:26 AM |
